  2. Hardware
  3. Home Assistant Connect ZWA-2 & ZBT-2
Hardware
Shelly Wall Display XL
Hardware
Hardware
DIY HomeKey locks via Reactor
Hardware
A recent thread on supporting the ZRC-90 Z-Wave scene controller got me to wonder, what does everybody use and like? I'll start... oh, and no dashboards. I want to hear from you all about dedicated scene controller devices. Dashboards and apps are great to a point, but my experience is that higher WAF is achieved with (a) a dedicated device (b) in a known location (c) with predictable functions and (d) no extra steps to operate (just walk up to it and push a button -- same effort as a light switch/dimmer). She's not wrong. It's a pain to unlock the phone, find the app, open the app, find the device, tap the device, when you can just walk across the room and push a button. Bonus points for something that can be labeled readably (low WAF for stuck-on tape/thermal labels). I have a ZRC-90 and it's great, but it was temperamental to get working on Vera, and wasn't smooth sailing when it made the move to Z-Wave JS either. A couple of include/exclude cycles were needed to get it fully working on both. Since then, I've done a battery change, and while the buttons work as reliably as ever, the device continues to report the old battery level despite having a measurably fresh battery for over a year now. But I would still recommend it. I have a Hank 4-button that is probably the best and most reliable battery-operated scene controller I have ever used. It's small and unobtrusive, so it lives on a lamp base in our living room and controls the room's mood lighting. I'm not sure they're still available. RIP. I just ran across the Minoston MR40Z on Amazon, and I may try one of those. It looks like an installed (in-wall) Decora switch, but the buttons are actually a removable remote that you can pull off the wall and take to the couch. No line power required. Kinda cool. Maybe a good Hank replacement. But, I've never heard of this manufacturer before, and the concern is always "will I be able to buy more/replacements in one/two/five years?" Among the wired controllers, the Zooz ZEN32 seems to be the most popular modern unit. I like it, but the LEDs are too small for my aging eyes to discern their color in daylight -- they are pin-head sized. Four of the five buttons are too small to label, so low WAF. When I started my Z-Wave network, I used the Leviton four-button scene/zone controllers (VRCS4 and VRCZ4), and these are still all over my house. They're glitchy first-gen Z-Wave stuff (Vizia RF+ actually, so compatible but with proprietary features that aren't usable). They're now discontinued for Z-Wave. Leviton's newer units are WiFi, so if I go that route, it's HomeKit via Home Assistant for those. During the pandemic lock-downs, I built a touch-screen scene controller using an Adafruit PyPortal. It had screens with 1 to 8 labeled, colorable soft buttons that could either perform a device function (i.e. publish to MQTT) or take you to another screen, so it was the love-child of scene controller and dashboard. Wife found it agreeable. But it was just a prototype. Memory limitation of the device was an issue because the PyPortal is really an inexpensive teaching device with a big load of Circuit Python overhead, and the graphic display needs a lot of RAM, so it was severely limited. I'm sure it could work out with the right micro and programming closer to the bare metal. Packaging and powering would also need to be addressed. And, at the end of the day, while "cute," it doesn't seem like something I would want to sell with the house if we ended up moving some day. So, I'm interested in what others are doing and using, or more specifically, what your significant others are comfortable with and willing to use.
Hardware
O
Hardware
Z
Hardware
Hardware
LEDVANCE
O
Hardware
Water Flow Meter & Shutoff
B
Hardware
Hardware
Remote light switch
Hardware
ESP32 / ESP8266
Hardware
Hardware
Hardware
PerHP
After a long wait for an updated version of the rather crude and unfinished Z-Way integration to HASS, i'm now looking (reluctantly) in to replacing Z-Way with Z-wave JS.. Mind you this is a big existing network, not a new controller stick.. I threw up a docker for z-wave JS UI, and tried to connect it to the UZB stick.. It loads the whole network from the stick, but the driver keeps restarting? Looking at the logs, I see a lot of Dropping message because the driver is not ready to handle it yet. It seems like the stick just keeps talking like z-way was still listening? This ends up in the driver crashing repeatedly.. Any ideas to how I can get them talking? In the code snippet below, you see the driver restarting with the graphic letters, seemingly while the stick is mid-sentence, or because of ACK timeout... 2022-10-02T19:19:59.664Z CNTRLR received additional controller information: Z-Wave API version: 6 (legacy) Z-Wave chip type: ZW050x node type Controller controller role: primary controller is the SIS: true controller supports timers: false nodes in the network: 1, 5, 6, 10, 11, 12, 13, 14, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 32, 33, 34, 36, 37, 38, 39, 41, 42, 43, 44, 45, 46, 4 7, 48, 52, 55, 69, 70, 71, 73, 74, 75, 77, 78, 79, 81, 82, 83 2022-10-02T19:19:59.765Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated 2022-10-02T19:19:59.766Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated 2022-10-02T19:19:59.767Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated 2022-10-02T19:19:59.768Z CNTRLR [Node 001] [+] [Manufacturer Specific] manufacturerId: 277 2022-10-02T19:19:59.769Z CNTRLR [Node 001] [+] [Manufacturer Specific] productType: 1024 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [+] [Manufacturer Specific] productId: 1 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated 2022-10-02T19:19:59.771Z CNTRLR [Node 001] [+] [Version] firmwareVersions: 5.39 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [Version] sdkVersion: metadata updated 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [+] [Version] sdkVersion: "6.9.0" 2022-10-02T19:19:59.772Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms 2022-10-02T19:19:59.792Z SERIAL » 0x01050006640f97 (7 bytes) 2022-10-02T19:19:59.792Z DRIVER » [REQ] [SetSerialApiTimeouts] payload: 0x640f 2022-10-02T19:19:59.815Z SERIAL « [ACK] (0x06) 2022-10-02T19:19:59.816Z SERIAL « 0x01050106640f96 (7 bytes) 2022-10-02T19:19:59.817Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.177Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:03.178Z DRIVER version 10.2.0 2022-10-02T19:21:03.179Z DRIVER 2022-10-02T19:21:03.179Z DRIVER starting driver... 2022-10-02T19:21:03.199Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:03.212Z DRIVER serial port opened 2022-10-02T19:21:03.213Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:03.229Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.232Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.233Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.234Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.261Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.273Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.274Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.274Z DRIVER loading configuration... 2022-10-02T19:21:03.298Z CONFIG Using external configuration dir /usr/src/app/store/.config-db 2022-10-02T19:21:03.298Z CONFIG version 10.2.0 2022-10-02T19:21:04.284Z DRIVER beginning interview... 2022-10-02T19:21:04.286Z DRIVER added request handler for AddNodeToNetwork (0x4a)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for ReplaceFailedNode (0x63)... 1 registered 2022-10-02T19:21:04.287Z CNTRLR querying controller IDs... 2022-10-02T19:21:04.484Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:04.485Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:04.487Z SERIAL « 0x0123000400511a9f039900b834787d066515a4b79c45bb3af55ea7f6203006010 (37 bytes) 80120c84d 2022-10-02T19:21:04.489Z SERIAL « [DISCARDED] invalid data 0x9ef4 (2 bytes) 2022-10-02T19:21:04.490Z DRIVER Dropping message because it contains invalid data 2022-10-02T19:21:04.490Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:05.488Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i n 100 ms. 2022-10-02T19:21:05.591Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:05.592Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:06.596Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i n 1100 ms. 2022-10-02T19:21:07.698Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:07.699Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:08.717Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200) at Driver.sendMessage (/usr/src/app/node_modules/zwave-js/src/lib/driver/D river.ts:3980:23) at ZWaveController.identify (/usr/src/app/node_modules/zwave-js/src/lib/co ntroller/Controller.ts:713:33) at Driver.initializeControllerAndNodes (/usr/src/app/node_modules/zwave-js /src/lib/driver/Driver.ts:1207:26) at Immediate.<anonymous> (/usr/src/app/node_modules/zwave-js/src/lib/drive r/Driver.ts:1014:16) 2022-10-02T19:21:08.723Z DRIVER destroying driver instance... 2022-10-02T19:21:08.728Z DRIVER driver instance destroyed 2022-10-02T19:21:08.739Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:08.740Z DRIVER version 10.2.0 2022-10-02T19:21:08.740Z DRIVER 2022-10-02T19:21:08.740Z DRIVER starting driver... 2022-10-02T19:21:08.745Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:08.751Z DRIVER serial port opened 2022-10-02T19:21:08.752Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:08.754Z DRIVER loading configuration... 2022-10-02T19:21:08.755Z SERIAL « 0x01080120c84d9ef40138 (10 bytes) 2022-10-02T19:21:08.757Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:08.758Z DRIVER « [RES] [GetControllerId]
Hardware
Hardware
Hardware
Hardware
Hardware
14 Posts 5 Posters 4.7k Views 5 Watching
    I started with Vera Edge, then Plus, and eventually moved my Z-Wave network to Z-Wave.me UZB. Recently, I wanted to experiment with Z-Wave Long Range, so I needed a new controller. I had Home Assistant Connect ZWA-2 on my radar for a while, and I pulled the trigger thanks to Black Friday offers. It was the least complicated migration ever: back up the old, unplug it, stop ZWaveJS, plug in the new controller, and restore the backup—done in a breeze.
    I let the mesh adapt for a couple of days, and the result is impressive: 80% of my devices are now reporting directly to the controller. The Z-Wave network feels crazy fast. My setup includes about 70 devices, and I struggled a lot with Vera. I had missing reports on UZB as well, even if sporadic. In the first days of use, this new setup seems definitely better, and its range is phenomenal. More on that later.
    Since I was at it, I moved my ZigBee network from Hue Bridge (only lights) to Home Assistant Connect ZBT-2 and ZigBee2MQTT, because I wanted to add more ZigBee devices to my network. It seems that all the little weird devices are ZigBee now—I bought a couple of temp/humidity sensors and a ThirdReality Night Light. I'm using it to turn red if the alarm is armed, and as a white night light in the hallway when not armed: very nice to automate with Reactor via Home Assistant.
    The ZigBee mesh is still small at 10 devices, but it will eventually improve.
    Here's a pic of the two antennas: ZWA-2 on the left, ZBT-2 in the center, and a 33cl bottle of water on the right for comparison.
    The ZWA-2 is huge. No wonder it's able to span across three floors and reach the garden with no hops. Mind you, my house is concrete and glass, so not the best in terms of signal. Highly recommended if you want a very powerful Z-Wave antenna, with support for Long Range as well.
      @therealdb I just bought and installed the ZWA-2. You are right, the setup was easiest thing I've done in ages. Of concern was the fact that ZWJS-UI in Home Assistant shows the correct name, etc. but somehow references my old Zooz details.
      Very odd.
      But it seems to be performing fine - I'm slowly moving things over to it from my Hubitat C7 which seems not able to keep itself together of late. Huge delays, switches literally stuttering, etc.
      *Hubitat C-7 2.5.0.159
      Core 2026.7.2
      MSR: latest-26193-8dd8f854
      therealdbT tunnusT 2 Replies Last reply
        Very odd.
        @gwp1 I think you could just rename it
          I recently bricked my Z-wave network somehow where I couldn't add any new devices so I opted to start fresh with the ZWA-2 and was impressed with its range! A lot of my devices talk directly to the controller now which has sped things up considerably as well.
            Now on my Christmas wish list...
              After all these years, no NAK/CAN is a joy to see 🙂
                Very odd.
                @gwp1 I have C-8, but now considering to buy ZWA-2. I think it could speed up the migration if ZWA-2 is added as a secondary controller to Hubitat and then promoted to primary? And after that ZWA-2 is plugged into Home Assistant
                  @tunnus if you could install ZwaveJS on your c8, just backup the nvm, take the file and restore it on your final controller. Easier than you’d think. Secondary controllers promoted to primary are always a mess in my experience.
                    @therealdb I guess only C-8 pro supports z-wave JS
                      @tunnus I see there's a beta for C8. The point is to just take a NVM backup in the format supported by ZwaveJS. after that, it's a breeze to restore it on a new controller, if you have a minimum SDK/fw version, as mentioned in the ZWA release notes.
                      It's wort a try, if you have lots of Zwave devices and unpair/repair them is out of question for you.
                      I'm still on my original ZWave network I built in a previous house 10+ years ago - and that's a testament to the enormous flexibility that Zwave offered me in the last decade.
                        Just on a lark, I took a little distraction trip on the Elevation downloadable (local/manual) backup files. It turns out, the backup files are compressed and encrypted, and I found all the resources for undoing all of that, but it's not productive to do it because the files don't have a copy of the NVM data on them, which is a bummer. The C7 to C8 upgrade process apparently worked because it used cloud-based backup and offered additional "Migrate radio" options for Z-Wave and ZigBee, which presumably pushed the additional radio data up to the cloud specifically for that process; no local option. So no win to be had from the backup files, it appears.
                          @toggledbits are external Zwave controllers supported via USB? that could be another route, as in the old Vera days.
                            @therealdb said in Home Assistant Connect ZWA-2 & ZBT-2:
                            Not an expert here, since I've never really embraced my C7 as a core of my home, but based on a little digging apparently not. The predecessor SmartThings hubs did, but as of the C7, the hub lacks the drivers to support an external Z-Wave stick, only its own internal chip. I'm sure C8 is even more entrenched.
                            Like many of us, I have a hundred+ Z-Wave devices in my home. If there's an upside to a piecewise migration, it's that it isn't Vera. Pairing was always a slow, anxiety-inducing activity on Vera... one device... maybe pairs... Luup restart (90 seconds or more before system is stable enough to proceed)... maybe bricks the Vera... if not, two identical devices end up with different configuration/capability... horrible. When I moved one level of my house to a USB stick last year, I could almost pair devices as quickly as I could walk up to them. You can tell me if the ZWA-2 experience is similar (can you walk it around self-powered or with a USB battery pack and pair devices?). It's not as easy as a migration, but there's always something to be said for starting with a clean slate, and as long as the process is smooth and I get to keep my hair and sanity by the end of it, I'll put up with the time it takes to get there.
                            Going forward, thinking to what may follow, I assume that you can back up the NVM on the ZWA-2?
                              Well, taking a backup inside ZWaveJS is a breeze - and yes, it's very easy to backup (or restore) the NVM on the ZWA-2. In fact, I just restored a backup from UZB to ZWA-2 and I was good to go.
                              I think you'll never need to move it around the house, because the antenna is huge. No problems in pairing devices either, but that was the case with UZB before and I think it's a ZWave JS prerogative in general. It was just plug&play for me, but I understand that if you have to change your logic to match new device IDs it may make sense to start from scratch - time permitting.
                              • therealdbT therealdb referenced this topic on
                                122.3k
