  4. Why can't I run this LUA code ?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
9 Posts 3 Posters 1.3k Views 3 Watching
    I have created a Global Reaction with this LUA code for my Vera to run.
    However when I run the Reaction nothing happens. I can't see anything in the log file either about this rules ID number.
    If I run the same LUA code on Vera in the test window it works OK.
    OR any other suggestions how I can set this up in a global Reaction (Scene) in MSR ?
    Instead I could use the VeraScenes.lua file in the Vera startup library, but I am wondering why I can't just paste the LUA code directly in to the MSR rule.
    local status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 419) --Status of Safe to Arm virtual switch
    if status == "0" then --Safe to Arm
      luup.inet.wget("http://SOME-HTTP-REQUEST")
      luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1","SetHouseMode", {Mode = 2}, 0) --Set House Mode to Away
      luup.inet.wget('SOME-HTTP-REQUEST' ,5);
    else --Not Safe to Arm
      luup.inet.wget("SOME-HTTP-REQUEST")
    LibraSunL 1 Reply Last reply
      Have you looked at the contents of your LuaUPnP log file?
      cw-kidC 2 Replies Last reply
        No I will try again and check it.
          @toggledbits said in Why can't I run this LUA code ?:
          I am not seeing anything at all in the Vera LuaUPnP log after running the Global Reaction with the above lua code.
          No job is started.
          However if I change the lua code to just a one liner to do a TTS announcement for example, then that does work OK and I see it happening in the Vera log also.
            Are you running firmware 7.32 in the 5350 range? If not, what firmware are you running?
              Production Vera Plus is firmware version 1.7.5186 (7.31)
                I tried running this code on my Vera Edge which is version 7.32 and same thing, nothing happens and nothing in the Vera log either.
                  @cw-kid I don't know much Lua, but what determines when you do or don't include a semicolon at the end of a statement? Seems irregular to my eye.
                    @librasun
                    Both of these work OK on the Vera unit itself.
                    The one with the semi colon has a time out set.
                    I have tried making both HTTP requests one or the other / the same, but that's not the problem.
                    The problem is the LUA code is just not run on the Vera at all when initiated from the MSR rules Set Reaction.
                    • Next Release?
