  4. How to auto start on Rpi reboot ?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
26 Posts 6 Posters 5.7k Views 7 Watching
    Do we have any instructions yet to follow for auto starting the MSR service on a Raspberry Pi after its rebooted?
      Assuming you are running on raspbian as a systemctl service, shouldn't enabling it do it?
      sudo systemctl enable msr.service
      Maybe you didn't create a service yet?
        Yes its Raspbian.
        I haven't created or done anything yet.
        I am running MSR currently by using this command:
        nohup ./app.sh &
        Which I am running by using Putty on my Windows 10 laptop.
          Yes its Raspbian.
          nohup ./app.sh &
          @cw-kid
          If such is the case, create the service by creating the file
          using putty logged in to your rpi:
          sudo nano /etc/systemd/system/msr.service
          paste in the following file content make sure the path to msr below is correct and change it if necessary:
          [Unit]
          After=network.target
          [Service]
          Type=simple
          ExecStart=nohup /home/user/msr/app.sh
          Restart=on-failure
          RestartSec=5s
          [Install]
          WantedBy=multi-user.target
          Hit ctrl+o then ctrl+x to save and exit from nano.
          reload the service daemon:
          sudo systemctl daemon-reload
          then enable the service
          You can then start and top the service with the two commands:
          sudo systemctl start msr
          sudo systemctl stop msr
            In Nano it says [ Error writing /etc/systemd/system/msr.service: Permission denied ] when trying to save the file.
            I then tried this instead:
            And it saved and I now have a file called msr.service in that directory.
            After this command
            It says
            Failed to enable unit: Invalid argument
              These are the file details / permissions
                This was the contents of the msr.service file.
                I had to change the path slightly.
                [Unit]
                [Service]
                Type=simple
                ExecStart=nohup /home/pi/Documents/reactor/app.sh
                Restart=on-failure
                RestartSec=5s
                [Install]
                  I would add User=pi at a minimum to the service section.
                  I have concerns about the stop action. Investigating...
                    Thanks, I did miss the sudo for the nano command to create the file.
                    The path does look suspicious too in addition to @toggledbits input. There may be other specificities about raspbian I may be missing.
                      I made a mistake in the msr.service file. Corrected and now the "sudo systemctl enable msr" command runs with no error.
                      I then rebooted the Pi but some time later I still cannot load MSR in the browser.
                        This is the contents of the msr.service file now
                        [Unit]
                        [Service]
                        User=pi
                        Type=simple
                        Restart=on-failure
                        RestartSec=5s
                        [Install]
                          can you show the error by posting the output of
                          sudo systemctl status msr
                            There are several things to indicate that the process is not ready for this at this point. Among them is that the nodejs installation done by the installer is local to the pi user. There are also issues with the home directory, and the search paths for modules and data relative to the current working directory vs the path of the application.
                            Too soon. Not ready yet. Not going to fix it tonight. This is prelease software. It isn't mean to run like production software at this point.
                              Think I have it working now and MSR is auto starting after a reboot
                              I placed my msr.service file in this directory:
                              Using WinSCP, on the msr.service file properties, I made its Group and Owner to be pi rather than root.
                              This is the files contents:
                              [Unit]
                              [Service]
                              Type=simple
                              ExecStart=nohup ./app.sh &
                              WorkingDirectory=/home/pi/Documents/reactor
                              Restart=on-failure
                              RestartSec=5s
                              [Install]
                              I then ran these commands in the terminal in Putty:
                              sudo systemctl enable /home/pi/Documents/reactor/msr.service
                              And I can check its status with this command:
                              It says its active and running.
                              If I reboot the Pi now after the reboot the MSR web page is then available and can be accessed.
                                Yeah, but running the shell script is not correct. You're basically having systemd do what the shell script is also doing (restarting when stopped), and it's going to cause problems. Your exec is also forking, so adding yet another layer of indirection that all but guarantees that systemd is going to be looking at the wrong process ID for what it thinks is a running Reactor. That could lead to problems stopping and restarting, and with the possible effect that an incorrect stop causes data loss.
                                  Didn't think I'd set it up correctly 😕 More of a hack to get it auto started.
                                    You're not far off, really, but the devilish details require some internal knowledge of how Reactor starts and organizes itself, and it's made a bit more complicated by the necessity to locate things "off shore" for docker containers and make sure that stays working as well. There's a bit of a balancing act there. As I'm sure you know well, features are not strictly governed by their ability to be implemented; they are also very much a function of what it takes to support them. I'd rather there be an "official" way that I know people use, because if ten people do it their own way, I'll have ten different ways I need to figure out any time there's a problem.
                                      Can I ask what data one could loose in a power outage? I presume that any setup (rules/expressions) change is written to persistent files on "save"?
                                        Right now, all data is written when modified, but that may not always be the case, and there's a high likelihood it will be user-configurable, even.
                                        One of the things designed in is that MSR is "crappy-storage-ready". @rafale77 can tell you at length about the merits and woes of various storage technologies, and an SD card in a Raspberry Pi is no exception (in fact, probably both a good example and a dire warning). MSR has a storage architecture for its data that allows "pluggable" storage disciplines, so you could, for example, choose a cached-with-delayed-write-back mechanism to reduce wear, and you could choose that for everything, or just states, or states and logs, etc. So in that case, as the system shuts down, it is necessary for the cache to write back any "dirty" (modified but unsaved as yet) data, or the modifications would be lost.
                                        That said, you should be thinking about getting your Pi off an SD card if that's what you're running, if you intend to run it full-time with MSR and depend on it. There are only two types of SD cards: those that have failed, and those that are about to. I have my Pi running on a cheap 2.5" SSD, and it's also a good bit faster, although there is some alchemy to getting that working, and while it's much better than it was, it involves some pretty magical incantations still today and can be a bit angst-inducing.
                                        Black CatB 1 Reply Last reply
                                        • MatohlM Offline
                                          MatohlM Offline
                                          Matohl
                                          With the newer firmwares to the RPi it is fairly straight forward to use a SSD since it has native support now. Not that much alchemy anymore.
                                            779
                                            3.6k
                                            3.2k
                                            809
