Reactor buld 26137
If you are upgrading to this build from 26011 or earlier, please read the cautions for build 26116!
- Rules: fix an error where a Variable Value condition in a constraint may not be reevaluated correctly when the variable changes.
- Rules UI: if a Rule State condition uses the changes operator with terminal values, make sure those are shown on the detail card.
- Rule Editor: when a new local variable/expression is added to the rule currently being edited, make sure all expression selectors in any Variable Value conditions shown are updated so that the new variable can be selected immediately (a bug was causing some to be missed).
- HassController: Bless HA to 2026.5.2
Reactor build 26140
- HassController: Address a race condition that can occur when a large number of devices is initialized at the same time that HA is starting up (i.e. during the connect/reconnect and entity inventory phase while HA is still starting integrations). The race condition could cause a state change for an integration's entity to be missed during inventory. This is particular to integrations that set their device/entity states to null or "unavailable* during startup rather than preserving the last known state and only changing it after initialization succeeds or fails.
- HubitatController: Add
sinceproperty tox_hubitat_pushableand family for improved button press detection. - HassController: Bless HA to 2026.5.3
General Advisory
Users of HassController (and some other controllers as well, like OWMController for weather) often rely on cloud-based/Internet-dependent integrations to drive entities. There is no documented standard for how an HA integration should behave at startup, before it connects and authenticates with its mother ship; nor is there a standard for when it loses its connection to the mother ship and has to reconnect. Some integrations will preserve the last-known state of their entities for a while during these (re)connections, and some don't. It's kind of up to us as consumers of these integrations to figure this out and adjust our Rules accordingly.
While the fix in this build can address the issue of missing a state change during a lengthy initialization, it doesn't address how rules might behave in the face of these state transitions when they occur. If, for example, you write a condition "John is home" that tests the John presence entity attribute for the value "home", the transition to "unavailable" during integration startup could easily cause your logic to perform its "not home" behaviors. There are a couple of ways you can hedge against these spurious/transient states:
- If the attribute value exposes "unavailable" as a state, test for it. I do this a lot. For example, a not-home test may be written as an AND group with
value <> "home" AND value <> "unavailable"or perhaps more simplyvalue NOT IN home,unavailable, rather than testing for equality to the sole valuenot_home. Again, whether or not "unavailable" is produced as a state and at what time/under what conditions is integration-dependent, so you will need to experiment. See further comments about integration states below. - Use the delay reset or sustained for condition option delays to dampen response to state changes. In this case, your rule would delay for some acceptable period before running its reaction...
value == "not_home" sustained for 60 secondsis likely in most cases to be sufficient to allow the integration to get up and running and provide a "real" state rather than locking your wife in a dark house with no heat running and an armed alarm system (low WAF). Be careful, however; this doesn't address how the integration behaves during sustained outages of your Internet connection or their cloud services. Sometimes adding additional checks that the integration is healthy is necessary.
Recent versions of Reactor have introduced entities for integrations. For example:
The top highlighted line shows the state of a particular integration. You can use these entities/attributes as another test of the validity of other attributes you need to test (e.g. when the integration state is other than "loaded", the values are not to be trusted/acted upon). The lower highlighted line is provided by the integration itself and provides another data point on overall health of the reported attributes.
And just so I've said it... you have to test your entire automation under some terrible conditions. Some day when everyone is out of the house, unplug your Internet router and watch how your automations behave. Chances are you'll find some interesting and not-so-obvious behaviors.
Reactor build 26143
- Reaction Editor: fix an issue where non-group actions could not be cloned.
- Docker images: add
pingcommand to underlying minimal OS packages. - HTTP Request Action: a bug in an underlying package dependency caused digest authentication to ignore a server's suggested/supported digest algorithm. A workaround has been put in place and tested successfully against servers requiring SHA-256 and SHA-512-256, in addition to the now disfavored MD5.
- HassController: Bless HA to 2026.5.4
Reactor build 26150
- A new Router notification method is now available. This method allows a single notification action to send a message to multiple notification targets. Configurable routes allow the selection and filtering of messages for different destinations. See docs
- In support of the new Router notification method, configured Notifier profiles other than
defaultare considered children ofdefault. If a configuration value is not specified in such a profile, the value will be inherited from thedefaultprofile. This allows, for example, the default profile for SMTP to contain the host and authentication information, while additional profiles may contain only different recipient addresses — the additional profiles will use the default profile's host/auth info to connect to the same mail server, without the need to repeat that information in each profile. If an additional profile needs to connect to a different mail server, it may specify its own host and authentication parameters as before. - DynamicGroupController: improve response to changes in groups using
filter_expressionin configuration; - Expressions: fix an error in the
runReaction()function that may cause it to crash on an attempted dereference through undefined. - Make the system more resilient to startup failures caused by hard errors in configuration files. When a (syntactically) valid configuration file is successfully loaded, it is copied to a last-known-good shadow file in the
configdirectory. If the YAML configuration is later edited and contains errors that would prevent it being loaded, Reactor will load the last-known-good configuration, log the error, and display an alert in the Current Alerts widget on the Status page. The alert will clear itself when the file is fixed and later successfully loaded. To be clear, "valid" in this context means parseable (syntactically correct YAML). It does not mean that the keys and values given in the configuration will do what you expect/want or contain values or structures that Reactor can't recognize. - Fix a compatibility issue with node version 18. This version of node is only supported in the
armv7ldocker image (for 32-bit Raspberry Pis). - A new backup script
backup_reactor_gfs.shhas been added to thetoolsdirectory; this script uses the grandfather-father-son backup strategy. If run daily, it will keep 30 daily backups, monthly backups (i.e. the first daily backup of each month), and quarterly backups (i.e. the first monthly backup of each quarter). Command line options suppress the backups of thelogsdirectory and/or the transient/temporary state data for smaller backup size.
Reactor build 26174
IF YOU ARE UPGRADING FROM A REACTOR BUILD EARLIER THAN 26116, PLEASE READ THE RELEASE NOTES FOR THAT BUILD. THERE WERE IMPORTANT CHANGES MADE ON THAT BUILD THAT MAY AFFECT HOW YOU BACK UP AND RESTORE REACTOR DATA.
NOTE TO DEVELOPERS: An upcoming build of Reactor will be published after code base conversion to ES modules. Current Reactor core modules are CommonJS (CJS). Many dependent packages are only getting new features in their ESM versions (i.e. the world is moving to ESMs), so Reactor must follow. Instructions for converting your Reactor Controller and Plugin subclasses are published in the Building Controllers page of the Reactor documentation (under Developer Info). If you send me a DM in this community, I can send you an early release of ESM Reactor for your development and testing. This 26174 build is still CJS-based, so your conversion applies only to that future Reactor release and beyond.
- Entities list: fix a bug in entity filtering where a group filter would be ignored when an entity's name matched the name filter (both should be enforced).
- Hubitat: Fixed a problem where a scene controller button would report tapped at every Reactor startup.
- HTTP API: A new endpoint
/api/v1/notifyhas been added so that external applications can use Reactor's configured notifiers to send messages. docs - VirtualEntityController: New
ping-driven binary sensor reflects the (ICMP) reachability of a target network host. see docs - VirtualEntityController: Virtual entities may now be added to system room/location groups by including
room: <string>in the virtual entity configuration. - HassController: Bless HA to 2026.6.4
Reactor build 26177
- Notify via Telegram: fix application of default chat_id when not specified on individual notification action.
- Hubitat: fix an error in handling data POST from MakerAPI (affects house modes, HSM)
Nodejs v24.17 Not Compatible
Users on bare-metal installs... a security fix in nodejs v24.17 inadvertently broke a dependency of Reactor. This version of nodejs is therefore not compatible with Reactor. If you are using it, please upgrade to v24.18.
Reactor build 26193
BARE-METAL USERS: nodejs v24.17 had a regression/injection that breaks HTTP connections, which has broad negative effect in Reactor. This version specifically is excluded from support, and users on that version are advised to upgrade to v24.18 (or higher).
BREAKING CHANGE: I'm guessing this will affect very few people, maybe none: the
include_attributesselector for DynamicGroupController now requires that all listed attributes match when tested against an entity. Previously, if any listed attribute matched, the entity would be added to group eligibility. This forced users to use a filter expression if all attributes had to be matched together, which carries a greater performance impact and has other side-effects. The old behavior can be obtained by separating each attribute under its owninclude_attributesselector individually.- DynamicGroupController: the
include_attributesselector now requires all listed attributes to match, rather than any of the listed attributes, for the entity to be selected. See note above. - A new
lexp-cli.jsutility in thetoolssubdirectory allows users to experiment with lexp expressions outside of Reactor. This tool doesn't have Reactor context, so functions likegetEntity()andisRuleSet()are not available; nor are Reactor's global variables. It is strictly an environment to help with familiarization. - Reaction Editor: when editing the Set or Reset reaction of a Rule, the Copy From... button will now list the contra-reaction at the top of the list, making it easier to find and copy the reaction within the current Rule.
- UI: The condition and action editors now support a right-click context menu on conditions and actions. The menu provides copy-paste of individual conditions and actions. Other menu actions are added where they make sense. Thank @therealdb for this power-user feature!
- UI: On dialogs, the Enter key will not perform any action if a modal dialog contains two or more buttons (i.e. where the meaning of Enter is ambiguous).
- nodejs version 26 is now explicitly supported, with v26.4.0 being the current version used for development (testing still occurs on v22 and v24).
- HassController: Bless HA to 2026.7.2
Reactor build 26193
@toggledbits said in Reactor (Multi-System/Multi-Hub) Announcements:
UI: The condition and action editors now support a right-click context menu on conditions and actions. The menu provides copy-paste of individual conditions and actions. Other menu actions are added where they make sense. Thank @therealdb for this power-user feature!Oh My! That is very cool indeed!
Reactor build 26214
ALL USERS: This build is strictly to address a problem for bare-metal installs only running on nodejs v22.0 through v22.11. Use
node -vto show your version, or look at the startup messages inreactor.log. If your nodejs is v22.12.0 or higher, or you are running a docker image, you do not need to update to this build.- Workaround for module load problem in nodejs versions from 22.0 through 22.11.
Only a bare-metal package is distributed for this build. The latest docker images are still build 26193.
Reactor build 26221
SECURITY! - BARE-METAL USERS: It is always recommended that you update package dependencies whenever installing Reactor updates. After unpacking the Reactor archive, go into the
reactordirectory (whereapp.jslives) and runnpm run depsto update package dependencies. This is particularly important to address security updates for many packages.- DynamicGroupController: Fix an issue where a
filter_expression-controlled group would miss an attribute update. - Engine/Reactions: The log level for the result of Group and While action predicates (i.e. the conditions) has been raised to INFO (4) from DEBUG0 (5). This may help users more easily identify logic bugs in their actions without the need to change the Engine log level (the Engine is dauntingly verbose even at DEBUG0 level).
- HassController: Bless HA to 2026.7.4
Reactor build 26284
NOTE: Your first startup on this build may log some odd-looking errors while rebuilding entities from various controllers, and that's expected. A second restart should be noticeably cleaner.
- New Access Control settings for operation behind reverse proxies. These new settings should enable easier reverse proxy configuration while maintaining local access (i.e. access UI via LAN). DISCLAIMER: Opening your system/network to a public IP address is not something to be trifled with, and if you don't know what you're doing, you will likely regret it at some point. Proceed entirely at your own risk. See further discussion here.
- HassController: now recognizes HA's
fanservice with capabilities (including new capabilities:preset_mode,speed,directionandoscillate) extended by matching the source device's advertised supported features (i.e. not all capabilities will be present on all devices). - HassController: extend
media_sourcecapability tomedia_playerdevices that support it. - HubitatController: Improve behavior when new devices are added to the hub and published by Maker API. It should now not be necessary to restart Reactor to have the entity fully configured and responsive.
- HubitatController: Default polling action is now Refresh (was Poll). On newer firmware, this more reliably produces a device change message when the state has updated (e.g. a switch without instant status was operated manually). Polled devices now allow an
actionconfig to override the default action. - HassController: Store HA
unique_idandplatformon extended attributes (e.g. for use in filtering). - HassController: Bless HA to 2026.10.1
Reactor build 26287
- Tighten tests for proxied requests so that proxy-handling behavior isn't triggered when proxy configuration has not been established.
Reactor build 26298
SECURITY: Recent discovery of compromised intermediate certificates has been addressed with updated docker images for arm64 and amd64/x86_64. Bare-metal Reactor users are advised to upgrade their node install to at least (within each major version) 22.23.4, 24.22.1, or 26.12.1, and further update their CA certificates on the underlying operating system, as well as any affected packages (e.g. potentially python, OpenSSL, curl, wget, etc.). Any of the popular AIs should be able to provide useful specific guidance if you adequately describe your system configuration. Note that armv7l images cannot be fully patched at this time due to limitations in underlying packages. Upgrading to 64-bit is currently the only path.
- Security: Reactor Access Control now supports Multi-factor (Two-Factor) Authentication. Configuring MFA is highly recommended for users granting access to Reactor from outside their LANs (e.g. via reverse proxy or tunnel). See docs
- Security: Reactor Access Control now blocks host IP addresses for consecutive login failures (configurable, default: 4 failures within 3 hours gets blocked for 48 hours). See docs
- Security: docker images have an updated node version to address recent discovery of compromised eMudhra intermediate certificates, and others. The image OS certificate store has also been updated accordingly. ref ref ref
- HubitatController: New
x_hubitat_sys.restartandx_hubitat_sys.rebootactions (on system entity); see docs - HassController: Bless HA to 2026.10.4
Reactor build 26318
- HubitatController: Fix hub login failure in hub firmware 2.5.3 and above.
- Security: New Access Control configuration elements
bypass_blockingandbypass_mfa. The former prevents IP addresses with multiple authentication failures from being blocked; the latter allows login without MFA whenrequire_mfa: trueis configured. Both expect an array of CIDR host or subnet addresses. See docs - DynamicGroupController: Prevent a group from having itself as a member.
- HassController: Bless HA to 2026.11.1
