  4. [SOLVED] Rethinking HVAC moving from Reactor (Vera) to MSR
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
Reset a delay
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
18 Posts 2 Posters 1.8k Views 2 Watching
    In my Vera config I have two SiteSensors (one for Ambient Wx, one for OpenWxMap) that point to two unique Reactor devices for controlling HVAC in my home. This is done for redundancy - if the Ambient API drops it returns zero data which then triggers a standalone Master API Reactor device to flip on the OWM SiteSensor and corresponding HVAC Reactor device to continue controlling the house conditions.
    Once the Ambient API returns to available the Master API Reactor device flips back to the Ambient SiteSensor and corresponding HVAC Reactor device, turning OFF the SiteSensor for OWM to save on API calls.
    I've been able to duplicate one half of this, including the Master API role, in MSR. But... here's the tricky part... I can't turn "off" the MSR Rule Sets for the OWM version. As such, HVAC is sent conflicting data and doesn't know what to do.
    Before I go alls deep into explaining how all of this currently works, am I missing something somewhere that would allow me to trigger the on/off of MSR Rule Sets?
    Solved here: https://smarthome.community/post/10329
    *Hubitat C-7 2.4.3.173
    *HASS 2025.12.4, Core 2025.12.3
    MSR: latest-25328-b2ed1365
      The simplest possible suggestion I can come up with involves creating a go/no-go variable within each Rule you'd like to control in that fashion. By creating an empty expression (let's call it "Go") in Rule A, for example, you could add a Constraint in Rule A:
      [Expression Value] [ Go ] == 1
      You could then, in Rule B, use a [Set Variable] [ Go ] = 1 (yes, MSR rules can now see each other's settable variables!) when you want Rule A active, and = 0 when you want Rule A deactivated.
      Did I come close to answering your question?
        I'm... not sure lol I'm not savvy in proper use of expressions so there needs to be more meat added to this bone for me to fully grasp it, I'm afraid.
          Give it time, as there is a shallow-but-nonzero learning curve moving from Reactor over to MSR. Let's keep this conversation going until you have things working according to plan. Don't hesitate to post screenshots of your work for us to review.
          My suggestion is to start with "Test Rules" that you build for no particular purpose (certainly not for daily driving of Vera devices!), just to kick the tires with. This is a good way to get a grasp of how Expressions work in particular. I probably create and destroy 3-4 throwaway Test Rules every day, just workshopping different approaches to problems similar to yours.
            Oh I have made very liberal use of Test rules, believe me lol It's been very helpful. I'll try to pull together some screenshots here shortly. As to Reactor>MSR, yes, there's a slight curve. I've been able to pare down my Reactor device designs considerably using MSR.
              This is the high-level architecture. Three arming rules, then the appropriate on/off rules that trigger when the arming criteria are met.
                Continuing, there were two SiteSensors in Vera - I've moved the Ambient API one to MSR as noted above with the high-level.
                In Vera, it's easy to turn on and off the SiteSensor for OpenWxMap to reduce API calls based on query results from the Ambient API SiteSensor. There's a ruleset moved into MSR that drives the failover/back.
                In MSR, however, I cannot turn off the OWM ruleset when Ambient API is driving. The result becomes two sets of data being sent to the t-stats which annoys them.
                Currently, I'm using the SiteSensor for OWM in Vera and the ruleset in MSR for Master failover/back and driving Ambient data to the t-stats.
                  Remember, it's entirely plausible to introduce an expressionless (empty) "Go" variable within any Rule, such that the Rule A "runs" (acts Enabled) with "Go" set to "1", and is barred from running (acting Disabled) with it set to "0".
                  To make this setup work, simply have your other Rule B's Set Reaction do a [ Set Expression ] [ = ] [ 0 ] on Rule A's variable "Go", with a [ Set Expression ] [ = ] [ 1 ] in its Reset Reaction. Create a corresponding Trigger condition in Rule A that tests [ Expression Value ] [ == ] [ 1 ], and you should be good to go.
                  Does that make sense? Hope it helps!
                  NOTE: You can also use true / false values for Go and make your Rule A's Trigger condition check for [isTrue] instead.
                    @librasun Wait, what? Slow pitch this - I've never played with the expressions before.
                      Before I do (let's save Expressions for very last...), please explain how MSR could "know" which version of the weather sensor you want enabled?? I'll go re-read your posts from the past 24 hours to see if I can ascertain same.
                        For instance, I heard you say, "I cannot turn off the OWM ruleset (in MSR) when Ambient API is driving". Couldn't its governing Rule just have an extra Constraint condition like:
                        [ Entity Attribute ] [ SiteSensor_156 ] [ x_vera_device.failed ] [ isTRUE ]
                        so that it refrains from execution while Ambient is in good health?
                          Fair enough on the explanation - I prob made that typical error of not providing the details that I "just know" in my head. 🙂
                          Original Vera setup: two SiteSensors, one for Ambient API, one for OWM API. Ambient is hyper-local (my wx station) and is the daily driver. To save API calls against OWM, the SiteSensor there is set to disabled status normally.
                          If Ambient API call returns zero results, the Master API ruleset sees the failure, changes OWM API SiteSensor to enabled. As the query results from Ambient are blank, it is left in enabled status - and there's only one set of data points going to the t-stats.
                          Once Ambient API call returns regular results again, the Master API ruleset sees the actual data and changes OWM API SiteSensor to disabled again and life is, once again, good for all.
                          Can you define for me "refrains from execution"... are you saying it would not send anything to the t-stats or query the API (or both)?
                            From all I see (I just stopped short of saying it explicitly earlier), you're asking, "How can I temporarily stop MSR from sending API requests to OWM?" I don't see an immediate way to set that mechanism's sys_system.state= to false, although that was my initial thought.
                            I think we'll have to ask @toggledbits to advise on best practices here.
                            G 2 Replies Last reply
                              @librasun I poked at this a bit with what I thought you were getting at. The configuration now (which is a carry-over from Vera Reactor and could prob use some trimming) has the top three rulesets (shown earlier) use to arm the system, ie set the parameters for what qualifies as "I should heat now" or "I should cool now" - and then the five rulesets below are the actual action rules.
                              For instance, if the system "qualifies" for (or is armed) for Cooling then only the two rulesets for Cooling are actionable. Same applies for Heating.
                              Taking what you said earlier, I added a condition to each of the action rulesets as shown in this example:
                              I was missing the reality of the action rulesets still running even though none of the qualifiers/armers were, well, armed. The action rulesets were using the last known datapoints stored in the armers - and that's where things were going amiss.
                              By adding the extra condition to each action ruleset it seems to have quieted - this may be the solution (not pretty, but a solution.)
                                @librasun The arming rules look like this:
                                In my mind, all of these conditions were rolling down to the action rulesets - which is not true.
                                  I'm liking what I see. We both know there are always 1000 avenues to "the right answer" but what you've just presented seems reasonable and suited to your original goal(s).
                                    @librasun Thanks, and totally agree.
                                    My goal is always to keep things as uncomplicated as possible as changes or tweaks later get crazy if you have to edit in multiple places. You ALWAYS miss something somewhere and lose countless hours trying to troubleshoot.
                                      As I'm marking this as [SOLVED] I thought I'd update on how this all ended up playing out:
                                      Creation of two API rulesets, one for Ambient, one for OWM, that dump their data into Global Expressions. At issue was how to disable OWM to prevent needless API calls - I ended up doing the maths and making adjustments that this isn't an issue any longer. As such, one API ruleset for each dumping to clearly labeled Global Expressions. Yes, they both call out to their respective APIs but the volume is low enough not to trigger either for overuse.
                                      The only gotcha here is to make sure that you include in the rulesets for the secondary (OWM) a Trigger that checks for the primary API to be returning null so you don't have both flavors of rulesets competing for Honeywell's API (which is notoriously cranky) as you set the t-stats.
                                      • Copying a global reaction
                                      • Need help with sequence
                                      • Possible feature request?
                                      • Time series documentation
                                      • Reset a delay
