  4. I'm no longer a PLEG user !
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
Reset a delay
Reactor Loading Screen Safari
8 Posts 7 Posters 1.0k Views 7 Watching
    Been using PLEG for about 8 or 9 years, I had 100 Conditions / Actions in PLEG, these are now all disabled and I've recreated them on MSR.
    Still learning MSR and how to do somethings but everything I was doing in PLEG was fairly easy to convert over to MSR once I found my feet a bit and got going.
    Thanks to everyone who answered any of my questions along the way when I got stuck.
    I have some Vera scenes I'd like to also convert to MSR, so not quite done yet. 😁
      Congratulations! It's quite a leap!
        Yes, PLEG, I'm told, was good in its day, but rather of its time (and its author Richard.) A bit Marmite-like (that's Vegemite for @Black-Cat, IIRC) you either loved it or hated it. The other options (AltUI workflows, Rules Engine, ...) also had their adherents. But that was then, and this is now. I trust that MSR will serve you at least as long.
          Good work. I could never get my head around PLEG (no one here will find that a surprise) so Reactor was an epiphany
            sender
            PLEG, I still miss it now and then... good old days... now node red is my automation engine.
              I remember looking at PLEG once... ONCE... and running away. Found Reactor just last year and wonder what I ever did without it.
                PLEG deserves every bit of the ample respect it gets. Vera could not have survived without it. Yes, it could be quirky and hard to learn, but it delivered a lot of functionality to platform that desperately needed it. I view Reactor as a different way of doing things. Chocolate vs Strawberry at the ice cream counter: you may only like one, but life could certainly be duller without the choice of both. In a way, PLEG (and possibly later Reactor) may have held Vera back, which I've said often: had PLEG not been there, Vera would have faced considerably more pressure to do something themselves, and maybe succeeded, or failed harder earlier.
                But it is time to look to the future.
                  Yes PLEG wasn't the easiest thing to learn but it did save Vera. Powerful but not so user friendly. The conditions were the hardest part as you wrote them all out like expressions. Bulletproof though, I rarely had any issues with it. I skipped the whole Reactor for Vera thing, converted now so better late than never I guess.
                  • Possible feature request 2?
                    82.2k
                  • Copying a global reaction
