  3. Advances made in Presence Detection?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
12 Posts 5 Posters 1.7k Views 6 Watching
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    Looks like the wasp in the Box has a new competitor, I received this information this morning and am posting it whilst looking for comment - 🙂
    Detecting Chest and Abdomen expansion sounds a little to far fetched for me, but I like the idea if it really works.
    LifeBeing Sensor
    Zigbee module & MCU SDK
    State-of-Art Technology
    It's based on 5.8Ghz microwave motion detection technology. And the patented low impedance antenna and exclusive occupancy sensing Algorithm are used to sensor human presence by detecting expansion of chest and abdomen during human respiration. Combined, they can effectively avoid the airflow interference from air conditioning and exhaust, to achieve accurate human detection
    Multi-state Recognition
    It can interact with different lights, air conditioners, background music, etc. based on the activeness of human motion. For example, lights turned fully on when it detects active human motion
    Independent Flush-mounted Design
    Not limited to LED lamps and can be well hidden in the existing lighting environment to avoid any damage
    aka Zedrally
      Ah, interesting. I was looking at this type of technology a while ago…
      May 10, 2013
      how do you "detect" somone home ?
      I was rather intrigued by this recent, highly publicised, paper: Through-the-Wall Sensing of Personnel Using Passive Bistatic WiFi Radar at Standoff Distances [url=http://ieeexplore.ieee.org/xpl/articleDetails.jsp?arnumber=6020778]Error Page - IEEE Xplore which claimed to detect presence using...
        mrFarmer
        At 276 Euro's and just one meter radius for breath detection I think I'll waive my arms for now 😉
        Black CatB 2 Replies Last reply
          @black-cat said in Advances made in Presence Detection?:
          Micro changes in air density my ass? 😉
          • M mrFarmer
            Black CatB Offline
            Black CatB Offline
            Black Cat
            @mrfarmer said in Advances made in Presence Detection?:
            I had no idea of price in the EU, none the less it's still comparable with similar KNX products which don't tell you if your still breathing..!
            I received a reply from the manufacturer, not giving much (anything) away about price, just wanting to know how many I want to order....LOL how would I know if I don't know the price...Chicken or Egg reborn in Wasp in a Box.
            Not sure where you got the specs from but they appear different from the ones I was sent.
            I'll get a price quote and see what the difference might be?
            aka Zedrally
            LibraSunL 1 Reply Last reply
            • Black CatB Black Cat
              @black-cat My Google Pixel phone detects my breathing rate by using the front-facing camera. So I guess this technology has proliferated.
              • M mrFarmer
                Black CatB Offline
                Black CatB Offline
                Black Cat
                We may be comparing Apples with Oranges here.
                After receiving further information from the manufacturer, a quick calculation shows the price for this device is about the same price you would buy a Fibaro Z-Wave IR Motion detector, This one with detection of a 5M radius at 3M height certainly becomes an affordable alternative.
                I'll order some stock - test and report back.
                aka Zedrally
                  Not sure what Fibaro models you're comparing to?
                  67 CAD  /  Device
                  Z-Wave Fibaro Multi Sensor
                  The Fibaro Motion Sensor is a universal Z-Wave multi-sensor that combines a PIR (Motion), light, temperature and accelerometer (vibration) sensor, all in one tiny package. The Fibaro Motion Sensor is battery powered device and designed to be installed quickly and easily on any surface....
                  About €64
                  Or am I missing something?
                  (PS Sorry no one got the Alien reference!)
                    Black CatB Offline
                    Black Cat
                    Here the FGMS-001 retails for AUD120.00 about 63.00GP or 73.00 Euro equivilient.
                    aka Zedrally
                      Ahhh so the €276 is wrong?
                        mrFarmer
                        wrote on last edited by mrFarmer
                        Here they sell it for that price. It is the only I could find https://karjalanvalaistuspalvelu.fi/en/iot/sensors/c-s-mw/msa012r-detail
                        They do have an other model at 79 euro, though.
                          Black CatB Offline
                          Black Cat
                          OK, the price differences are because of the different systems that they can be used with.
                          The E276 is for Dali - that is a very professional lighting system. I agree, I would just wave my hands about however for installations in large buildings it's a very clever way to control lighting intensity - Building Management Systems are a very different animal.
                          E79 for Wifi or Zigbee isn't a deal breaker and in fact can be a a very clever way of light control in a Smart House without the complication of additional systems.
                          Looking forward to unwrapping the box when it arrives....watch this space.
                          aka Zedrally
                            334
                          • Self test
                          • Possible feature request 2?
