  4. [SOLVED] Rethinking HVAC moving from Reactor (Vera) to MSR
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
18 Posts 2 Posters 1.9k Views 2 Watching
    In my Vera config I have two SiteSensors (one for Ambient Wx, one for OpenWxMap) that point to two unique Reactor devices for controlling HVAC in my home. This is done for redundancy - if the Ambient API drops it returns zero data which then triggers a standalone Master API Reactor device to flip on the OWM SiteSensor and corresponding HVAC Reactor device to continue controlling the house conditions.
    Once the Ambient API returns to available the Master API Reactor device flips back to the Ambient SiteSensor and corresponding HVAC Reactor device, turning OFF the SiteSensor for OWM to save on API calls.
    I've been able to duplicate one half of this, including the Master API role, in MSR. But... here's the tricky part... I can't turn "off" the MSR Rule Sets for the OWM version. As such, HVAC is sent conflicting data and doesn't know what to do.
    Before I go alls deep into explaining how all of this currently works, am I missing something somewhere that would allow me to trigger the on/off of MSR Rule Sets?
    Solved here: https://smarthome.community/post/10329
    *Hubitat C-7 2.4.3.177
    Core 2026.1.1
    MSR: latest-26011-c621bbc7
      The simplest possible suggestion I can come up with involves creating a go/no-go variable within each Rule you'd like to control in that fashion. By creating an empty expression (let's call it "Go") in Rule A, for example, you could add a Constraint in Rule A:
      [Expression Value] [ Go ] == 1
      You could then, in Rule B, use a [Set Variable] [ Go ] = 1 (yes, MSR rules can now see each other's settable variables!) when you want Rule A active, and = 0 when you want Rule A deactivated.
      Did I come close to answering your question?
        I'm... not sure lol I'm not savvy in proper use of expressions so there needs to be more meat added to this bone for me to fully grasp it, I'm afraid.
        Core 2026.1.1
          Give it time, as there is a shallow-but-nonzero learning curve moving from Reactor over to MSR. Let's keep this conversation going until you have things working according to plan. Don't hesitate to post screenshots of your work for us to review.
          My suggestion is to start with "Test Rules" that you build for no particular purpose (certainly not for daily driving of Vera devices!), just to kick the tires with. This is a good way to get a grasp of how Expressions work in particular. I probably create and destroy 3-4 throwaway Test Rules every day, just workshopping different approaches to problems similar to yours.
            Oh I have made very liberal use of Test rules, believe me lol It's been very helpful. I'll try to pull together some screenshots here shortly. As to Reactor>MSR, yes, there's a slight curve. I've been able to pare down my Reactor device designs considerably using MSR.
            Core 2026.1.1
              This is the high-level architecture. Three arming rules, then the appropriate on/off rules that trigger when the arming criteria are met.
              Core 2026.1.1
                Continuing, there were two SiteSensors in Vera - I've moved the Ambient API one to MSR as noted above with the high-level.
                In Vera, it's easy to turn on and off the SiteSensor for OpenWxMap to reduce API calls based on query results from the Ambient API SiteSensor. There's a ruleset moved into MSR that drives the failover/back.
                In MSR, however, I cannot turn off the OWM ruleset when Ambient API is driving. The result becomes two sets of data being sent to the t-stats which annoys them.
                Currently, I'm using the SiteSensor for OWM in Vera and the ruleset in MSR for Master failover/back and driving Ambient data to the t-stats.
                Core 2026.1.1
                  Remember, it's entirely plausible to introduce an expressionless (empty) "Go" variable within any Rule, such that the Rule A "runs" (acts Enabled) with "Go" set to "1", and is barred from running (acting Disabled) with it set to "0".
                  To make this setup work, simply have your other Rule B's Set Reaction do a [ Set Expression ] [ = ] [ 0 ] on Rule A's variable "Go", with a [ Set Expression ] [ = ] [ 1 ] in its Reset Reaction. Create a corresponding Trigger condition in Rule A that tests [ Expression Value ] [ == ] [ 1 ], and you should be good to go.
                  Does that make sense? Hope it helps!
                  NOTE: You can also use true / false values for Go and make your Rule A's Trigger condition check for [isTrue] instead.
                    @librasun Wait, what? Slow pitch this - I've never played with the expressions before.
                    Core 2026.1.1
                      Before I do (let's save Expressions for very last...), please explain how MSR could "know" which version of the weather sensor you want enabled?? I'll go re-read your posts from the past 24 hours to see if I can ascertain same.
                        For instance, I heard you say, "I cannot turn off the OWM ruleset (in MSR) when Ambient API is driving". Couldn't its governing Rule just have an extra Constraint condition like:
                        [ Entity Attribute ] [ SiteSensor_156 ] [ x_vera_device.failed ] [ isTRUE ]
                        so that it refrains from execution while Ambient is in good health?
                          Fair enough on the explanation - I prob made that typical error of not providing the details that I "just know" in my head. 🙂
                          Original Vera setup: two SiteSensors, one for Ambient API, one for OWM API. Ambient is hyper-local (my wx station) and is the daily driver. To save API calls against OWM, the SiteSensor there is set to disabled status normally.
                          If Ambient API call returns zero results, the Master API ruleset sees the failure, changes OWM API SiteSensor to enabled. As the query results from Ambient are blank, it is left in enabled status - and there's only one set of data points going to the t-stats.
                          Once Ambient API call returns regular results again, the Master API ruleset sees the actual data and changes OWM API SiteSensor to disabled again and life is, once again, good for all.
                          Can you define for me "refrains from execution"... are you saying it would not send anything to the t-stats or query the API (or both)?
                          Core 2026.1.1
                            From all I see (I just stopped short of saying it explicitly earlier), you're asking, "How can I temporarily stop MSR from sending API requests to OWM?" I don't see an immediate way to set that mechanism's sys_system.state= to false, although that was my initial thought.
                            I think we'll have to ask @toggledbits to advise on best practices here.
                            G 2 Replies Last reply
                              @librasun I poked at this a bit with what I thought you were getting at. The configuration now (which is a carry-over from Vera Reactor and could prob use some trimming) has the top three rulesets (shown earlier) use to arm the system, ie set the parameters for what qualifies as "I should heat now" or "I should cool now" - and then the five rulesets below are the actual action rules.
                              For instance, if the system "qualifies" for (or is armed) for Cooling then only the two rulesets for Cooling are actionable. Same applies for Heating.
                              Taking what you said earlier, I added a condition to each of the action rulesets as shown in this example:
                              I was missing the reality of the action rulesets still running even though none of the qualifiers/armers were, well, armed. The action rulesets were using the last known datapoints stored in the armers - and that's where things were going amiss.
                              By adding the extra condition to each action ruleset it seems to have quieted - this may be the solution (not pretty, but a solution.)
                              Core 2026.1.1
                                @librasun The arming rules look like this:
                                In my mind, all of these conditions were rolling down to the action rulesets - which is not true.
                                Core 2026.1.1
                                  I'm liking what I see. We both know there are always 1000 avenues to "the right answer" but what you've just presented seems reasonable and suited to your original goal(s).
                                    @librasun Thanks, and totally agree.
                                    My goal is always to keep things as uncomplicated as possible as changes or tweaks later get crazy if you have to edit in multiple places. You ALWAYS miss something somewhere and lose countless hours trying to troubleshoot.
                                    Core 2026.1.1
                                      As I'm marking this as [SOLVED] I thought I'd update on how this all ended up playing out:
                                      Creation of two API rulesets, one for Ambient, one for OWM, that dump their data into Global Expressions. At issue was how to disable OWM to prevent needless API calls - I ended up doing the maths and making adjustments that this isn't an issue any longer. As such, one API ruleset for each dumping to clearly labeled Global Expressions. Yes, they both call out to their respective APIs but the volume is low enough not to trigger either for overuse.
                                      The only gotcha here is to make sure that you include in the rulesets for the secondary (OWM) a Trigger that checks for the primary API to be returning null so you don't have both flavors of rulesets competing for Honeywell's API (which is notoriously cranky) as you set the t-stats.
                                      Core 2026.1.1
                                        3.5k
                                        3.1k
                                        472
                                      • Self test
