  4. Is this correct? Text shown in the blue banners on the rule summaries
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
11 Posts 2 Posters 2.3k Views 2 Watching
    I've just created four new rules as you can see in the screen shot above.
    In the dark blue banners, the first two rules show text of:
    Group: rule-klgiivpk-trig;
    and
    Group: rule-klghttuk-trig;
    and the bottom two rules have text of:
    Group: trig;
    I've named each of my rules as you can see in the screen shot.
    I was just wondering about the text in these dark blue banners.
    There doesn't appear to be a way to edit that text at all.
    All the rules are working fine as expected though.
      Seems to be related to copying an existing rule from one group to another or even within the same group.
      Also when I copied this rule from one group to another the "Set Reaction" action was fired and ran as it turned on my "Globe lamp".
        That's a bug; that view is still a work in progress. As I mentioned in the other thread, the constraints are missing from this display, as are any expressions local to each rule. Much work yet to be done, but this kind of thing usually mops up quickly. I wanted to get at least this much out so one could see what was going on. In any case, it should show nothing there for the "root" (highest-level) group.
          And the "Set reaction" action actually running when copying a rule ?
          Would you like me to create a ticket on the tracker for this ?
            @cw-kid said in Is this correct? Text shown in the blue banners on the rule summaries:
            That's new information. What's that?
              Then I copied that "Globe Lamp On or Off" rule from my group called "Moodlights" to the group called "Security" the action in the "Set Reaction" was fired and ran because my Globe lamp actually turned on.
                You can open a bug, but it needs to have reproducible steps, please.
                  OK its happened twice now when copying that particular rule and the Globe lamp is turned on for real.
                    Just to be clear, if you copy a rule to new rule, the new rule has no states, so if that rule is enabled, it will evaluated and it will run. So that may actually be normal and expected. The states of the original rule are not copied with the rule.
                      OK I've created a ticket you can decide.
                        I can't comment on the ticket now its closed.
                        Yes having the new copied rule disabled initially will work, you generally then want to edit and tweak that copied rule anyway and then you can enable it.
                        This will stop the copied rule just firing when you don't want it to do so.
