  3. MQTT – setup and use
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
107 Posts 10 Posters 72.8k Views 7 Watching
    #98
    I think we are being misled by your error messages. These tables are not empty...
    local x = {a = 1, b = 2}
    local y = table.concat (x)
    print (y == '')
    yields the expected result true.
    • B Offline
      B Offline
      Buxton
      Ah! Yes that explains the empty variable, though I'm going to have to dig into my lua book to understand why! I was assuming that the concat function returned a series of string values from a table, and therefore, the output could be sent to the log for display.
        #100
        It works only for a contiguous array of numbers and/or strings...
        local x = {"a ", 1, " b ", 2}
        print(y)
        gives
        a 1 b 2
        B 1 Reply Last reply
          print(y)
          gives
          a 1 b 2
          B Offline
          B Offline
          Buxton
          @akbooer Ok, so the variable "message " contains more than just a value array.
          I've never been able to get zerobrane as a debugger working with openLuup, though the instructions on how to do so have been written about previously. I just couldn't get the debugger working on a target remote PC, so it's difficult to watch what's going on within the myriad method code in the object model you've created. I don't write code for a living--never have-- though I use SQL, VBA and Python in my day to day job. The debuggers for those languages are a breeze compared to setting up zerobrane and Vera.....
            #102
            Yes, the message structure is an object with various values and methods:
                    -- variables
                    length          = nb,             -- byte count for statistics
                    packet_type     = packet_type,
                    control_flags   = control_flags,
                    body            = body,           -- may include variable header and payload
                    ptr             = 0,              -- pointer to parse position in body
                    packet_name     = pname,          -- string name of packet type
                    -- methods
                    read_bytes      = read_bytes,
                    read_flag_byte  = read_flag_byte, -- converting octet to 8 separate flag bits
                    read_word       = read_word,
                    read_string     = read_utf8,
            It's that way, because MQTT message formats are dependent on the type of message, so the methods contain here do some of that job. However, for the publish / subscribe functions, the topic and message parameters are simple strings, so easy to print out.
            As for debugging, I run the entire openLuup system within ZeroBrane during development, so most things are directly traceable and the debugging facilities are very adequate. I've never, ever, tried to debug a remote system.
            Still keen to discover the cause of your bridged server issue...
            ...have you tried enabling DEBUG of the MQTT module itself? It provides some useful information.
                      -- variables
                      -- methods
              B Offline
              B Offline
              Buxton
              @akbooer Yeah, I've tried debug and there's nothing in the log that helps.
              If you ever do get the notion to connect to a remote instance, let me know the steps as the procedure that was outlined on the vera forum was fairly complex.
              • A ArcherS
                If you have blocked the Shelly in your router from Internet access you probably have to open it temporary for the downgrade.
                I also added my Shelly Button to OpenLuup and for some reason I could not downgrade it, but I managed to get it working anyway after a few attempts.
                (A bit strange since the post I found on the forum was on problems with the Button and v1.10.3.)
                Another tip is to use MqttExplorer if you do not already use it and see if the Shelly shows up there. If it does, then at least the Mqtt part of the Shelly most likely works.
                @archers said in MQTT – setup and use:
                Do we know if this issue has been solved yet?
                I’ll update all my device firmware if so, but I’m loathe to do so without some sort of confirmation. TIA.
                A 2 Replies Last reply
                  ArcherS
                  @akbooer I have not upgraded any of mine so I do not know.
                  This thread and the post from May 14th indicate some Mqtt changes in 1.10.5_RC1. And this thread indicates that 1.10.4 may still have had some problems.
                  Maybe someone else here has tested?
                    ArcherS
                    @akbooer today I set up a new Shelly Plug.
                    The firmware on it was quite old and I thought I would give the latest release a go and see if the Mqtt problem was solved. I loaded "v1.11.4-DNSfix" on the plug and then set up Mqtt as per my other Shellies, then - nothing. It did not show up in Mqtt Explorer at all.
                    I then downgraded to v1.9.4 on the plug and it immediately showed up as it should.
                    I did not dive down into the problem more, I will however stay away from the latest releases for the time being. On my devices v1.9.x does the job and Mqtt works.
                    As a side note I also set up a Shelly Flood that will live under the dishwasher and it seems to work pretty good. The Shelly battery devices are a bit of a pain to set up but I got it to work eventually. I have since before a Button1 that was painfully slow on battery; I run it on USB and then it is ok.
                    After having set up the flood sensor I tested it and it gave an alert as it should only after a few seconds delay.
                      Thanks for the update! I’ve reverted to to a "if it ain’t broke, don’t fix it" approach myself, so haven’t been upgrading the Shelly firmware.
                        154.0k
