  4. MSR in Alpine Docker
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
32 Posts 7 Posters 14.4k Views 7 Watching
    wrote on last edited by PerH
    I have a docker running smoothly now, thought i'd share it. (and BTW, it looks awesome, Patrick!)
    So far i've only opened 8111, and /config as volume. Mabye the full /reactor folder should be exposed for easy updating?
    docker compose:
    version: "3.9"
    services:
      MSR:
        container_name: MSR
        restart: always
        image: perhu/msr-alpine:latest
        ports:
          - "8111:8111"
        networks:
          HAnett:
            ipv4_address: 192.168.0.8
        volumes:
          - type: bind
            source: /etc/localtime
            target: /etc/localtime
          - type: volume
            source: MSR-config
            target: /etc/reactor/config
          - type: volume
            source: MSR-storage
            target: /etc/reactor/storage
    logging:
            driver: "json-file"
            options:
                max-file: "5"
                max-size: 10m
    networks:
        HAnett:
            driver: bridge
            ipam:
                    - subnet: 192.168.0.0/16
                      gateway: 192.168.0.254
    volumes:
      MSR-config:
      MSR-storage:
    dockerfile for those who want to modify the image: (this works if you have unzipped MSR zip file to the same folder as the dockerfile)
    FROM alpine:latest
    COPY /reactor/. /etc/reactor/
    RUN apk add --update nodejs npm && cd /etc/reactor \
            && npm install --loglevel error --no-save \
            && cp dist-config/* config/
    VOLUME ["/etc/reactor/config"]
    VOLUME ["/etc/reactor/storage"]
    EXPOSE 8111
    CMD ["/bin/sh"]
    WORKDIR /etc/reactor
    CMD ["node", "/etc/reactor/app.js"]
    EDIT: 20210307 - updated with localtime bind
      Per, there's also a storage folder that should be a volume or bind mount.
        Added. (havent uploaded new image to dockerhub yet though).
          @LibraSun asked about MSR docker on synology in another thread. I don't know whats special on synology as i don't hvae one, but this is how you can do it on other linux systems (and please correct me if something's wrong in the write-up, im still learning here!):
          Start by downloading reactor from the bugtracker place and unzip it to an appropriate folder on the NAS called "/.../reactor/"
          Edit your /reactor/config/reactor.yaml with the appropriate settings
          In the same folder you have the /reactor/ sub folder, create a textfile called "dockerfile" (no extension)
          paste this in:
          FROM alpine:latest
          EXPOSE 8111
          CMD ["/bin/sh"]
          save & close, and then type docker build -t your/image:version .
          Then you can make a docker-compose like mine in the above post, or you can use run command:
          docker run -p 8111:8111 your/image:version
          Note: @toggledbits prefers to keep control over MSR distribution through the alpha/beta testing, so publishing on dockerhub is not an option. You can have private repositories there as well in order to transfer an image between machines easily.
            I'm just putting finishing touches on the first Synology container. I'm going with the approach that it can be configured and started from the UI, which helps with the var data and config. I had to add a way to redirect (or really, prefix) those directories, as well as some additional initializations (which I'm working on at this moment). I'll probably still make composer an option for folks that are OK with command line into their NAS. Once the container has been created, it's low-maintenance. My Dockerfile appears below, for your review (proof-read/code check, if you like, I'm new to docker).
            FROM node:alpine
            # Where Reactor lives in the container
            ENV REACTOR_HOME="/opt/reactor"
            # Container stores all variable data under /var
            ENV REACTOR_DATA_PREFIX="/var/reactor"
            # ENV NODE_ENV=production
            # Default port
            ENV PORT=8111
            # Creates directory if doesn't exist
            WORKDIR ${REACTOR_HOME}
            LABEL description="Reactor (Multi-System)"
            LABEL version="###BUILDVERSION###"
            LABEL copyright="Copyright (C) 2020,2021 Patrick H. Rigney, All Rights Reserved"
            LABEL cicd="reactor"
            COPY reactor/app.js ./
            COPY reactor/client ./client/
            COPY reactor/common ./common/
            COPY reactor/dashboard ./dashboard/
            COPY reactor/dist-config ./dist-config/
            COPY reactor/INSTALL.md ./
            COPY reactor/LICENSE.md ./
            COPY reactor/package.json ./
            COPY reactor/reactorui ./reactorui/
            COPY reactor/server ./server/
            WORKDIR ${REACTOR_HOME}/docs/html
            COPY reactor/docs/html ./
            RUN rm -rf node_modules && npm install --loglevel error --no-save
            WORKDIR ${REACTOR_DATA_PREFIX}
            VOLUME ${REACTOR_DATA_PREFIX}
            EXPOSE ${PORT}
            STOPSIGNAL SIGTERM
            HEALTHCHECK --interval=5m --timeout=15s CMD curl -f http://localhost:${PORT}/api/v1/alive || exit 1
            CMD ["node", "app.js"]
                OK. Let's see how this does in your hands. I've installed and uninstalled 3-4 times and it seems OK. In the bug tracker, go to #58, in the notes you'll find a download link and draft installation instructions. You can use the "monitor" function to follow that PR (emails you when things are posted--might get chatty with a lot of people in there, though). Please use that PR for reporting install-related issues.
                K 1 Reply Last reply
                  K Offline
                  K Offline
                  kfxo
                  @toggledbits said in MSR in Alpine Docker:
                  This loads up nicely. Running unconfigured right now. I will transfer over my configs later and test it out.
                    nice! i'll try this later. node:alpine should be a better staring image for sure.
                    Only question i have is if you should nest more of the commands together to reduce number of layers. This is said to reduce both build time and image size.
                    i think that can be done with the copying the full reactor folder in, and then distribute the files (like you do with the multiple COPY lines) with a RUN command having several nested "cp" commands.
                      just have to mention for all non-synology docker users, Portainer is a very nice UI alternative for playing with dockers without the "dreaded" command line approach. 🙂
                      • K kfxo
                        K Offline
                        K Offline
                        kfxo
                        @kfxo said in MSR in Alpine Docker:
                        Just an update, I copied over config and storage directories to the mounted docker volume and Reactor would not start until I also created a 'logs' directory in the mounted docker volume. All looked well after that but going to continue to run it on my Debian VM for now.
                          It's supposed to (a) notice those directories and missing and create them, and (b) if (and only if) it created the config directory, copy the contents of the containers dist-config into config as a starting point. Seems to be fine on Linux, somehow not working in the container, I guess. Time to go digging...
                            Quick note about base image, I've built my image using both node:alpine and alpine:latest as base image, and the former ended up being approx. 50mb bigger.
                            I did however not do the rm -rf node_modules from your dockerfile (as i didn't see why it was there), that may be the difference?
                            • parkercP Offline
                              parkercP Offline
                              parkerc
                              Hi, I’m keen to try the Docker version on my QNAP, but I can’t find the specific guide on https://reactor.toggledbits.com/docs/Installation/ , it suggests under the Raspberry Pi install section, “If you prefer to use Docker, see the separate procedure below.’ but nothing seems to be listed ?
                                There hasn't been published a docker for this yet, I think @toggledbits wants to go through the beta phase first, as there may be many updates in a short time-frame which would have to be maintained in the docker.
                                You can follow the procedure i posted 5 days ago (in this thread) to make your own docker.
                                • D Offline
                                  D Offline
                                  d868
                                  I'm just starting to look at ways to migrate away from Vera and just started working on a Home Assistant setup so I'd also love to have a go at testing this out in Docker on a QNAP but I don't really want to have to SSH into the NAS to do the docker compose, etc. I have only ever used the docker hub to add docker images but it looks like it's possible to use the QNAP container station to create a docker image locally but the steps you posted a few days ago in the thread don't seem to be in the format that the GUI needs, or I'm doing something wrong. If there aren't any QNAP gurus around I'll wait for something to come up.
                                    The code above is for dockerfile. That is for making images, while docker-compose sets up containers based on images you make, or is found on docker hub.
                                    No idea how QNAP works, you say it has input for dockerfile code? if so, the code above should work (the dockerfile code, not the compose!), its very standardized.. But unless you make the image yourself i guess you'll have to wait with MSR in docker until there is an official MSR image.
                                    • parkercP Offline
                                      parkercP Offline
                                      parkerc
                                      Hi @d868, other than creating our own image, we’ll have to wait until one’s approved and then published on Docker Hub.
                                      If it helps you I’m planning to do the same thing with MSR as I did with Home Assistant, and create a Container Station API build guide.
                                      Jan 23, 2021
                                      QNAP - Installation via Container Station’s API
                                      Rather than use the UI to build your Home Assistant Docker container, you can do it all via the command line using its API. https://qnap-dev.github.io/container-station-api/ Here’s how I did it… On any device, access it via the command line, In this situation, I’m doing it on the QNAP itself...
                                      D 1 Reply Last reply
                                      • parkercP parkerc
                                        Jan 23, 2021
                                        D Offline
                                        D Offline
                                        d868
                                        @parkerc thanks. I'm trying to avoid doing anything by command line if I can, but if you do end up creating a guide I'll see how I go with it. In the meantime I'll have a bit of a play around with Container station to see if I can get the syntax right for creating it myself via the GUI.
                                          Just updated the first post.
                                          I just noticed that Reactor time wasn't correct, and its probably because of daylight savings time here in Norway.
                                          I put a Bind mount for /etc/localtime in the docker-compose, and noW it will follow the host machines time.
                                            163.3k
