  3. Smart devices and mesh
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
1 Posts 1 Posters 786 Views 1 Watching
  • J Offline
    J Offline
    jcocker
    The wifi on my router is turned off, and wifi around the house is provided using a mesh - 3 units altogether (one connected directly to the router) that are spread around the house.
    I would like to start automating certain tasks around the house and intend to try adding a few smart sockets to my setup.
    The mesh system I have supports both 2.4GHz and 5GHz, and does not provide me with the option to control them - i.e. turn one or both on/off, give each a different SSID, etc.
    The devices I wish to purchase/use only support 2.4GHz.
    Will turning the mesh units off and temporarily turning the 2.4GHz wifi on the router to allow me to set them up be enough? Will I then be able to return to my usual setup and everything will work as it should?
    Many thanks in advance
      164.6k
