  4. MSR in Alpine Docker
32 Posts 7 Posters 13.3k Views 7 Watching
  • K kfxo
    @toggledbits said in MSR in Alpine Docker:
    OK. Let's see how this does in your hands. I've installed and uninstalled 3-4 times and it seems OK. In the bug tracker, go to #58, in the notes you'll find a download link and draft installation instructions. You can use the "monitor" function to follow that PR (emails you when things are posted--might get chatty with a lot of people in there, though). Please use that PR for reporting install-related issues.
    This loads up nicely. Running unconfigured right now. I will transfer over my configs later and test it out.
    K Offline
    K Offline
    kfxo
    @kfxo said in MSR in Alpine Docker:
    Just an update, I copied over config and storage directories to the mounted docker volume and Reactor would not start until I also created a 'logs' directory in the mounted docker volume. All looked well after that but going to continue to run it on my Debian VM for now.
      It's supposed to (a) notice those directories and missing and create them, and (b) if (and only if) it created the config directory, copy the contents of the containers dist-config into config as a starting point. Seems to be fine on Linux, somehow not working in the container, I guess. Time to go digging...
        Quick note about base image, I've built my image using both node:alpine and alpine:latest as base image, and the former ended up being approx. 50mb bigger.
        I did however not do the rm -rf node_modules from your dockerfile (as i didn't see why it was there), that may be the difference?
        • parkercP Offline
          parkercP Offline
          parkerc
          Hi, I’m keen to try the Docker version on my QNAP, but I can’t find the specific guide on https://reactor.toggledbits.com/docs/Installation/ , it suggests under the Raspberry Pi install section, “If you prefer to use Docker, see the separate procedure below.’ but nothing seems to be listed ?
            There hasn't been published a docker for this yet, I think @toggledbits wants to go through the beta phase first, as there may be many updates in a short time-frame which would have to be maintained in the docker.
            You can follow the procedure i posted 5 days ago (in this thread) to make your own docker.
            • D Offline
              D Offline
              d868
              I'm just starting to look at ways to migrate away from Vera and just started working on a Home Assistant setup so I'd also love to have a go at testing this out in Docker on a QNAP but I don't really want to have to SSH into the NAS to do the docker compose, etc. I have only ever used the docker hub to add docker images but it looks like it's possible to use the QNAP container station to create a docker image locally but the steps you posted a few days ago in the thread don't seem to be in the format that the GUI needs, or I'm doing something wrong. If there aren't any QNAP gurus around I'll wait for something to come up.
                The code above is for dockerfile. That is for making images, while docker-compose sets up containers based on images you make, or is found on docker hub.
                No idea how QNAP works, you say it has input for dockerfile code? if so, the code above should work (the dockerfile code, not the compose!), its very standardized.. But unless you make the image yourself i guess you'll have to wait with MSR in docker until there is an official MSR image.
                • parkercP Offline
                  parkercP Offline
                  parkerc
                  Hi @d868, other than creating our own image, we’ll have to wait until one’s approved and then published on Docker Hub.
                  If it helps you I’m planning to do the same thing with MSR as I did with Home Assistant, and create a Container Station API build guide.
                  Jan 23, 2021
                  QNAP - Installation via Container Station’s API
                  Rather than use the UI to build your Home Assistant Docker container, you can do it all via the command line using its API. https://qnap-dev.github.io/container-station-api/ Here’s how I did it… On any device, access it via the command line, In this situation, I’m doing it on the QNAP itself...
                  D 1 Reply Last reply
                  • parkercP parkerc
                    Jan 23, 2021
                    D Offline
                    D Offline
                    d868
                    @parkerc thanks. I'm trying to avoid doing anything by command line if I can, but if you do end up creating a guide I'll see how I go with it. In the meantime I'll have a bit of a play around with Container station to see if I can get the syntax right for creating it myself via the GUI.
                      wrote on last edited by PerH
                      Just updated the first post.
                      I just noticed that Reactor time wasn't correct, and its probably because of daylight savings time here in Norway.
                      I put a Bind mount for /etc/localtime in the docker-compose, and noW it will follow the host machines time.
                      • B Offline
                        B Offline
                        Buxton
                        Hi Patrick,
                        Do you have a compose file that you're happy with. I'd like to try this on my HA machine which has several other containers, and runs on an Intel Atom with 4gb ram.
                        • B Offline
                          B Offline
                          Buxton
                          To those dreading ssh into their machine, try using WinSCP and setting the file editor to Notepad ++. Makes editing linux files a breeze and you can set up your folder structures and permissions with the winscp gui.
                          • B Buxton
                            Hi Patrick,
                            #23
                            @buxton said in MSR in Alpine Docker:
                            Here's what I last used:
                            version: '3'
                            services:
                              web:
                                container_name: reactor
                                environment:
                                image: toggledbits/reactor:latest
                                restart: always
                                network_mode: "bridge"
                                expose:
                                  - 8111
                                ports:
                                  - 8111:8111
                                volumes:
                                  - .data:/var/reactor
                                tmpfs: /tmp
                            If you're on an RPi (or really anything, but RPi was a breeze), setting up Samba and being able to open the files directly on the host via the share is a great time saver, too. Choices.
                            • PerHP PerH
                              @perh said in MSR in Alpine Docker:
                              and not it will follow the host machines time.
                              @PerH I'm re-reading this... the bind mount fixes it, right? You meant "now"?
                                Yes.
                                My MSR Container clock was one hour off, and the bind fixed it. 🙂
                                • B Offline
                                  B Offline
                                  Buxton
                                  Ok got the following error:
                                  Pulling MSR (toggledbits/reactor:latest)...
                                  ERROR: pull access denied for toggledbits/reactor, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
                                    It's not a published image. The only image I make available is for Synology NAS x86. You'll need to build your own image using the generic package download (which you can get from the download button in the MantisBT bug tracker).
                                    Have you built docker images before?
                                    • B Offline
                                      B Offline
                                      Buxton
                                      Yes, I've built some simple ones. I'll need a Mantis login though. Let me know what kind of info you need to set up my credentials.
                                        OK. Just PM me your full name and email address.
                                          #30
                                          I'm happy to see an official docker image for MSR!
                                          Just thought i'd share my docker-compose.yaml, which is only different in that i use docker volume instead of bind to host folder
                                          Not sure if it's better, but i've done this to all dockers in my system.
                                          This came up working well immediately, next is to stop the container and add my storage and config data. 🙂
                                          version: "3.9"
                                          services:
                                            MSR:
                                              container_name: MSReactor
                                              restart: always
                                              ports:
                                                - "8111:8111"
                                              networks:                            # Optional for use of static IP inside the docker network.
                                                HAnett:                            # You could replace this and the subsequent lines with " network_mode: "bridge" "
                                                  ipv4_address: 192.168.0.8
                                              volumes:
                                                - type: volume
                                                  source: MSR
                                                  target: /var/reactor
                                                - "/etc/localtime:/etc/localtime:ro"
                                              environment:
                                                - TZ=Europe/Oslo
                                                - REACTOR_DATA_PREFIX=/var/reactor
                                              tmpfs: /tmp
                                              logging:
                                                  driver: "json-file"
                                                  options:
                                                    max-file: "5"
                                                    max-size: 2m
                                          networks:    #Optional
                                              HAnett:
                                                  driver: bridge
                                                  ipam:
                                                          - subnet: 192.168.0.0/16
                                                            gateway: 192.168.0.254
                                          volumes:
                                            MSR:
                                            343
                                            151.2k
