  4. [Solved] alarm() in global expression throws error in log.
P
HA 2025.9.4 Supported Yet?
Rule Set UI bug - RESOLVED
[Reactor] Copy&Paste of Rules
[Reactor] Help with scene controller cycling logic
Expose MSR entities
Comment in Globa Expressions
Tom_DT
Gradually turn on lights.
Tom_DT
26 Posts 2 Posters 111 Views 2 Watching
    wrote last edited by Crille
    I'm testing the new alarm() function but I can't get it to do what I expect.
    alarm.PNG This does not re-evaluate the expression and an error is logged on first run and when run manually:
    [latest-25310]2025-11-06T19:02:45.379Z <Engine:NOTICE> Engine#1 creating global expression alarmTest
    [latest-25310]2025-11-06T19:02:50.381Z <Engine:ERR> Engine#1 failed alarm() update for $global: [Error] Expression name "" is invalid [-]
    [latest-25310]2025-11-06T19:02:50.381Z <Engine:CRIT> Error: Expression name "" is invalid [-]
        at GlobalExpression.getInstance (/home/homebridge/reactor/server/lib/GlobalExpression.js:60:19)
        at Timer.callback (/home/homebridge/reactor/server/lib/Engine.js:1428:166)
        at Timer._fire (/home/homebridge/reactor/server/lib/Timer.js:219:46)
        at listOnTimeout (node:internal/timers:608:17)
        at process.processTimers (node:internal/timers:543:7)
    Nothing related before or after in the log. I've tried with existing variables but same behavior and log entry when saved or run manually, latest-25310
    EDIT: Bare Metal install and what I expect is the timestamp to update every 5 seconds.
      OK. I respun buld 25310. Pull the new zip and give it another go.
        You're fast! It's now behaving as expected (even though it's logged as CRIT? but that's your court so you set the rules 🙂 )
        [latest-25310]2025-11-06T19:44:05.638Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
        [latest-25310]2025-11-06T19:44:05.638Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762458250638<2025-11-06 20:44:10> = now 1762458245638<2025-11-06 20:44:05> + delay 5000
        [latest-25310]2025-11-06T19:44:10.639Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
        [latest-25310]2025-11-06T19:44:10.639Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762458255639<2025-11-06 20:44:15> = now 1762458250639<2025-11-06 20:44:10> + delay 5000
        [latest-25310]2025-11-06T19:44:15.641Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
        [latest-25310]2025-11-06T19:44:15.642Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762458260642<2025-11-06 20:44:20> = now 1762458255642<2025-11-06 20:44:15> + delay 5000
          Just debug elevated. Next build it will be quiet.
            Understandable, thank you for the quick fix.
              I'm still having some (other) issues...
              First a question, is do...done in a Global expression considered out of scope to the function? because when alarm() is put in the statement block it shows error. When alarm() is put before the statement block it seems to be working a bit inconsistent, probably related to the observations further down.
              Another issue. I cleared the alarmTest, restarted Reactor, hard refreshed browser and put
              alarm(5),
              getEntity( "reactor_system>system" ).attributes.reactor_system.reactor_uptime
              All good and now there's no error (and no statement block) but when I changed alarm(5) to alarm(10) and saved, on first tick, an error is logged and a minor misleading tick at 5000ms lingers but the + delay says 10000ms as expected. This error happens every time I change anything in the expression.
              [latest-25310]2025-11-07T09:15:54.492Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
              [latest-25310]2025-11-07T09:15:54.492Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762506964492<2025-11-07 10:16:04> = now 1762506954492<2025-11-07 10:15:54> + delay 10000
              [latest-25310]2025-11-07T09:15:55.349Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T09:15:55.349Z <Engine:ERR> Engine#1: expression: alarm(10),
              [latest-25310]2025-11-07T09:15:55.349Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                  at /home/homebridge/reactor/server/lib/Engine.js:1435:23
                  at _run (/home/homebridge/reactor/common/lexp.js:1704:34)
                  at /home/homebridge/reactor/common/lexp.js:1426:29
                  at _run (/home/homebridge/reactor/common/lexp.js:1425:28)
                  at Object.run (/home/homebridge/reactor/common/lexp.js:1855:24)
                  at Engine._eval_expr (/home/homebridge/reactor/server/lib/Engine.js:1156:165)
                  at Engine._expr_dependency (/home/homebridge/reactor/server/lib/Engine.js:1529:96)
                  at /home/homebridge/reactor/server/lib/MessageBus.js:57:289
              [latest-25310]2025-11-07T09:16:04.494Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
              [latest-25310]2025-11-07T09:16:04.495Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762506974494<2025-11-07 10:16:14> = now 1762506964494<2025-11-07 10:16:04> + delay 10000
              [latest-25310]2025-11-07T09:16:14.495Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
              Trying this, an entity that is updating faster than the tick. The GUI is flapping between error and OK value and the log goes crazy
              [latest-25310]2025-11-07T10:01:36.227Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
              [latest-25310]2025-11-07T10:01:36.227Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
              [latest-25310]2025-11-07T10:01:36.227Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762509711227<2025-11-07 11:01:51> = now 1762509696227<2025-11-07 11:01:36> + delay 15000
              [latest-25310]2025-11-07T10:01:41.200Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.200Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              getEntity( "mosquitto-mqtt>smartmeter" ).attributes.x_momentary_active_import.value
              [latest-25310]2025-11-07T10:01:41.200Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.206Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.206Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.206Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.209Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.209Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.209Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.212Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.212Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.212Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.215Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.215Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.215Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.217Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.217Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.218Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.220Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.220Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.220Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.223Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.223Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.223Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.230Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.230Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.230Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.233Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.233Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.233Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              (Bare Metal, latest-25310-dc2bb580)
                Respun again. Give it a try.
                  Testing with
                  alarm(0),
                  alarm(15),
                  Same behavior in GUI, log:
                  [latest-25310]2025-11-07T14:32:20.950Z <Engine:NOTICE> Engine#1 expression alarmTest has changed
                  [latest-25310]2025-11-07T14:32:20.951Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:20.951Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525955951<2025-11-07 15:32:35> = now 1762525940951<2025-11-07 15:32:20> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.782Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:21.782Z <Engine:ERR> Engine#1: expression: alarm(0),
                  alarm(15),getEntity( "mosquitto-mqtt>smartmeter" ).attributes.x_momentary_active_import.value
                  [latest-25310]2025-11-07T14:32:21.783Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                      at /home/homebridge/reactor/server/lib/Engine.js:1455:23
                      at Engine._eval_expr (/home/homebridge/reactor/server/lib/Engine.js:1170:141)
                      at Engine._expr_dependency (/home/homebridge/reactor/server/lib/Engine.js:1555:82)
                      at /home/homebridge/reactor/server/lib/MessageBus.js:114:195
                  [latest-25310]2025-11-07T14:32:21.791Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.791Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956791<2025-11-07 15:32:36> = now 1762525941791<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.796Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.796Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956796<2025-11-07 15:32:36> = now 1762525941796<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.801Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.801Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956801<2025-11-07 15:32:36> = now 1762525941801<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.803Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.803Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956803<2025-11-07 15:32:36> = now 1762525941803<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.805Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.806Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956806<2025-11-07 15:32:36> = now 1762525941806<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.812Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.812Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956812<2025-11-07 15:32:36> = now 1762525941812<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.815Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.815Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956815<2025-11-07 15:32:36> = now 1762525941815<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:25.543Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.544Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.544Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:25.835Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.836Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.836Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:25.995Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.996Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.996Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:26.338Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.339Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.339Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:26.469Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.469Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.469Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:26.882Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.883Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.883Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:26.970Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.970Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.970Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:27.400Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:27.400Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:27.401Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:29.986Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:29.986Z <Engine:ERR> Engine#1: expression: alarm(0),
                  [latest-25310]2025-11-07T14:32:29.987Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.727Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.727Z <Engine:ERR> Engine#1: expression: alarm(0),
                  [latest-25310]2025-11-07T14:32:31.727Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.735Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.735Z <Engine:ERR> Engine#1: expression: alarm(0),
                  [latest-25310]2025-11-07T14:32:31.735Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.738Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.738Z <Engine:ERR> Engine#1: expression: alarm(0),
                    Can you show me an alarm tick message?
                      Yes, if I lower the tick to 2000ms it's logged (different from before)
                      [latest-25310]2025-11-07T14:42:21.833Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762526543833<2025-11-07 15:42:23> = now 1762526541833<2025-11-07 15:42:21> + delay 2000
                      [latest-25310]2025-11-07T14:42:23.833Z <Engine:CRIT> Engine#1 alarmTest alarm() tick
                      [latest-25310]2025-11-07T14:42:23.833Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                        Odd. I'm not able to duplicate this, and there's a message missing from the log that I would expect to see in conjunction with the other messages. Can you re-apply the build and restart, and try again?
                          I downloaded it again, re-applied and restarted.
                          Changed entity to eliminate any issues with my x_mqtt entity but same behavior and this is whats logged at Engine level 4
                          [latest-25310]2025-11-07T15:19:15.932Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:16.861Z <Engine:CRIT> Engine#1 alarmTest alarm() tick
                          [latest-25310]2025-11-07T15:19:16.861Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                          [latest-25310]2025-11-07T15:19:16.862Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762528771862<2025-11-07 16:19:31> = now 1762528756862<2025-11-07 16:19:16> + delay 15000
                          [latest-25310]2025-11-07T15:19:21.817Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.817Z <Engine:ERR> Engine#1: expression: alarm(0),
                          alarm(15),
                          getEntity( "hass>sensor_momentary_active_import" ).attributes.string_sensor.value
                          [latest-25310]2025-11-07T15:19:21.817Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.823Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.823Z <Engine:ERR> Engine#1: expression: alarm(0),
                          alarm(15),
                          [latest-25310]2025-11-07T15:19:21.824Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.827Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.827Z <Engine:ERR> Engine#1: expression: alarm(0),
                          alarm(15)...
                          Tried Engine log level 5 but was to much for me to handle 🙂 I tested the same expression in a new variable but it produced the same error.
                          No related errors in the startup sequence of the log either.
                            Can you show the log starting with "expression alarmTest has changed" (context before the error message)?
                              Unfortunately that's long gone by testing level 5 but before that the expression was the simple string "hello" so there were only rule related log entries before it. I can reproduce it if you want though...
                                Yes, please reproduce. Level 4 is fine. You can also set gvar_debug: true in the engine config section -- that will be verbose but a lot less verbose than level 5.
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 expr alertElmatare result changed=false, was false now false
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 evaluating global poolHeat expression do
                                    selling = getEntity( "virtual>time_series_selling" ).attributes.power_sensor.value,
                                    buying = getEntity( "mosquitto-mqtt>smartmeter" ).attributes.x_momentary_active_import.value,
                                    rule = isRuleSet("rule-l3wyah83"),
                                  case
                                    when selling >= 1.8 : bool(true)
                                    when buying < 0.8 and rule : bool(true)
                                    when poolHeatTrigger == "on" : bool(true)
                                    else bool(false)
                                  done source global
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 global expression poolHeat old value=false
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "hello" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__tree": Array(1) ["poolHeat"], "__suppress_dependencies": true }, "__tree": (seen=.__global.__tree), "__suppress_dependencies": true }
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 expr poolHeat result changed=false, was false now false
                                  [latest-25310]2025-11-07T16:16:42.411Z <Engine:INFO> Engine#1 evaluating global Självförsörjande expression int(getEntity( "vera>device_56" ).attributes.x_vera_svc_micasaverde_com_GenericSensor1.self_sufficient) source global
                                  [latest-25310]2025-11-07T16:16:42.412Z <Engine:INFO> Engine#1 global expression Självförsörjande old value=0
                                  [latest-25310]2025-11-07T16:16:42.412Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "hello" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__tree": Array(1) ["Självförsörjande"], "__suppress_dependencies": true }, "__tree": (seen=.__global.__tree), "__suppress_dependencies": true }
                                  [latest-25310]2025-11-07T16:16:42.412Z <Engine:INFO> Engine#1 expr Självförsörjande result changed=false, was 0 now 0
                                  [latest-25310]2025-11-07T16:16:47.368Z <Engine:NOTICE> Engine#1 expression alarmTest has changed
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 _compile_global_expr alarmTest
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 global expression alarmTest refers to: Array(0) []
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 evaluating global alarmTest expression alarm(0),
                                  alarm(15),
                                  getEntity( "hass>sensor_momentary_active_import" ).attributes.string_sensor.value source global
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 global expression alarmTest old value=hello
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "hello" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__tree": Array(1) ["alarmTest"] }, "__tree": (seen=.__global.__tree) }
                                  [latest-25310]2025-11-07T16:16:47.371Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                                  [latest-25310]2025-11-07T16:16:47.371Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762532222371<2025-11-07 17:17:02> = now 1762532207371<2025-11-07 17:16:47> + delay 15000
                                  [latest-25310]2025-11-07T16:16:47.371Z <Engine:INFO> Engine#1 getEntity evaluating global alarmTest with ValueSensor#hass>sensor_momentary_active_import dependency
                                  [latest-25310]2025-11-07T16:16:47.371Z <Engine:INFO> Engine#1 expr alarmTest result changed=true, was hello now "1.123"
                                  [latest-25310]2025-11-07T16:16:47.372Z <Engine:INFO> Engine#1 notify() expression state change GlobalExpression#alarmTest
                                  [latest-25310]2025-11-07T16:16:47.373Z <Engine:INFO> Engine#1 var alarmTest changed, evaluating dependents {  }
                                  [latest-25310]2025-11-07T16:16:47.373Z <Engine:INFO> Engine#1 update dependencies for alarmTest, which are: Array(0) []
                                  [latest-25310]2025-11-07T16:16:47.373Z <Engine:INFO> Engine#1 expr_tree is now {
                                    testHere: {},
                                    chargeAmps: {},
                                    poolHeat: {},
                                    poolHeatTrigger: { poolHeat: {} },
                                    'Växthuset': {},
                                    Medeltemp: {},
                                    Luftfuktighet: {},
                                    EzloDevicesNotResponding: {},
                                    prevEzloDevicesNotResponding: {},
                                    VeraDevicesNotResponding: {},
                                    openLuupWasDown: {},
                                    Charging: {},
                                    ReactorRestarted: {},
                                    HumOutdoor: {},
                                    TempOutdoor: {},
                                    'Självförsörjande': {},
                                    Elpris: {},
                                    restartCameraRTSP: {},
                                    lovVecka: {},
                                    VVBsellingHigh: {},
                                    HassElpriser: {},
                                    chargeNow: {},
                                    alertBLE: {},
                                    ElpriserMedelMedian: {},
                                    ChargingPaused: {},
                                    alertElmatare: {},
                                    functions: {},
                                    functionsDEV: {},
                                    alarmTest: {}
                                  [latest-25310]2025-11-07T16:16:51.916Z <Engine:INFO> Engine#1 evaluating global chargeAmps expression do
                                  More?
                                    No errors now?
                                      Oops, sorry. There's a lot going on with other stuff then this is logged.
                                      [latest-25310]2025-11-07T16:16:51.930Z <Engine:INFO> Engine#1 global expression poolHeat old value=false
                                      [latest-25310]2025-11-07T16:16:51.930Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "1.123" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__alarmhandle": { "alarmTest": Timer(Timer#alarm:alarmTest) }, "__suppress_dependencies": true, "__tree": Array(1) ["poolHeat"] }, "__alarmhandle": (seen=.__global.__alarmhandle), "__suppress_dependencies": true, "__tree": (seen=.__global.__tree) }
                                      [latest-25310]2025-11-07T16:16:51.930Z <Engine:INFO> Engine#1 expr poolHeat result changed=false, was false now false
                                      [latest-25310]2025-11-07T16:16:51.932Z <Engine:INFO> Engine#1 evaluating global alarmTest expression alarm(0),
                                      alarm(15),
                                      [latest-25310]2025-11-07T16:16:51.932Z <Engine:INFO> Engine#1 global expression alarmTest old value="1.123"
                                      [latest-25310]2025-11-07T16:16:51.932Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "1.123" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__alarmhandle": { "alarmTest": Timer(Timer#alarm:alarmTest) }, "__suppress_dependencies": true, "__tree": Array(1) ["alarmTest"] }, "__alarmhandle": (seen=.__global.__alarmhandle), "__suppress_dependencies": true, "__tree": (seen=.__global.__tree) }
                                      [latest-25310]2025-11-07T16:16:51.932Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                                      [latest-25310]2025-11-07T16:16:51.933Z <Engine:ERR> Engine#1: expression: alarm(0),
                                      alarm(15),
                                      [latest-25310]2025-11-07T16:16:51.945Z <Engine:INFO> Engine#1: path alarmTest->alarmTest
                                      [latest-25310]2025-11-07T16:16:51.945Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                                      [latest-25310]2025-11-07T16:16:51.947Z <Engine:INFO> Engine#1 expr alarmTest result changed=true, was "1.123" now (null)
                                      [latest-25310]2025-11-07T16:16:51.948Z <Engine:INFO> Engine#1 notify() expression state change GlobalExpression#alarmTest
                                      [latest-25310]2025-11-07T16:16:51.949Z <Engine:INFO> Engine#1 var alarmTest changed, evaluating dependents {  }
                                      [latest-25310]2025-11-07T16:16:51.949Z <Engine:INFO> Engine#1 update dependencies for alarmTest, which are: Array(0) []
                                      [latest-25310]2025-11-07T16:16:51.959Z <Engine:INFO> Engine#1 evaluating global chargeAmps expression do
                                        Where else are you using that variable, and how?
                                          Nowhere, strictly to test the function before I put it in production
                                          • [Solved] alarm() in global expression throws error in log.
                                            111
                                            33
                                          • [Solved] Define function issue in latest-25304
                                            71.4k
                                          • Shelly Wall Display XL
                                          • No Upgrade Notification for Build 25308?
                                          • Strange behavior in MSR latest-25304 with disabled groups in Reaction
                                            9.0k
