  4. Rule update rates, limits, logic loops, warnings and throttling
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
6 Posts 2 Posters 896 Views 2 Watching
    As is my custom, I often create ungainly Rules designed to push the limits of MSR until some problem crops up (UI glitch, runtime error, faulty logic, etc.). I'm starting this topic - and sharing a cautionary example below - to invite MSR power users to embrace best practices in their routines.
      Onward to my wayward example...
      Most recently, I noticed this line in Reactor.log
      Rule:WARN (Circulate House Air (auto)) update rate 61/min exceeds limit (60/min)! Logic loop? Throttling...
      suggesting that I had an issue in my "Circulate House Air" rule that caused "flapping" -- uncontrolled or unexpectedly high rates of triggering -- which invoked MSR's automatic throttling (suppression) of that rule.
      Because it's a fairly simple rule -- watch two Expressions (one a boolean, the other a calculated value from sensors), and check whether particular virtual switch is ON -- I was easily able to scrutinize its logic and layout.
      Here were the essentials:
      TRIGGERS
      [ Expression Value ] [ tempVar ] [ > ] [ 2 ] // IF temperature variation exceeds a certain threshold (a rare occurrence!); Pulse for 10 sec., repeat every 1200 secs.
      CONSTRAINTS
      [ Expression Value ] [ modesMatch ] [ is TRUE ] // only when A/C and Vera show same House Mode setting for 10+ secs.
      [ Entity Attribute ] [ VSwitch.status ] [ is TRUE ] // switch must also be ON
      REACTION
      [ Entity Action ] [ ACblower.power ] [ == ] [ 1 ] // turn on blower (auto-resets itself after 30 seconds)
      EXPRESSIONS
      tempVar := <mean deviation formula based on 4 sensors>
      modesMatch := <TRUE when A/C house mode matches Vera's>
      At first glance, all seemed well. Except MSR had expressly warned me (via the Log, at least) that something was amiss.
      Speculating that it was simply the arrangement of items within TRIGGERS and CONSTRAINTS, I moved the "VSwitch" condition from Constraints up into Triggers, and the "tempVar" expression down into Constraints, then re-enabled the Rule.
      Yet the throttling problem remains, according to the Log. While currently tempVar == 3, the VSwitch is OFF and modesMatch is FALSE -- that is, both Triggers and Constraints read 'false' -- so I would have thought it impossible for the Rule to be so active behind the scenes.
      Any insights on this problem?
        FEATURE REQUEST
        Display each active Rule's current rate and/or display a warning in UI whenever Throttling occurs. (Probably already on the MSR roadmap)
          If your log level is 5 or above for the rule in question, you will see messages logged like this:
          2021-03-15T15:21:07.639Z <Rule:5:Rule.js:444> {ruleid} notification {type} {data} from {sender}
          So this will tell you what is triggering the request for re-evaluation.
          If you didn't know, you can set the logging level (in config/logging.yaml) for a particular rule, so it's useful to set the generic level (level entry under Rule:) to 4 to keep other rules quiet, and then create a new entry with key Rule#ruleid: and subkey level set to 5 or whatever. This will focus the detailed debug output on the single rule and hold the noise down from the stuff you're not as interested in.
          logging:
            ... other stuff ...
            Rule:
              level: 4
            Rule#rule-f984r5nfe
              level: 5
            So far, with the default logging level of 4 set in LOGGING.YAML, I merely see these not-so-illustrative entries immediately before the <WARN> line:
            2021-03-15T15:34:34.150Z <Rule:5:Rule.js:800> Rule#rule-km9hxs0z (Circulate House Air (auto)) evaluate() acquiring mutex
            2021-03-15T15:34:34.150Z <Rule:5:Rule.js:804> Rule#rule-km9hxs0z._evaluate() mutex acquired, evaluating
            2021-03-15T15:34:34.151Z <Rule:5:Rule.js:808> Rule#rule-km9hxs0z update rate is 61/min limit 60/min
            I'll proceed to try higher level inspection (by altering the level: for this Rule only) later today, and see what specifically turns up. For now, I have the Rule disabled.
              Do not (ever) change the default logging level. Only change the logging level for the specific Rule and Rule#rule-id classes.
              • Next Release?
