  4. MQTT configuration question
Set Reaction > Script Action
Tom_DT
Need help reducing false positive notifications
Deleting widgets
Hopefully a trivial question, but how do you delete widgets in a status page? Using build 22266
I have the following yaml configuration in local_mqtt_devices file x_mqtt_device: set_speed: arguments: speed: type: str topic: "command/%friendly_name%" payload: type: json expr: '{ "fan": parameters.speed }' While this works fine, I'm wondering how this could be changed to "fixed" parameters, as in this case "fan" only accepts "A", "Q" or a numeric value of 1-5?
System Configuration Check - time is offset
Hi! I get this message when I'm on the status tab: System Configuration Check The time on this system and on the Reactor host are significantly different. This may be due to incorrect system configuration on either or both. Please check the configuration of both systems. The host reports 2025-04-01T15:29:29.252Z; browser reports 2025-04-01T15:29:40.528Z; difference 11.276 seconds. I have MSR installed as a docker on my Home Assistant Blue / Hardkernel ODROID-N2/N2+. MSR version is latest-25082-3c348de6. HA versions are: Core 2025.3.4 Supervisor 2025.03.4 Operating System 15.1 I have restarted HA as well as MSR multiple times. This message didn´t show two weeks ago. Don´t know if it have anything to do with the latest MSR version. Do anyone know what I can try? Thanks in advance! Let's Be Careful Out There (Hill Street reference...) /Fanan
Programmatically capture HTTP Request action status code or error
I have a very strange situation, where if InfluxDB restarts, other containers may fail when restarting at the same time (under not easy to understand circumstances), and InfluxDB remains unreachable (and these containers crashes). I need to reboot these containers in an exact order, after rebooting InfluxDB. While I understand what's going on, I need a way to reliable determine that InfluxDB is not reachable and these containers are not reachable, in order to identify this situation and manually check what's going on - and, maybe, in the future, automatically restart them if needed. So, I was looking at HTTP Request action, but I need to capture the HTTP response code, instead of the response (becase if ping is OK, InfluxDB will reply with a 204), and, potentially, a way to programmatically detect that it's failing to get the response. While I could write a custom HTTP controller for this or a custom HTTP virtual device, I was wondering if this is somewhat on you roadmap @toggledbits Thanks!
ZwaveJSUI - RGBWW BULB - Warm/Cold White interfered with RGB settings - Bulb doesn't change color if in WarmWhite state.
Hi , I'm on -Reactor (Multi-hub) latest-25067-62e21a2d -Docker on Synology NAS -ZWaveJSUI 9.31.0.6c80945 Problem with ZwaveJSUI: When I try to change color to a bulb RGBWW, it doesn't change to the RGB color and the bulb remains warm or cold white. I tryed with Zipato RGBW Bulb V2 RGBWE2, Hank Bulb HKZW-RGB01, Aentec 6 A-ZWA002, so seems that it happens with all RGBWW bulb with reactor/zwavejsui. I'm using from reator the entity action: "rgb_color.set" and "rgb_color.set_rgb". After I send the reactor command, It changes in zwavejsui the rgb settings but doesn't put the white channel to "0", so the prevalent channel remains warm/cold White and the bulb doesn't change into the rgb color. This is the status of the bulb in zwavejsui after "rgb_color.set" (235,33,33,) and the bulb is still warmWhite. x_zwave_values.Color_Switch_currentColor={"warmWhite":204,"coldWhite":0,"red":235,"green":33,"blue":33} The "cold white" and "warm white" settings interfer with the rgb color settings. Reactor can change bulb colors with rgb_color set — (value, ui8, 0x000000 to 0xffffff) or rgb_color set_rgb — (red, green, blue, all ui1, 0 to 255) but if warm or cold white are not to "0", zwavejsui doesn't change them and I can't find a way to change into rgb or from rgb back to warm white. So if I use from reactor: rgb_color set_rgb — (235,33,33) in zwavejsui I have x_zwave_values.Color_Switch_targetColor={"red":235,"green":33,"blue":33} 14/03/2025, 16:43:57 - value updated Arg 0: └─commandClassName: Color Switch └─commandClass: 51 └─property: targetColor └─endpoint: 0 └─newValue └──red: 235 └──green: 33 └──blue: 33 └─prevValue └──red: 235 └──green: 33 └──blue: 33 └─propertyName: targetColor 14/03/2025, 16:43:57 - value updated Arg 0: └─commandClassName: Color Switch └─commandClass: 51 └─property: currentColor └─endpoint: 0 └─newValue └──warmWhite: 204 └──coldWhite: 0 └──red: 235 └──green: 33 └──blue: 33 └─prevValue └──warmWhite: 204 └──coldWhite: 0 └──red: 235 └──green: 33 └──blue: 33 └─propertyName: currentColor In zwavejsui, the bulb changes rgb set but warm White remains to "204" and the bulb remais on warm White channel bacause is prevalent on rgb set. x_zwave_values.Color_Switch_currentColor_0=204 x_zwave_values.Color_Switch_currentColor_1=0 x_zwave_values.Color_Switch_currentColor_2=235 x_zwave_values.Color_Switch_currentColor_3=33 x_zwave_values.Color_Switch_currentColor_4=33 Is it possible to targetColor also for "warmWhite" and "coldWhite" and have something similar to this? x_zwave_values.Color_Switch_targetColor={"warmWhite":0,"coldWhite":0,"red":235,"green":33,"blue":33} Thanks in advance.
Problem with simultaneous notifications.
Problem after upgrading to 25067
MSR had been running fine, but I decided to follow the message to upgrade to 25067. Since the upgrade, I have received the message "Controller "<name>" (HubitatController hubitat2) could not be loaded at startup. Its ID is not unique." MSR throws the message on every restart. Has anyone else encountered this problem? I am running MSR on a Raspberry Pi4 connecting to two Hubitat units over an OpenVPN tunnel. One C8 and a C8 Pro. Both are up-to-date. It appears that despite the error message that MSR may be operating properly.
Global expressions not always evaluated
[Solved] Local expression evaluation
[Solved] Runtime error when exiting global reaction that contains a group
I am getting a Runtime error on different browsers when I click exit when editing an existing or creating a new global reaction containing a group. If the global reaction does not have a group I don't get an error. I see a similar post on the forum about a Runtime Error when creating reactions but started a new thread as that appears to be solved. The Runtime Error is different in the two browsers Safari v18.3 @http://192.168.10.21:8111/reactor/en-US/lib/js/reaction-list.js:171:44 You may report this error, but do not screen shot it. Copy-paste the complete text. Remember to include a description of the operation you were performing in as much detail as possible. Report using the Reactor Bug Tracker (in your left navigation) or at the SmartHome Community. Google Chrome 133.0.6943.142 TypeError: self.editor.isModified is not a function at HTMLButtonElement.<anonymous> (http://192.168.10.21:8111/reactor/en-US/lib/js/reaction-list.js:171:34) You may report this error, but do not screen shot it. Copy-paste the complete text. Remember to include a description of the operation you were performing in as much detail as possible. Report using the Reactor Bug Tracker (in your left navigation) or at the SmartHome Community. Steps to reproduce: Click the pencil to edit a global reaction with a group. Click the Exit button. Runtime error appears. or Click Create Reaction Click Add Action Select Group Add Condition such as Entity Attribute. Add an Action. Click Save Click Exit Runtime error appears. I don’t know how long the error has been there as I haven’t edited the global reaction in a long time. Reactor (Multi-hub) latest-25060-f32eaa46 Docker Mac OS: 15.3.1 Thanks
Cannot delete Global Expressions
SnowmanS
I am trying to delete a global expression (gLightDelay) but for some strange reason, it comes back despite clicking the Delete this expression and Save Changes buttons. I have not created a global expression for some times and just noticed this while doing some clean-up. I have upgraded Reactor to 25067 from 25060 and the behaviour is still there. I have restarted Reactor (as well as restarting its container) and cleared the browser's cache several times without success. Here's what the log shows. [latest-25067]2025-03-08T23:50:22.690Z <wsapi:INFO> [WSAPI]wsapi#1 rpc_echo [Object]{ "comment": "UI activity" } [latest-25067]2025-03-08T23:50:26.254Z <GlobalExpression:NOTICE> Deleting global expression gLightDelay [latest-25067]2025-03-08T23:50:27.887Z <wsapi:INFO> [WSAPI]wsapi#1 rpc_echo [Object]{ "comment": "UI activity" } Reactor latest-25067-62e21a2d Docker on Synology NAS
11 Posts 2 Posters 678 Views 2 Watching
          x_mqtt_device:
            set_speed:
              arguments:
                speed:
                  type: str
              payload:
                type: json
    Using MSR on Docker (Synology NAS), having InfluxDB, Grafana & Home Assistant, Hubitat C-8, Zigbee2MQTT
            x_mqtt_device:
              set_speed:
                arguments:
                  speed:
                    type: str
                payload:
                  type: json
      Then another case, where I'm trying to pass a variable "cmd":
      requires: [cmd]
          actions:
            power_switch:
              "on":
                payload:
                  type: json
                  expr: '{ "cmd": true }'
      Expression here seems to be tricky, as "cmd" does not translate to its value (e.g. "econo"). What I'm after here is the following JSON:
        "econo": true
      I have tried multiple variations, e.g.:
       expr: "{ cmd: true }"
       expr: "{ 'cmd': true }"
       expr: '{ cmd: true }'
      But no luck. The closest I have gotten is with:
      expr: '"{" + cmd + ": true }"'
      So any help is appreciated!
        Your post doesn't have enough context. Under what section have you placed the x_mqtt_device structure, for example. You're giving us a bunch of bits and pieces that don't line up to anything, so it's impossible to tell if you even have the right structure, let alone if it's going to do anything like what you want to do. If that's a template, show the entire template, because it just looks like a fragment of one.
        You also haven't given us any real context for the device itself. What is it? What topics does it send or receive?
        From what is discernible, defining an action (set_speed) that isn't defined as part of the native definition of x_mqtt_device isn't really a good idea. What you need to do is use an existing system capability that is close to your device, or perhaps define your own extended capability, but redefining an existing extended capability will only create problems.
        As for the cmd part, you're getting close. What you are missing is the context object for cmd, which is config. So you should be using config.cmd to get to the value of the cmd configuration element. But that's not the whole story... you then need to use that value as a key in creating the object. We'd like the expression language to support { [config.cmd]: true } which is similar to JavaScript, but it doesn't (yet -- I'll look into that). But what you can do is this:
          payload:
            type: json
            expr: 'result={}, result[config.cmd]=true, result'
        What this expression does is define an empty object in result, then set the key stored in config.cmd to true, and then returns that amended object as the expression result.
            payload:
              type: json
          @toggledbits thanks, cmd part works fine! Other part in the same case is:
          requires: [cmd]
              events:
                "state/%friendly_name%":
                  "power_switch.state":
                    json_payload: true
                    if_expr: '! isnull( payload?.cmd )'
                    expr: "bool(payload.cmd) ? 'on' : 'off'"
          Again, here "cmd" should translate to "econo", but for this to work I guess something similar you showed could do, but not sure how to formulate that?
            I'm in teaching mode here. I've given you the tools you need. I'll give you a little bit more... where you have payload.cmd, it is literally looking for the key named cmd in the payload. You need it to look for the word that is in cmd as given by your device configuration. This is exactly the same as one small part of the modification I gave you.
            Go forth and experiment!
              @toggledbits ok, got it (took a couple of iterations...) 😎
              Then to my original question, now with a little bit more context:
              daikin_command:
                  capabilities: [ "hvac_heating_unit", "value_sensor" ]
                  primary_attribute: hvac_heating_unit.setpoint
                  events:
                      "hvac_heating_unit.setpoint":
                        json_payload: true
                        if_expr: '! isnull( payload?.target )'
                        expr: "float(payload.target)"
                      "hvac_heating_unit.units": "°C"
                      "hvac_heating_unit.state":
                        json_payload: true
                        if_expr: '! isnull( payload?.mode )'
                        expr: "lower(payload.mode) == 'heat'"
                      "value_sensor.fan":
                        json_payload: true
                        if_expr: '! isnull( payload?.fan )'
                        expr: "str(payload.fan)"
                  actions:
                    hvac_heating_unit:
                      set_setpoint:
                        payload:
                          type: json
                          expr: '{ "temp": min(28, max(16, float(parameters.setpoint))) }'
                    x_mqtt_device:
                      set_speed:
                        arguments:
                          speed:
                            type: str
                        payload:
                          type: json
              So I want to control fan speed and I noticed there is "hvac_blower_unit" in standard capabilities:
              hvac_blower_unit:
                  actions:
                    set_mode:
                      arguments:
                        mode:
                          type: string
                          values:
                            - 'off'
                            - auto
                            - continuous
                            - periodic
                            - low
                            - medium
                            - high
              But as this wasn't 1:1 capability mapping as compared to my AC unit, I didn't know how to extend/change that to suit my needs. MQTT topics relevant to this case are documented here. Kinda thought using x_mqtt_device was a good idea. Seems to work though.
              How can I define my own (extended) MQTT capability? Also, I'd like to utilize those fixed arguments, so something like:
              set_speed:
                        arguments:
                          speed:
                            type: str
                            values:
                              - A
                              - Q
                              - 1
                              - 2
                              - 3
                              - 4
                              - 5
                daikin_command:
                    events:
                          json_payload: true
                          json_payload: true
                        "value_sensor.fan":
                          json_payload: true
                    actions:
                      hvac_heating_unit:
                        set_setpoint:
                          payload:
                            type: json
                      x_mqtt_device:
                        set_speed:
                          arguments:
                            speed:
                              type: str
                          payload:
                            type: json
                hvac_blower_unit:
                    actions:
                      set_mode:
                        arguments:
                          mode:
                            type: string
                            values:
                              - 'off'
                              - auto
                              - continuous
                              - periodic
                              - low
                              - medium
                              - high
                set_speed:
                          arguments:
                            speed:
                              type: str
                              values:
                                - A
                                - Q
                                - 1
                                - 2
                                - 3
                                - 4
                                - 5
                @tunnus Kudos! I'm guessing you discovered that something like payload[config.cmd] got you where you were going with that (I'm repeating it here for future readers, since you didn't show your final result).
                To your next question, first thing: I believe you said you are using local_mqtt_devices.yaml. You'll "modernize" a bit by moving your template to its own file (e.g. daikin.yaml) in config/mqtt_templates/. Within template files in that subdirectory, you can define both custom capabilities and the templates that use them. They are structured more like a package, so you can more easily share them as others here have done.
                In this case, though, you probably don't need to define your own capability. While the system-defined capabilities have values for attributes and action parameters, they are not set in stone. The defined values are a reasonable subset that a lot of devices may have in common, but there would be no way for me to know the entire range of values for every device that ever was or will be, so Reactor doesn't enforce them. They are mostly hints to the UI for reasonable values it can display for the user as a starting point. You can use your own values for hvac_blower_unit.set_mode without defining your own capability; it won't be a problem as long as your implementation (template) expects those values and handles them.
                You're on the right track replacing the value_sensor capability with hvac_blower_unit. Using your posted config as a guide, it may look something like below. Let's look at the attributes of the capability first:
                daikin_command:
                  # some config here, redacted in OP's post
                    capabilities: [ "hvac_heating_unit", "hvac_blower_unit" ]
                    events:
                      "some-topic-for-status-I-assume":  # topic was redacted in OP's post
                        # hvac_heating_unit stuff redacted for clarity/focus on hvac_blower_unit
                        "hvac_blower_unit.state":
                          json_payload: true
                          expr: 'payload?.fan !== "X"'  # whatever expression you need here.
                        "hvac_blower_unit.mode":
                          json_payload: true
                          expr: payload.fan
                          map:
                            A: auto
                            Q: quiet
                            1: low
                            2: low-medium
                            3: medium
                            4: medium-high
                            5: high
                What I can't tell from your posts is if there's a value for payload.fan that represents fan off. That would be used to drive the state boolean attribute. You may use an expression like expr: payload?.fan !== "X" Assuming X means off, state will be false when the fan is off, and true when it's running at any speed, which is the intent of the attribute. If the fan is always running or you just don't know (i.e. the device doesn't actually report it), you can forego the if_expr and expr and just supply value: true (or perhaps value: null, meaning "I don't know"), which supplies a fixed value for that attribute that never changes.
                For hvac_blower_unit.mode, you can see I've mapped the single-character values to strings. This isn't strictly necessary, but it's in keeping with the spirit of Reactor's design goals. Some of the values map to pre-defined values in the capability, and some don't, and that's just fine. It won't bother Reactor at all.
                Now on the action side, we need to add:
                    actions:
                      hvac_blower_unit:
                        set_mode:
                          payload:
                            type: json
                            expr: |
                              value = {},
                              value.fan =
                                  "auto": "A",
                                  "quiet": "Q",
                                  "low": 1,
                                  "low-medium": 2,
                                  "medium": 3,
                                  "medium-high": 4,
                                  "high": 5
                                })[parameters.mode] ?? parameters.mode, value
                This defines the set_mode action for the capability, preparing it to send a JSON payload. It first sets up an empty object in the value local variable. It then sets the fan key in the object by mapping any words given in the mode parameter to the action back to their letter equivalent for the device. If the value of the mode parameter doesn't map, it's just passed through as given (so you can still use the one-letter values directly if you don't want to use the words). Finally, the object in value is returned as the expression result (that's the , value bit at the end).
                Digging in to that mapping a little more, we're creating a key-value pair object on the fly to use to look the value in parameters.mode. If it matches a key (i.e. left side of a colon), it changes it to the value (the right of the colon). If it matches nothing, the lookup results in null, which is handled by the ?? operator — when given null on its left, it returns the value of the expression on its right (i.e. if the map isn't matched, parameters.mode as given is the result). This is how you can use either the fancy strings or the one-letter values equally.
                Hint: for debugging, when you run an action, MQTTController logs the exact topic and full payload being published at INFO level by default.
                Finally, if you truly wanted to define your own capability, you could make your own Daikin+MQTT custom version of hvac_blower_unit by putting it in a capabilities section of your template file (this does not work in local_mqtt_devices.yaml, only in files in config/mqtt_templates/:
                capabilities:
                  x_mqtt_daikin_moredetail:  # moredetail may include device type, model number, interface type, etc.
                      speed:
                        type: string
                        values:
                          - A
                          - Q
                          - 1
                          - 2
                          - 3
                          - 4
                          - 5
                    actions:
                      set_speed:
                        arguments:
                          speed:
                            type: string
                            values:
                              - A
                              - Q
                              - 1
                              - 2
                              - 3
                              - 4
                              - 5
                This section can just precede the templates: section in your file. You would then adjust the capability name, attribute name, and action and parameters names accordingly in the above example to match your custom definition.
                When you post snippets, please don't redact in a way that disrupts the structure. For example, you removed the topics from under events, and other data in your template. For future readers, that makes your post confusing and misleading, so other people that may find your post because they're having the same problem won't be able to follow it as easily. It would also be a courtesy to those other readers if you posted the final solution, for example the expression you finally came up with for the first problem solved.
                Link to: MQTTController Documentation
                Edit: fix missing expr in example for hvac_blower_unit.mode.
                tunnusT 2 Replies Last reply
                  daikin_command:
                      events:
                            json_payload: true
                            json_payload: true
                            expr: payload.fan
                            map:
                              A: auto
                              Q: quiet
                              1: low
                              2: low-medium
                              3: medium
                              4: medium-high
                              5: high
                      actions:
                        hvac_blower_unit:
                          set_mode:
                            payload:
                              type: json
                              expr: |
                                value = {},
                                value.fan =
                                    "auto": "A",
                                    "quiet": "Q",
                                    "low": 1,
                                    "low-medium": 2,
                                    "medium": 3,
                                    "medium-high": 4,
                                    "high": 5
                  capabilities:
                        speed:
                          type: string
                          values:
                            - A
                            - Q
                            - 1
                            - 2
                            - 3
                            - 4
                            - 5
                      actions:
                        set_speed:
                          arguments:
                            speed:
                              type: string
                              values:
                                - A
                                - Q
                                - 1
                                - 2
                                - 3
                                - 4
                                - 5
                  @toggledbits thanks again! I did left some stuff out, as I thought they were not relevant for the questions at hand, as I was not trying to present how to configure a particular device, but trying to learn how to do something a bit more "advanced" (and that stuff would be visible to others as well).
                  Actually only thing I left out from my "daikin_command" template was power_switch:
                   daikin_command:
                      # also nothing here before capabilities
                      capabilities: [ "hvac_heating_unit", "power_switch", "value_sensor" ]
                      events:
                            json_payload: true
                            if_expr: '! isnull( payload?.power )'
                            expr: "payload.power ? 'on' : 'off'"
                  For clarity, here's that "payload.cmd" final solution (with some extra logic):
                  requires: [cmd]
                      events:
                            json_payload: true
                            expr: 'config.cmd == "swingv" || config.cmd == "swingh" ? payload.swing : payload[config.cmd]'
                  About "hvac_blower_unit.mode", I think you had forgotten "expr", so I added that, and also "map_default" in case something changes in the other end, and this would continue to work. Also those mapping values were the other way around (something that you could not know).
                            json_payload: true
                            expr: "payload.fan"
                            map:
                              auto: "Auto"
                              night: "Indoor quiet"
                              low: 1
                              lowMedium: 2
                              medium: 3
                              mediumHigh: 4
                              high: 5
                            map_default: payload.fan
                     daikin_command:
                        events:
                              json_payload: true
                    requires: [cmd]
                        events:
                              json_payload: true
                              json_payload: true
                              expr: "payload.fan"
                              map:
                                auto: "Auto"
                                low: 1
                                lowMedium: 2
                                medium: 3
                                mediumHigh: 4
                                high: 5
                    @tunnus said in MQTT configuration question:
                    Yes, you are correct on expr -- I missed it. I will amend my prior post.
                    map_unmatched is not necessary. The default for map is to leave the value unchanged. And actually, the map_default you provided will result in the default being the string "payload.fan", not the value of the expression payload.fan.
                      @toggledbits ok, good to know
                        daikin_command:
                            events:
                                  json_payload: true
                                  json_payload: true
                                  expr: payload.fan
                                  map:
                                    A: auto
                                    Q: quiet
                                    1: low
                                    2: low-medium
                                    3: medium
                                    4: medium-high
                                    5: high
                            actions:
                              hvac_blower_unit:
                                set_mode:
                                  payload:
                                    type: json
                                    expr: |
                                      value = {},
                                      value.fan =
                                          "auto": "A",
                                          "quiet": "Q",
                                          "low": 1,
                                          "low-medium": 2,
                                          "medium": 3,
                                          "medium-high": 4,
                                          "high": 5
                        capabilities:
                              speed:
                                type: string
                                values:
                                  - A
                                  - Q
                                  - 1
                                  - 2
                                  - 3
                                  - 4
                                  - 5
                            actions:
                              set_speed:
                                arguments:
                                  speed:
                                    type: string
                                    values:
                                      - A
                                      - Q
                                      - 1
                                      - 2
                                      - 3
                                      - 4
                                      - 5
                        I've used MQTTX, which I can highly recommend
                        • tunnusT tunnus marked this topic as a question on
                        • tunnusT tunnus has marked this topic as solved on
                          Freemanator
                          37.3k
                        • Z-Wave Future....
                        • Can´t restart or upgrade/deploy MSR
                        • [Solved] Limit HA Entity in MSR
                        • Disaster recovery and virtualisation
                        • Remote access of Zwave stick from Z-wave server
                        • Organizing/ structuring rule sets and rules
                        • Moving MSR from a QNAP container to RP 5 - some issues
