  4. MSR and WLED Presets
5 Posts 2 Posters 1.3k Views 2 Watching
  • J Offline
    J Offline
    Jaggz
    Attempting to set up an automation that turns on one of my WLED lights running in Home Assistant to a specific "preset", defined in the WLED application. In HA automations, there is an option to input the specific preset number but that doesn't seem to be an option in MSR. Am I missing something or can this be added in a future release?
      What service do you use in HA to do that?
      • J Offline
        J Offline
        Jaggz
        wled.preset
          OK. If the x_hass_wled service is not on your entity you need to add it manually through configuration. One of the issues with Home Assistant is that their API does not enumerate what services are supported by a (HA) entity, so there is no way MSR can determine which services apply other than the service implied by the entity's domain name (e.g. switch.living_room is assumed to support the switch service because it's in the name). So, you have to declare those yourself.
          Make a text file called local_hass_devices.yaml in your config subdirectory. Format it as shown below, using spaces for indents (two spaces per indent level). Replace my placeholder (MSR) entity canonical ID with the actual canonical ID of your MSR entity:
          entities:
            "hass>light.whatever_id_it_is":       <--- your canonical ID here
              services:
                - wled
          That will tell the HassController class that the specific entity mentioned supports the wled service. Restart MSR, and after that, you should find x_hass_wled capability on the entity with whatever actions it supports.
          • J Offline
            J Offline
            Jaggz
            Thanks. This worked perfectly and do appreciate the added context to understand why. Note: there was already a "local_hass_devices.yaml" file in my config with an entities header. Therefore, I just needed to enter the following 3 lines/entity information you noted below that heading and all was good.
              138.8k
