  4. [Solved] alarm() in global expression throws error in log.
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
26 Posts 2 Posters 1.3k Views 2 Watching
  • CrilleC Online
    CrilleC Online
    wrote last edited by Crille
    I'm testing the new alarm() function but I can't get it to do what I expect.
    alarm.PNG This does not re-evaluate the expression and an error is logged on first run and when run manually:
    [latest-25310]2025-11-06T19:02:45.379Z <Engine:NOTICE> Engine#1 creating global expression alarmTest
    [latest-25310]2025-11-06T19:02:50.381Z <Engine:ERR> Engine#1 failed alarm() update for $global: [Error] Expression name "" is invalid [-]
    [latest-25310]2025-11-06T19:02:50.381Z <Engine:CRIT> Error: Expression name "" is invalid [-]
        at GlobalExpression.getInstance (/home/homebridge/reactor/server/lib/GlobalExpression.js:60:19)
        at Timer.callback (/home/homebridge/reactor/server/lib/Engine.js:1428:166)
        at Timer._fire (/home/homebridge/reactor/server/lib/Timer.js:219:46)
        at listOnTimeout (node:internal/timers:608:17)
        at process.processTimers (node:internal/timers:543:7)
    Nothing related before or after in the log. I've tried with existing variables but same behavior and log entry when saved or run manually, latest-25310
    EDIT: Bare Metal install and what I expect is the timestamp to update every 5 seconds.
      OK. I respun buld 25310. Pull the new zip and give it another go.
      • CrilleC Online
        CrilleC Online
        You're fast! It's now behaving as expected (even though it's logged as CRIT? but that's your court so you set the rules 🙂 )
        [latest-25310]2025-11-06T19:44:05.638Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
        [latest-25310]2025-11-06T19:44:05.638Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762458250638<2025-11-06 20:44:10> = now 1762458245638<2025-11-06 20:44:05> + delay 5000
        [latest-25310]2025-11-06T19:44:10.639Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
        [latest-25310]2025-11-06T19:44:10.639Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762458255639<2025-11-06 20:44:15> = now 1762458250639<2025-11-06 20:44:10> + delay 5000
        [latest-25310]2025-11-06T19:44:15.641Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
        [latest-25310]2025-11-06T19:44:15.642Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762458260642<2025-11-06 20:44:20> = now 1762458255642<2025-11-06 20:44:15> + delay 5000
          Just debug elevated. Next build it will be quiet.
          • CrilleC Online
            CrilleC Online
            Understandable, thank you for the quick fix.
            • CrilleC Online
              CrilleC Online
              I'm still having some (other) issues...
              First a question, is do...done in a Global expression considered out of scope to the function? because when alarm() is put in the statement block it shows error. When alarm() is put before the statement block it seems to be working a bit inconsistent, probably related to the observations further down.
              Another issue. I cleared the alarmTest, restarted Reactor, hard refreshed browser and put
              alarm(5),
              getEntity( "reactor_system>system" ).attributes.reactor_system.reactor_uptime
              All good and now there's no error (and no statement block) but when I changed alarm(5) to alarm(10) and saved, on first tick, an error is logged and a minor misleading tick at 5000ms lingers but the + delay says 10000ms as expected. This error happens every time I change anything in the expression.
              [latest-25310]2025-11-07T09:15:54.492Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
              [latest-25310]2025-11-07T09:15:54.492Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762506964492<2025-11-07 10:16:04> = now 1762506954492<2025-11-07 10:15:54> + delay 10000
              [latest-25310]2025-11-07T09:15:55.349Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T09:15:55.349Z <Engine:ERR> Engine#1: expression: alarm(10),
              [latest-25310]2025-11-07T09:15:55.349Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                  at /home/homebridge/reactor/server/lib/Engine.js:1435:23
                  at _run (/home/homebridge/reactor/common/lexp.js:1704:34)
                  at /home/homebridge/reactor/common/lexp.js:1426:29
                  at _run (/home/homebridge/reactor/common/lexp.js:1425:28)
                  at Object.run (/home/homebridge/reactor/common/lexp.js:1855:24)
                  at Engine._eval_expr (/home/homebridge/reactor/server/lib/Engine.js:1156:165)
                  at Engine._expr_dependency (/home/homebridge/reactor/server/lib/Engine.js:1529:96)
                  at /home/homebridge/reactor/server/lib/MessageBus.js:57:289
              [latest-25310]2025-11-07T09:16:04.494Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
              [latest-25310]2025-11-07T09:16:04.495Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762506974494<2025-11-07 10:16:14> = now 1762506964494<2025-11-07 10:16:04> + delay 10000
              [latest-25310]2025-11-07T09:16:14.495Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
              Trying this, an entity that is updating faster than the tick. The GUI is flapping between error and OK value and the log goes crazy
              [latest-25310]2025-11-07T10:01:36.227Z <Engine:CRIT> Engine#1 alarmTest alarm() tick 5000ms
              [latest-25310]2025-11-07T10:01:36.227Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
              [latest-25310]2025-11-07T10:01:36.227Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762509711227<2025-11-07 11:01:51> = now 1762509696227<2025-11-07 11:01:36> + delay 15000
              [latest-25310]2025-11-07T10:01:41.200Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.200Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              getEntity( "mosquitto-mqtt>smartmeter" ).attributes.x_momentary_active_import.value
              [latest-25310]2025-11-07T10:01:41.200Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.206Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.206Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.206Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.209Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.209Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.209Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.212Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.212Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.212Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.215Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.215Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.215Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.217Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.217Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.218Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.220Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.220Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.220Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.223Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.223Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.223Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.230Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.230Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.230Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.233Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
              [latest-25310]2025-11-07T10:01:41.233Z <Engine:ERR> Engine#1: expression: alarm(0),
              alarm(15),
              [latest-25310]2025-11-07T10:01:41.233Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
              (Bare Metal, latest-25310-dc2bb580)
                Respun again. Give it a try.
                • CrilleC Online
                  CrilleC Online
                  Testing with
                  alarm(0),
                  alarm(15),
                  Same behavior in GUI, log:
                  [latest-25310]2025-11-07T14:32:20.950Z <Engine:NOTICE> Engine#1 expression alarmTest has changed
                  [latest-25310]2025-11-07T14:32:20.951Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:20.951Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525955951<2025-11-07 15:32:35> = now 1762525940951<2025-11-07 15:32:20> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.782Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:21.782Z <Engine:ERR> Engine#1: expression: alarm(0),
                  alarm(15),getEntity( "mosquitto-mqtt>smartmeter" ).attributes.x_momentary_active_import.value
                  [latest-25310]2025-11-07T14:32:21.783Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                      at /home/homebridge/reactor/server/lib/Engine.js:1455:23
                      at Engine._eval_expr (/home/homebridge/reactor/server/lib/Engine.js:1170:141)
                      at Engine._expr_dependency (/home/homebridge/reactor/server/lib/Engine.js:1555:82)
                      at /home/homebridge/reactor/server/lib/MessageBus.js:114:195
                  [latest-25310]2025-11-07T14:32:21.791Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.791Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956791<2025-11-07 15:32:36> = now 1762525941791<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.796Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.796Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956796<2025-11-07 15:32:36> = now 1762525941796<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.801Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.801Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956801<2025-11-07 15:32:36> = now 1762525941801<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.803Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.803Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956803<2025-11-07 15:32:36> = now 1762525941803<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.805Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.806Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956806<2025-11-07 15:32:36> = now 1762525941806<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.812Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.812Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956812<2025-11-07 15:32:36> = now 1762525941812<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:21.815Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                  [latest-25310]2025-11-07T14:32:21.815Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762525956815<2025-11-07 15:32:36> = now 1762525941815<2025-11-07 15:32:21> + delay 15000
                  [latest-25310]2025-11-07T14:32:25.543Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.544Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.544Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:25.835Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.836Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.836Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:25.995Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.996Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:25.996Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:26.338Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.339Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.339Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:26.469Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.469Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.469Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:26.882Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.883Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.883Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:26.970Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.970Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:26.970Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:27.400Z <Rule:INFO> Luftrenare Sovrum (rule-lu9y668n in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:27.400Z <Rule:INFO> LV pump värme - Övervåningen (rule-lb10thf8 in Funktioner) starting rule state evaluation; because entity-changed Entity#mosquitto-mqtt>sovrumsdorr
                  [latest-25310]2025-11-07T14:32:27.401Z <Rule:INFO> Rule#rule-lb10thf8 local temp has object dependency
                  [latest-25310]2025-11-07T14:32:29.986Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:29.986Z <Engine:ERR> Engine#1: expression: alarm(0),
                  [latest-25310]2025-11-07T14:32:29.987Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.727Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.727Z <Engine:ERR> Engine#1: expression: alarm(0),
                  [latest-25310]2025-11-07T14:32:31.727Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.735Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.735Z <Engine:ERR> Engine#1: expression: alarm(0),
                  [latest-25310]2025-11-07T14:32:31.735Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.738Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                  [latest-25310]2025-11-07T14:32:31.738Z <Engine:ERR> Engine#1: expression: alarm(0),
                    Can you show me an alarm tick message?
                    • CrilleC Online
                      CrilleC Online
                      Yes, if I lower the tick to 2000ms it's logged (different from before)
                      [latest-25310]2025-11-07T14:42:21.833Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762526543833<2025-11-07 15:42:23> = now 1762526541833<2025-11-07 15:42:21> + delay 2000
                      [latest-25310]2025-11-07T14:42:23.833Z <Engine:CRIT> Engine#1 alarmTest alarm() tick
                      [latest-25310]2025-11-07T14:42:23.833Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                        Odd. I'm not able to duplicate this, and there's a message missing from the log that I would expect to see in conjunction with the other messages. Can you re-apply the build and restart, and try again?
                        • CrilleC Online
                          CrilleC Online
                          I downloaded it again, re-applied and restarted.
                          Changed entity to eliminate any issues with my x_mqtt entity but same behavior and this is whats logged at Engine level 4
                          [latest-25310]2025-11-07T15:19:15.932Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:16.861Z <Engine:CRIT> Engine#1 alarmTest alarm() tick
                          [latest-25310]2025-11-07T15:19:16.861Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                          [latest-25310]2025-11-07T15:19:16.862Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762528771862<2025-11-07 16:19:31> = now 1762528756862<2025-11-07 16:19:16> + delay 15000
                          [latest-25310]2025-11-07T15:19:21.817Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.817Z <Engine:ERR> Engine#1: expression: alarm(0),
                          alarm(15),
                          getEntity( "hass>sensor_momentary_active_import" ).attributes.string_sensor.value
                          [latest-25310]2025-11-07T15:19:21.817Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.823Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.823Z <Engine:ERR> Engine#1: expression: alarm(0),
                          alarm(15),
                          [latest-25310]2025-11-07T15:19:21.824Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.827Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                          [latest-25310]2025-11-07T15:19:21.827Z <Engine:ERR> Engine#1: expression: alarm(0),
                          alarm(15)...
                          Tried Engine log level 5 but was to much for me to handle 🙂 I tested the same expression in a new variable but it produced the same error.
                          No related errors in the startup sequence of the log either.
                            Can you show the log starting with "expression alarmTest has changed" (context before the error message)?
                            • CrilleC Online
                              CrilleC Online
                              Unfortunately that's long gone by testing level 5 but before that the expression was the simple string "hello" so there were only rule related log entries before it. I can reproduce it if you want though...
                                Yes, please reproduce. Level 4 is fine. You can also set gvar_debug: true in the engine config section -- that will be verbose but a lot less verbose than level 5.
                                • CrilleC Online
                                  CrilleC Online
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 expr alertElmatare result changed=false, was false now false
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 evaluating global poolHeat expression do
                                    selling = getEntity( "virtual>time_series_selling" ).attributes.power_sensor.value,
                                    buying = getEntity( "mosquitto-mqtt>smartmeter" ).attributes.x_momentary_active_import.value,
                                    rule = isRuleSet("rule-l3wyah83"),
                                  case
                                    when selling >= 1.8 : bool(true)
                                    when buying < 0.8 and rule : bool(true)
                                    when poolHeatTrigger == "on" : bool(true)
                                    else bool(false)
                                  done source global
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 global expression poolHeat old value=false
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "hello" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__tree": Array(1) ["poolHeat"], "__suppress_dependencies": true }, "__tree": (seen=.__global.__tree), "__suppress_dependencies": true }
                                  [latest-25310]2025-11-07T16:16:41.926Z <Engine:INFO> Engine#1 expr poolHeat result changed=false, was false now false
                                  [latest-25310]2025-11-07T16:16:42.411Z <Engine:INFO> Engine#1 evaluating global Självförsörjande expression int(getEntity( "vera>device_56" ).attributes.x_vera_svc_micasaverde_com_GenericSensor1.self_sufficient) source global
                                  [latest-25310]2025-11-07T16:16:42.412Z <Engine:INFO> Engine#1 global expression Självförsörjande old value=0
                                  [latest-25310]2025-11-07T16:16:42.412Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "hello" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__tree": Array(1) ["Självförsörjande"], "__suppress_dependencies": true }, "__tree": (seen=.__global.__tree), "__suppress_dependencies": true }
                                  [latest-25310]2025-11-07T16:16:42.412Z <Engine:INFO> Engine#1 expr Självförsörjande result changed=false, was 0 now 0
                                  [latest-25310]2025-11-07T16:16:47.368Z <Engine:NOTICE> Engine#1 expression alarmTest has changed
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 _compile_global_expr alarmTest
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 global expression alarmTest refers to: Array(0) []
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 evaluating global alarmTest expression alarm(0),
                                  alarm(15),
                                  getEntity( "hass>sensor_momentary_active_import" ).attributes.string_sensor.value source global
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 global expression alarmTest old value=hello
                                  [latest-25310]2025-11-07T16:16:47.369Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "hello" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__tree": Array(1) ["alarmTest"] }, "__tree": (seen=.__global.__tree) }
                                  [latest-25310]2025-11-07T16:16:47.371Z <Engine:CRIT> Engine#1 alarm(0) -- cancelling alarmTest timer
                                  [latest-25310]2025-11-07T16:16:47.371Z <Engine:CRIT> Engine#1 alarm() scheduled alarmTest tick for 1762532222371<2025-11-07 17:17:02> = now 1762532207371<2025-11-07 17:16:47> + delay 15000
                                  [latest-25310]2025-11-07T16:16:47.371Z <Engine:INFO> Engine#1 getEntity evaluating global alarmTest with ValueSensor#hass>sensor_momentary_active_import dependency
                                  [latest-25310]2025-11-07T16:16:47.371Z <Engine:INFO> Engine#1 expr alarmTest result changed=true, was hello now "1.123"
                                  [latest-25310]2025-11-07T16:16:47.372Z <Engine:INFO> Engine#1 notify() expression state change GlobalExpression#alarmTest
                                  [latest-25310]2025-11-07T16:16:47.373Z <Engine:INFO> Engine#1 var alarmTest changed, evaluating dependents {  }
                                  [latest-25310]2025-11-07T16:16:47.373Z <Engine:INFO> Engine#1 update dependencies for alarmTest, which are: Array(0) []
                                  [latest-25310]2025-11-07T16:16:47.373Z <Engine:INFO> Engine#1 expr_tree is now {
                                    testHere: {},
                                    chargeAmps: {},
                                    poolHeat: {},
                                    poolHeatTrigger: { poolHeat: {} },
                                    'Växthuset': {},
                                    Medeltemp: {},
                                    Luftfuktighet: {},
                                    EzloDevicesNotResponding: {},
                                    prevEzloDevicesNotResponding: {},
                                    VeraDevicesNotResponding: {},
                                    openLuupWasDown: {},
                                    Charging: {},
                                    ReactorRestarted: {},
                                    HumOutdoor: {},
                                    TempOutdoor: {},
                                    'Självförsörjande': {},
                                    Elpris: {},
                                    restartCameraRTSP: {},
                                    lovVecka: {},
                                    VVBsellingHigh: {},
                                    HassElpriser: {},
                                    chargeNow: {},
                                    alertBLE: {},
                                    ElpriserMedelMedian: {},
                                    ChargingPaused: {},
                                    alertElmatare: {},
                                    functions: {},
                                    functionsDEV: {},
                                    alarmTest: {}
                                  [latest-25310]2025-11-07T16:16:51.916Z <Engine:INFO> Engine#1 evaluating global chargeAmps expression do
                                  More?
                                    No errors now?
                                    • CrilleC Online
                                      CrilleC Online
                                      Oops, sorry. There's a lot going on with other stuff then this is logged.
                                      [latest-25310]2025-11-07T16:16:51.930Z <Engine:INFO> Engine#1 global expression poolHeat old value=false
                                      [latest-25310]2025-11-07T16:16:51.930Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "1.123" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__alarmhandle": { "alarmTest": Timer(Timer#alarm:alarmTest) }, "__suppress_dependencies": true, "__tree": Array(1) ["poolHeat"] }, "__alarmhandle": (seen=.__global.__alarmhandle), "__suppress_dependencies": true, "__tree": (seen=.__global.__tree) }
                                      [latest-25310]2025-11-07T16:16:51.930Z <Engine:INFO> Engine#1 expr poolHeat result changed=false, was false now false
                                      [latest-25310]2025-11-07T16:16:51.932Z <Engine:INFO> Engine#1 evaluating global alarmTest expression alarm(0),
                                      alarm(15),
                                      [latest-25310]2025-11-07T16:16:51.932Z <Engine:INFO> Engine#1 global expression alarmTest old value="1.123"
                                      [latest-25310]2025-11-07T16:16:51.932Z <Engine:INFO> Engine#1 evaluation context { "__lvar": { "MAXINT": 9007199254740991, "MININT": -9007199254740991, "MAXFLOAT": 1.7976931348623157e+308, "MINFLOAT": 5e-324, "testHere": "test", "chargeAmps": 16, "poolHeat": false, "poolHeatTrigger": "auto", "Växthuset": { "LYWSD03aa6def": { "x_mqtt_device": { "online": true, "templates": Array(1) ["tasmota_sensor_lyw"] }, "temperature_sensor": { "value": 7.3, "units": "C" }, "humidity_sensor": { "value": 96, "units": "%" }, "battery_power": { "level": 0.75, "since": 1762532173549, "alert_level": 0.5 }, "reactor_entity": {  } }, "Flora1": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 10.3, "units": "C" }, "light_sensor": { "value": 0, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora1_Lux": 0.0001, "Flora2": { "x_mqtt_device": { "online": true, "templates": Array(1) ["my_tasmota_sensor_flora"] }, "temperature_sensor": { "value": 8.4, "units": "C" }, "light_sensor": { "value": 618, "units": "lux" }, "humidity_sensor": { "value": 0, "units": "%" }, "value_sensor": { "value": 0, "units": (null) }, "reactor_entity": {  } }, "Flora2_Lux": 618 }, "Medeltemp": 8.67, "Luftfuktighet": 1.1162790697674418, "EzloDevicesNotResponding": Array(0) [], "prevEzloDevicesNotResponding": Array(0) [], "VeraDevicesNotResponding": Array(0) [], "openLuupWasDown": "No", "Charging": false, "ReactorRestarted": false, "HumOutdoor": 86, "TempOutdoor": 8.82, "Självförsörjande": 0, "Elpris": 178.405, "restartCameraRTSP": false, "lovVecka": false, "VVBsellingHigh": false, "HassElpriser": { "buy_sek": 1.86, "sell_sek": 1.53 }, "chargeNow": false, "alertBLE": true, "ElpriserMedelMedian": "Idag:86/87, Imorgon:78/65", "ChargingPaused": false, "alertElmatare": false, "functions": "Global functions", "functionsDEV": "Global functions", "alarmTest": "1.123" }, "__depth": 0, "__tag": "$global", "__func": { "_compare": [Function (anonymous) (?,?,?)], "fileRead": [Function (anonymous) (?,?,?)], "fileWrite": [Function (anonymous) (?,?,?,?)], "fileExists": [Function (anonymous) (?,?)], "dumpVars": [Function (anonymous) (?)], "strftime": [Function (anonymous) (?)], "format": [Function (anonymous) (?)], "geodist": [Function (anonymous) (?)], "_assign": [Function (anonymous) (?,?,?)], "getEntity": [Function _0x498020 (?,?)], "entity": [Function _0x498020 (?,?)], "$": [Function _0x498020 (?,?)], "matchEntities": [Function (anonymous) (?,?)], "groupMembers": [Function (anonymous) (?,?)], "performAction": [Function _0x498020 (?,?,?,?)], "perform": [Function _0x498020 (?,?,?,?)], "getRule": [Function (anonymous) (?,?)], "isRuleSet": [Function (anonymous) (?,?)], "isRuleEnabled": [Function (anonymous) (?,?)], "alarm": [Function (anonymous) (?)], "getPrices": [Function (anonymous) (?)], "getSlots": [Function (anonymous) (?)], "cheapestHours": [Function (anonymous) (?)], "VVBdayRange": [Function (anonymous) (?)], "getChargingTime": [Function (anonymous) (?)], "getPricesOLD": [Function (anonymous) (?)], "SlotsOLD": [Function (anonymous) (?)], "cheapestHoursOLD": [Function (anonymous) (?)], "getChargingTimeOLD": [Function (anonymous) (?)] }, "__global": { "__lvar": (seen=.__lvar), "__depth": 0, "__tag": "$global", "__func": (seen=.__func), "__global": (seen=.__global), "__alarmhandle": { "alarmTest": Timer(Timer#alarm:alarmTest) }, "__suppress_dependencies": true, "__tree": Array(1) ["alarmTest"] }, "__alarmhandle": (seen=.__global.__alarmhandle), "__suppress_dependencies": true, "__tree": (seen=.__global.__tree) }
                                      [latest-25310]2025-11-07T16:16:51.932Z <Engine:ERR> Engine#1: error evaluating expression alarmTest: [ReferenceError] alarm() can only be used in global expressions [-]
                                      [latest-25310]2025-11-07T16:16:51.933Z <Engine:ERR> Engine#1: expression: alarm(0),
                                      alarm(15),
                                      [latest-25310]2025-11-07T16:16:51.945Z <Engine:INFO> Engine#1: path alarmTest->alarmTest
                                      [latest-25310]2025-11-07T16:16:51.945Z <Engine:CRIT> ReferenceError: alarm() can only be used in global expressions [-]
                                      [latest-25310]2025-11-07T16:16:51.947Z <Engine:INFO> Engine#1 expr alarmTest result changed=true, was "1.123" now (null)
                                      [latest-25310]2025-11-07T16:16:51.948Z <Engine:INFO> Engine#1 notify() expression state change GlobalExpression#alarmTest
                                      [latest-25310]2025-11-07T16:16:51.949Z <Engine:INFO> Engine#1 var alarmTest changed, evaluating dependents {  }
                                      [latest-25310]2025-11-07T16:16:51.949Z <Engine:INFO> Engine#1 update dependencies for alarmTest, which are: Array(0) []
                                      [latest-25310]2025-11-07T16:16:51.959Z <Engine:INFO> Engine#1 evaluating global chargeAmps expression do
                                        Where else are you using that variable, and how?
                                        • CrilleC Online
                                          CrilleC Online
                                          Nowhere, strictly to test the function before I put it in production
                                            sethlampman
                                          • Date/time condition
                                          • Device log?
                                          • Midnight crossing not working in date/time condition (build 25325)
                                            75.7k
                                          • [Solved] Local expression in Rule does not evaluate as they used to do
