  4. [SOLVED] Multiple Holidays, one Ruleset
Gradually turn on lights.
Tom_DT
Error After Upgrade
Links to MSR from HA
Tom_DT
Set Reaction > Script Action
I'm running MSR build 25139 on Docker, using MQTT controller 24293, and everything working as expected. But if I try to upgrade to MQTTController build 25139, I'm getting the following errors on MSR UI: An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.god Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa auto heating off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.green Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto off" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute temperature_sensor.red Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa filter pump auto run" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.pump Last 11:20:37 An Entity Attribute condition in "Lay-Z-Spa watchdog" (Terrace) failed because the referenced entity "Lay-Z-Spa States" (mqtt>layzspa_states) does not have attribute value_sensor.status Last 11:20:37 My MQTT configuration (local_mqtt_devices.yaml) for the related entity is: layzspa_message: type: ValueSensor capabilities: ["temperature_sensor", "value_sensor", "power_sensor"] primary_attribute: power_sensor.value events: "layzspa/message": "power_sensor.value": json_payload: true if_expr: '! isnull( payload?.PWR )' expr: "float(payload.PWR)" "value_sensor.air": json_payload: true if_expr: '! isnull( payload?.AIR )' expr: "float(payload.AIR)" "value_sensor.pump": json_payload: true if_expr: '! isnull( payload?.FLT )' expr: "float(payload.FLT)" "value_sensor.god": json_payload: true if_expr: '! isnull( payload?.GOD )' expr: "float(payload.GOD)" "value_sensor.lock": json_payload: true if_expr: '! isnull( payload?.LCK )' expr: "float(payload.LCK)" "value_sensor.unit": json_payload: true if_expr: '! isnull( payload?.UNT )' expr: "float(payload.UNT)" "value_sensor.error": json_payload: true if_expr: '! isnull( payload?.ERR )' expr: "float(payload.ERR)" "temperature_sensor.green": json_payload: true if_expr: '! isnull( payload?.GRN )' expr: "float(payload.GRN)" "temperature_sensor.red": json_payload: true if_expr: '! isnull( payload?.RED )' expr: "float(payload.RED)" "temperature_sensor.target": json_payload: true if_expr: '! isnull( payload?.TGT )' expr: "float(payload.TGT)" "temperature_sensor.value": json_payload: true if_expr: '! isnull( payload?.TMP )' expr: "float(payload.TMP)" "temperature_sensor.virtual": json_payload: true if_expr: '! isnull( payload?.VTM )' expr: "round(float(payload.VTM), 1)" "temperature_sensor.ambient": json_payload: true if_expr: '! isnull( payload?.AMB )' expr: "float(payload.AMB)" "layzspa/Status": "value_sensor.status": if_expr: '! isnull( payload )' expr: "payload" "layzspa/button": "value_sensor.button": if_expr: '! isnull( payload )' expr: "payload" and in reactor.yaml I have: "layzspa_states": name: "Lay-Z-Spa States" friendly_name: 'Lay-Z-Spa States' include: layzspa_message I realize my MQTT configuration might be a bit unorthodox, but could there still be something unintentional in the latest MQTTController build? If needed, I can provide detailed logs.
Tom_DT
Need help reducing false positive notifications
Deleting widgets
Hopefully a trivial question, but how do you delete widgets in a status page? Using build 22266
MQTT configuration question
I have the following yaml configuration in local_mqtt_devices file x_mqtt_device: set_speed: arguments: speed: type: str topic: "command/%friendly_name%" payload: type: json expr: '{ "fan": parameters.speed }' While this works fine, I'm wondering how this could be changed to "fixed" parameters, as in this case "fan" only accepts "A", "Q" or a numeric value of 1-5?
8 Posts 4 Posters 482 Views 4 Watching
    Seems simple enough: same landscape lights for Independence Day, Memorial Day, and Labor Day.
    Complication: one is a static date each year, the others are "last Monday of" and "first Monday of" respectively.
    Here's what I have:
    How far off am I?
    *Hubitat C-7 2.4.1.177
    *HASS 2025.6.0
    w/ ZST10-700 fw 7.18.3
    MSR: latest-25139-fbd67abc
    3 1 Reply Last reply
    • toggledbitsT Away
      toggledbitsT Away
      Looks good. The Date/Time constraints for Memorial and Labor Days are technically, and very specifically, correct, but don't need to be (as specific). A full month range would have the same effect, since the Date/time and the Weekday conditions are AND'd together. So you've put a bit more thought into it than it actually requires, but you're not wrong; it should work great.
        So we all looked at it... and we all missed it lol.
        Independence Day = 00:00 07/04 - 00:00 07/04. That doesn't work because literally zero time lol. Now, 00:00 07/04 - 00:00 07/05 works... because WHOLE DAY lol
        Figured it out when the lights were reported by neighbor to have never come on. Logs agreed. Updated, tested on 07/05 for a few minutes and we're all set for next year.
        *HASS 2025.6.0
        • toggledbitsT Away
          toggledbitsT Away
          You can also use "after" instead of between. The rule stays true for a while, but it still only fires the reaction when it changes (once).
            @toggledbits I'm always looking for better ways to smarten my rulesets. As you noted earlier in this thread, I tend to overthink the criteria a bit.
            *HASS 2025.6.0
              Here's what I have:
              How far off am I?
              3 Offline
              3 Offline
              @gwp1 said in Multiple Holidays, one Ruleset:
              I use a Google Calendar plugin in my Vera controller for the holidays that float around. I/E not always on X day. Labor Day, Memorial Day, Mother's Day, etc. If the gCal device contains the word "Easter", lets say, AND my lights are on, then color them. I used to use PLEG in Vera for this and programing it wasn't as easy as I wished, so I never touched it once I got set. Plus there was a bug with any event that contained an apostrophe. I reported this bug several times, but it remained for several versions. Regardless, this worked flawlessly in RfV, but bogged my Vera down. I also doubled my dates when it because super easy in Reactor. That's what helped bog my controller down. But now I'm on MSR and loving it. And I probably took the color changes a tad too far, but that's why I have them too.
              My color changing days:
              Easter, Mother's Day, Martin Luther King, President's Day, Memorial Day, D-Day, Flag Day, Juneteenth, Independence Day, Labor Day, Patriots Day, Columbus Day, Peral Harbor Day, Valentine's Day, Black History Month (Start of), Cinco de Mayo, Christmas, Women's History Month (Start of), Purple Heart Day, Thanksgiving, Native American Heritage, Halloween, St. Patrick's Day, Veterans Day, and Father's Day.
              Yikes. I may have a problem.
                I have different colors for each holiday 🤣
                I’m using https://www.webcal.guru/en-US/today
                Lots of calendar and very reliable.
                  @therealdb I've never seen that calendar site before - interesting.
                  *HASS 2025.6.0
                  • Gradually turn on lights.
                  • Error After Upgrade
                    RHCPNG
                    931
                  • Links to MSR from HA
                    Tom_DT
                    Tom_D
                  • 🎉 My very first MSR controller: OpenSprinkler
                    920
