  4. Why can't I run this LUA code ?
9 Posts 3 Posters 1.7k Views 3 Watching
    I have created a Global Reaction with this LUA code for my Vera to run.
    However when I run the Reaction nothing happens. I can't see anything in the log file either about this rules ID number.
    If I run the same LUA code on Vera in the test window it works OK.
    OR any other suggestions how I can set this up in a global Reaction (Scene) in MSR ?
    Instead I could use the VeraScenes.lua file in the Vera startup library, but I am wondering why I can't just paste the LUA code directly in to the MSR rule.
    local status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 419) --Status of Safe to Arm virtual switch
    if status == "0" then --Safe to Arm
      luup.inet.wget("http://SOME-HTTP-REQUEST")
      luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1","SetHouseMode", {Mode = 2}, 0) --Set House Mode to Away
      luup.inet.wget('SOME-HTTP-REQUEST' ,5);
    else --Not Safe to Arm
      luup.inet.wget("SOME-HTTP-REQUEST")
    LibraSunL 1 Reply Last reply
      Have you looked at the contents of your LuaUPnP log file?
      cw-kidC 2 Replies Last reply
        No I will try again and check it.
          @toggledbits said in Why can't I run this LUA code ?:
          I am not seeing anything at all in the Vera LuaUPnP log after running the Global Reaction with the above lua code.
          No job is started.
          However if I change the lua code to just a one liner to do a TTS announcement for example, then that does work OK and I see it happening in the Vera log also.
            Are you running firmware 7.32 in the 5350 range? If not, what firmware are you running?
              Production Vera Plus is firmware version 1.7.5186 (7.31)
                I tried running this code on my Vera Edge which is version 7.32 and same thing, nothing happens and nothing in the Vera log either.
                  @cw-kid I don't know much Lua, but what determines when you do or don't include a semicolon at the end of a statement? Seems irregular to my eye.
                    @librasun
                    Both of these work OK on the Vera unit itself.
                    The one with the semi colon has a time out set.
                    I have tried making both HTTP requests one or the other / the same, but that's not the problem.
                    The problem is the LUA code is just not run on the Vera at all when initiated from the MSR rules Set Reaction.
                      160.0k
