  4. Possible mismatch between binary_sensor in HA and MSR
25 Posts 3 Posters 3.2k Views 3 Watching
    I don't believe so, It's been used in several places in HA without issue across restarts. I will see if I can double check that however, as it may simply not have been noticed if it's coming up 'off' and immediately tripping to the correct state.
      OK I've just done some digging: When HA restarts, all three sensors
      sensor.rachel_primary_region
      Go 'unknown'
      Someone Home (fairly logically) goes 'Off'
      The period of 'Unknown' is about 5-10 seconds before the correct status is realised.
      Here's the data from the last restart
      binary_sensor.someone_home	unknown	2026-05-19T12:06:55.461Z
      binary_sensor.someone_home	off	2026-05-19T12:07:04.582Z
      binary_sensor.someone_home	on	2026-05-19T12:07:11.505Z
      TIA
        It may. I have similar behavior with other Template sensors being 0/null/off at boot.
        As a defensive measure, I always make the condition to be sustained for at least 10 secs and/or avoid them being evaluated when ha has been restarted for the last 20 secs.
        I rarely use ha templates, so my experience is anecdotal.
          Thanks, helpful input!
            I think you may just filter for unknown and return null. Tell that to my friend Claude 🤣
              @therealdb that would rather force (in this case) all the heating off (or on), wouldn't it?
              I like the idea of a 30 second delay though.
                I don’t know if setting to null it’s better for reactor. @toggledbits here is the best source of truth.
                  Of course. I'm not sure what I'd do without him!
                  • toggledbitsT Online
                    toggledbitsT Online
                    #22
                    OK. I can't prevent HA from starting up in an undefined state, and the effect that can have on the rules, but @therealdb is spot-on with an approach to dealing with that, since the corrected state usually comes pretty quickly after. Sometimes, you just have to debounce those switches a little.
                    Beyond that, there is definitely an opportunity for a race condition and I think I have a good general fix for that. The logs support that cause as well. Testing my updates now. Will likely do a build with the update tomorrow.
                      #23
                      Fabulous!
                      I've actually just put reset delays in the two rules that are triggered. The 'set' is heating on so it's the reset that's a PITA. That should cover it.
                        toggledbitsT Online
                        #24
                        This is just a follow-up to link this conversation to the announcement for the build that addresses it, and expands generally on transient startup/outage states in HA integrations
                          Thanks, installed and working.
                          Although after the first restart there were some virtual switches in HA that were not being accurately reflected in MSR, but I restarted MSR again, and everything looks fine.
                          Thanks again for your help. Next time I'll upload the logs to start with!
                            154.9k
