  4. Sending HASS notifications from MSR
13 Posts 3 Posters 2.7k Views 3 Watching
  • H Offline
    H Offline
    HansW
    Hello anyone,
    is there a simple trick to send native HASS notifications from MSR? I guess I could call a scene or something with some parameters but I have little experience so would need some clear pointers on this. Thanks in advance!
    F 1 Reply Last reply
    • H HansW
      Hello anyone,
      @hansw Can you give more info? An example? Do you mean push messages to your phone?
      I have all scenes/automations in MSR. Most of my devices comes from HA and Vera, but they are more like radio transmitters (and HA have a nice and useable UI, which I use), and MSR is the brain, where all the good shit happens... 🙂
      Everything the entities can do in HA, they can do in MSR. So why would anyone in their right senses use anything else?
      • H Offline
        H Offline
        HansW
        Yes I mean HASS native push messages to my iPhone. I would ;ike to stay with MSR for my automation instead of diving into the complexity of HASS automation, templates and blueprints but the notify action of MSR is limited to alert, email, prowl, pushover, syslog, callmebot and telegram. I would like to use the native messages and its different interruption levels
          Looking into this...
          • H HansW
            @hansw OK. Latest docker images...
            The system entity for your Hass controller will have an action x_hass_system.call_service. This action lets you call any service. You pass the service data as a JSON string. Here, for example, is how a persistent notification can be sent:
            You can call any service, but you have to know what the service data for that service needs to contain, and you have to supply it (in properly formed JSON).
            • H Offline
              H Offline
              HansW
              @toggledbits holy cow, you are fast! I am going to try this out!
              • H Offline
                H Offline
                HansW
                wrote on last edited by HansW
                @toggledbits, I tried but the hass>system entity is not there. I do have a hass>controller entity but no action to choose from. I am running your container on a qnap though so maybe selecting the latest build had no effect since you didn't rebuild that version? Or I did not manage to update the image in the right way. What I did was stopping the image, creating a new one using the latest-genereric-amd64 build and than starting that new image. It reports: Reactor (Multi-hub) latest-21243-a5028fc
                • H Offline
                  H Offline
                  HansW
                  @toggledbits And as an addition question on this new feature, is there any way to get for instance the friendly name of the trigger into the parameter section? I have for instance 9 doors which I would like to combine into one rule where, if one of them opens or closes, I get a message which tells me which door was opened/closed. It is not a big deal of course, I could easily have 9 rules but still would be nice also for other situations reporting temperatures and such.
                  • H HansW
                    @hansw said in Sending HASS notifications from MSR:
                    It should be 21257
                    You can do it, but it's an exercise for the reader. You'll need expressions. The roots of it would be similar to what is described in this post.
                    H 1 Reply Last reply
                      It should be 21257
                      H Offline
                      H Offline
                      HansW
                      @toggledbits said in Sending HASS notifications from MSR:
                      It should be 21257
                      Thanks. It turns out that to upgrade a container on a QNAP you need to delete the old container first, than delete the image (which is locally stored as well) through the image menu and after that you can create a new image which will than all the real latest from the docker hub. Just specifying to get it from docker hub like I did the first time did not work, it used the locally stored image anyway.
                      • H Offline
                        H Offline
                        HansW
                        @toggledbits Well, I have 21257 running now but still no hass>system entity... Only hass>controller. Should I enable something somewhere?
                          Go to the Entities list, clear the filters, then choose "hass" from the controller filter, and sys_system from the capabilities filter. You should have exactly one entity listed, and that's it.
                            H Offline
                            H Offline
                            HansW
                            Thanks, that did it!
                              137.2k
