  4. Possible mismatch between binary_sensor in HA and MSR
25 Posts 3 Posters 3.2k Views 3 Watching
    It may. I have similar behavior with other Template sensors being 0/null/off at boot.
    As a defensive measure, I always make the condition to be sustained for at least 10 secs and/or avoid them being evaluated when ha has been restarted for the last 20 secs.
    I rarely use ha templates, so my experience is anecdotal.
      Thanks, helpful input!
        I think you may just filter for unknown and return null. Tell that to my friend Claude 🤣
          @therealdb that would rather force (in this case) all the heating off (or on), wouldn't it?
          I like the idea of a 30 second delay though.
            I don’t know if setting to null it’s better for reactor. @toggledbits here is the best source of truth.
              Of course. I'm not sure what I'd do without him!
              • toggledbitsT Online
                toggledbitsT Online
                #22
                OK. I can't prevent HA from starting up in an undefined state, and the effect that can have on the rules, but @therealdb is spot-on with an approach to dealing with that, since the corrected state usually comes pretty quickly after. Sometimes, you just have to debounce those switches a little.
                Beyond that, there is definitely an opportunity for a race condition and I think I have a good general fix for that. The logs support that cause as well. Testing my updates now. Will likely do a build with the update tomorrow.
                  #23
                  Fabulous!
                  I've actually just put reset delays in the two rules that are triggered. The 'set' is heating on so it's the reset that's a PITA. That should cover it.
                    toggledbitsT Online
                    #24
                    This is just a follow-up to link this conversation to the announcement for the build that addresses it, and expands generally on transient startup/outage states in HA integrations
                      Thanks, installed and working.
                      Although after the first restart there were some virtual switches in HA that were not being accurately reflected in MSR, but I restarted MSR again, and everything looks fine.
                      Thanks again for your help. Next time I'll upload the logs to start with!
                        154.9k
