  4. Ezlo device capabilities
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
31 Posts 3 Posters 5.5k Views 2 Watching
    Having gotten the Ezlo controller to connect I see these device items
    x_ezlo_item.learn_ir_code=0
    x_ezlo_item.learn_rf_code=0
    x_ezlo_item.send_ir_code=""
    x_ezlo_item.send_rf_code=""
    But they are not listed in the capabilities. It would be nice if to send Ir and Rf codes direct from MSR.
    If possible couild you add this feature.
      You would have to explain to me how they work (e.g. what the parameters mean, etc.), since I don't have these devices (I noted from our other discussion that it's a Broadlink device), and eZLO's documentation does not cover these items (not even a mention).
        And there is the rub.
        As far as i know the ir/rf codes are stored on the ezlo as base64 encoded strings. I presume that the code would be sent as a value with one of those two item.send parameters, th broadlink would then broadcast the ir/rf . I would ask Ezlo, but i am one of the banned people.
        I believe the broadlink device is a plugin developed by Ezlo.
        If i find out more i will let you know. As you say you can not work miracles.
        Maybe some one who is not banned can ask over at Ezlo what the parameters accepts and if it is open for use.
          I'm not yet banned, but probably have one foot in their forums and the other on a banana peel, so I'll try and see what response I get.
            Well this is classic Vera/eZLO. Support appears to have no idea that this device is recognized: https://community.ezlo.com/t/broadlink-ir-what-do-these-items-mean-do/217834/2?u=rigpapa
            @Elcid This is not bridged from a Vera or anything like that, right? You specifically added this device to your eZLO as a first-class, directly-supported device? Just confirming before I go back and disagree with Oscar's assertion.
            Edit: Yeah, I see it listed in the VeraMobile app. Sheesh. Here we go...
              Yes defiantly added via the Ezlo/vera app.
              Just read the thread. Seems the usual lefthand not knowing righthand scenario.
              Cheers for posing the question though. May be it will get a response that will help from Oleh.
                So happy to be out of it!
                  wrote on last edited by Elcid
                  I see Oleh has responded
                  i tested the the hub.item.value.set with the below command and was able to turn on /off the ir device, i also tested a rf device and all works.
                    "method": "hub.item.value.set",
                    "id": "1626604139112",
                    "params": {
                      "_id": "6093b3b9122335171491d136",
                      "value": "JgBwAAABJ5UQFREUEBURFBAVEBQSFBAVDzoSOBE4ETkROREUEDoQORAWETcRFQ8XDxUQFRAVEBUOOxITEDoROBE5EDoROBE5EAAFQQABJ0wQAAxLAAEnSxEADEsAASZMEQAMSwABJkwRAAxKAAEmTBEADQUAAAAAAAAAAA=="
                  I was also able to turn on ir/rf learning with the below api request
                    "id": "1626604956393",
                    "params": {
                      "_id": "60a35a31122335171b85b751",
                      "value": 1
                  this is the broadcast response after a ir signal is sent to broadlink in learning mode.
                    "id": "ui_broadcast",
                    "msg_id": "60f4346b122335125b847786",
                    "msg_subclass": "hub.extensions.plugin.ui_broadcast",
                    "result": {
                      "code": "JgBYAAABLJUSFBIUERQUEhMTERURORMTETkSORI5EzgRORI5FBISOREVERQTExE5FBITExEUFBITOBM3EjkSFBI5EjgSORI5EgAFLQABK0sSAAx3AAErSxIADQU=",
                      "plugin": "broadlink",
                      "type": "IR"
                  each ir/rf command has a different _id that is listed in hub.items.list
                    Unfortunately there's nothing in the broadcast that ties it back to the original request, so that's going to eliminate the possibility of storing any broadcast response on the correct item/device. I've asked Oleh about this.
                      Capturing the learnt rf/ir codes would be enough, it would remove the need to fire up the ezlo/vera App to capture codes. Maybe actions to learn_ir/rf_code and an ezlo broadcast listener in the tool section?
                      • ElcidE Elcid
                        @elcid said in Ezlo device capabilities:
                        Yup, that's the part I can't do correctly without connecting data.
                          Ok we will see what Oleh has to say.
                          here is complete broadcast respnonse
                          1 send "learn_ir_code" _id with hub.item.value.set
                          2 after broadlink learns ir code.
                          3 when learn_ir_code resets to 0
                          3-
                              "date": 1626635249558,
                              "data": {
                                "msg_id": "60f47bf1122335125b847819",
                                "msg_subclass": "hub.item.updated",
                                "result": {
                                  "_id": "6059aab5122335123a08b974",
                                  "deviceCategory": "ir_tx",
                                  "deviceId": "6059aab5122335123a08b973",
                                  "deviceName": "RM pro lounge",
                                  "deviceSubcategory": "irt",
                                  "name": "learn_ir_code",
                                  "notifications": [],
                                  "roomName": "lounge",
                                  "serviceNotification": true,
                                  "syncNotification": false,
                                  "userNotification": false,
                                  "value": 0,
                                  "valueFormatted": "0",
                                  "valueType": "int"
                          2-
                              "date": 1626635249517,
                              "data": {
                                "msg_id": "60f47bf1122335125b847818",
                                "result": {
                                  "code": "JgBQAAABLJUVERQSFBEUEhQSFBEUNxQSFDcUNxM3FDcUNxQ3FBITNxQ3FBIUNxMSFBIUEhQRFBIUEhQ3ExIUNxQ3FDcUNxM3FAAFLQABLUkUAA0FAAAAAAAAAAA=",
                                  "type": "IR"
                          1-
                              "date": 1626635244363,
                              "data": {
                                "msg_id": "60f47bec122335125b847817",
                                "result": {
                                  "value": 1,
                                  "valueFormatted": "1",
                                  "valueType": "int"
                            This is not the broadcast response we need, though. This is the one that resets the item back to 0 when the learn stops. A successful learn causes two broadcasts: this one to announce that the device has stopped learning, and a separate one to announce what was learned. It's that second broadcast that is missing the IDs we would need to tie it back to either the item or the device.
                              Yes i understand that, I was just adding the full sequence for clarity.
                                Just to report, the hub.item.value.set in msr 1.0 is working fine. I can send ir/rf codes, and initiate a rf/ir learn mode, i just have to listen for broadcasts to pick up the codes and copy and paste into msr.
                                P.s. congrats on the release of 1.0 and thank you.
                                  You should also be able to use remote.send_codes. The format of the code data can either be a base64 string (in the format base64:datadatadata), or a list of byte values as decimal or hex values separated by spaces or commas (e.g. 0x00 0x12 0x2a 0xfe 0x14 for hex, 0 18 42 254 20 for decimal, and mixing is OK).
                                  Should it support Pronto?
                                  ElcidE 1 Reply Last reply
                                    @toggledbits remote.send_code has no input field.
                                    As shown in above image
                                      Whoops! I'll have that fixed in the next build. Remind me what package you are using (docker or bare metal, RPi, Linux, Windows?)
                                      Edit: And the builds are up (latest).
                                        no luck with remote.send_codes with format base64:JgBYAAABJ5UQFBITERQRFBEUEBURExIUEDkRORE4ETkRORETEjkQORE4EjkQFBEUERQRFBEUEBURExITETkSOBE4ETkRORE4EQAFPwABJ0sRAAxHAAEnSxEADQU=
                                        build reactor-latest-21200-17fb925.tar.gz
                                          OK. Got your log file; thanks for that. Found the issue, will be fixed in today's "latest" build (21201).
                                            918
                                            2.0k
                                            3.7k
                                            3.3k
                                            940
