  4. MSR in Alpine Docker
32 Posts 7 Posters 13.3k Views 7 Watching
  • parkercP parkerc
    Hi @d868, other than creating our own image, we’ll have to wait until one’s approved and then published on Docker Hub.
    If it helps you I’m planning to do the same thing with MSR as I did with Home Assistant, and create a Container Station API build guide.
    Jan 23, 2021
    QNAP - Installation via Container Station’s API
    Rather than use the UI to build your Home Assistant Docker container, you can do it all via the command line using its API. https://qnap-dev.github.io/container-station-api/ Here’s how I did it… On any device, access it via the command line, In this situation, I’m doing it on the QNAP itself...
    D Offline
    D Offline
    d868
    @parkerc thanks. I'm trying to avoid doing anything by command line if I can, but if you do end up creating a guide I'll see how I go with it. In the meantime I'll have a bit of a play around with Container station to see if I can get the syntax right for creating it myself via the GUI.
      wrote on last edited by PerH
      Just updated the first post.
      I just noticed that Reactor time wasn't correct, and its probably because of daylight savings time here in Norway.
      I put a Bind mount for /etc/localtime in the docker-compose, and noW it will follow the host machines time.
      • B Offline
        B Offline
        Buxton
        Hi Patrick,
        Do you have a compose file that you're happy with. I'd like to try this on my HA machine which has several other containers, and runs on an Intel Atom with 4gb ram.
        • B Offline
          B Offline
          Buxton
          To those dreading ssh into their machine, try using WinSCP and setting the file editor to Notepad ++. Makes editing linux files a breeze and you can set up your folder structures and permissions with the winscp gui.
          • B Buxton
            Hi Patrick,
            #23
            @buxton said in MSR in Alpine Docker:
            Here's what I last used:
            version: '3'
            services:
              web:
                container_name: reactor
                environment:
                image: toggledbits/reactor:latest
                restart: always
                network_mode: "bridge"
                expose:
                  - 8111
                ports:
                  - 8111:8111
                volumes:
                  - .data:/var/reactor
                tmpfs: /tmp
            If you're on an RPi (or really anything, but RPi was a breeze), setting up Samba and being able to open the files directly on the host via the share is a great time saver, too. Choices.
            • PerHP PerH
              @perh said in MSR in Alpine Docker:
              and not it will follow the host machines time.
              @PerH I'm re-reading this... the bind mount fixes it, right? You meant "now"?
                Yes.
                My MSR Container clock was one hour off, and the bind fixed it. 🙂
                • B Offline
                  B Offline
                  Buxton
                  Ok got the following error:
                  Pulling MSR (toggledbits/reactor:latest)...
                  ERROR: pull access denied for toggledbits/reactor, repository does not exist or may require 'docker login': denied: requested access to the resource is denied
                    It's not a published image. The only image I make available is for Synology NAS x86. You'll need to build your own image using the generic package download (which you can get from the download button in the MantisBT bug tracker).
                    Have you built docker images before?
                    • B Offline
                      B Offline
                      Buxton
                      Yes, I've built some simple ones. I'll need a Mantis login though. Let me know what kind of info you need to set up my credentials.
                        OK. Just PM me your full name and email address.
                          #30
                          I'm happy to see an official docker image for MSR!
                          Just thought i'd share my docker-compose.yaml, which is only different in that i use docker volume instead of bind to host folder
                          Not sure if it's better, but i've done this to all dockers in my system.
                          This came up working well immediately, next is to stop the container and add my storage and config data. 🙂
                          version: "3.9"
                          services:
                            MSR:
                              container_name: MSReactor
                              restart: always
                              ports:
                                - "8111:8111"
                              networks:                            # Optional for use of static IP inside the docker network.
                                HAnett:                            # You could replace this and the subsequent lines with " network_mode: "bridge" "
                                  ipv4_address: 192.168.0.8
                              volumes:
                                - type: volume
                                  source: MSR
                                  target: /var/reactor
                                - "/etc/localtime:/etc/localtime:ro"
                              environment:
                                - TZ=Europe/Oslo
                                - REACTOR_DATA_PREFIX=/var/reactor
                              tmpfs: /tmp
                              logging:
                                  driver: "json-file"
                                  options:
                                    max-file: "5"
                                    max-size: 2m
                          networks:    #Optional
                              HAnett:
                                  driver: bridge
                                  ipam:
                                          - subnet: 192.168.0.0/16
                                            gateway: 192.168.0.254
                          volumes:
                            MSR:
                            Nice work there! I'm going to save a copy even though I routinely use the Docker GUI (perhaps not available to all Synology NAS users) to set up MSR.
                            I, too, have been mulling the difference between bind and volume and Googling a while back did not seem to settle it for me. Surely it must make some difference?!
                            Also, I gotta ask: Do you have any Sunrise/Sunset-based Rules? Only asking b/c for me, in 21117, my only Sunset/offset routine somehow failed to launch itself last night, but I'm uncertain whether that constitutes a 'bug' or just a misfire of some other kind.
                              I think the main advantage of volumes is that location is controlled by docker, and these locations aren't as easy to screw up if you mess around with the folder structure.. It also puts all volumes in a common folder (var/lib/docker/volumes) that can be copied to a tar or backup folder using one line, but thats just as easy if you organize bind folders the same way.. Let me know if you find other advatages. 🙂
                              I have no sunrise/sunset rules, i use light sensors for i.e. outside lighting.. I think about 90% of my "MSR bugs" have been PEBCAC, so check your logic. 😁
                                343
                                151.2k
