  4. [Dev] Inheritance in MQTT templates?
40 Posts 4 Posters 14.5k Views 4 Watching
    It also looks like something may be getting a shallow copy when it needs a deep copy, and it's being modified later and polluting the other references. I'm really tied up today, but I'll look at this as soon as I can.
    Did you address the template redefinitions that were being logged at startup? That has nothing to do with primary attributes; the entire template is trying to be redefined.
    No rush!
    @toggledbits said in [Dev] Inheritance in MQTT templates?:
    You mean this?
    <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_door_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_door_sensor.yaml overrides existing template definition zigbee2mqtt_tuya_door_sensor
    If so I don't know what to do about it, it's just the template provided in my earlier post and there is no reference/copy of it in the reactor folder/subfolders that I know of.
      With debug level 5, that message will have another message that follows it to tell you what file originally defined it.
      CrilleC 1 Reply Last reply
        This?
        [latest-24152]2024-06-06T19:29:35.079Z <MQTTController:5:MQTTController.js:941> MQTTController#mqtt loading template defs, considering zigbee2mqtt_tuya_door_sensor.yaml
        [latest-24152]2024-06-06T19:29:35.079Z <MQTTController:5:MQTTController.js:987> MQTTController#mqtt loading YAML template data from /home/homebridge/reactor/config/mqtt_templates/zigbee2mqt
        [latest-24152]2024-06-06T19:29:35.080Z <MQTTController:WARN> MQTTController#mqtt file zigbee2mqtt_tuya_door_sensor.yaml in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_do
        [latest-24152]2024-06-06T19:29:35.080Z <MQTTController:5:MQTTController.js:918> MQTTController#mqtt previously defined in /home/homebridge/reactor/config/mqtt_templates/zigbee2mqtt_tuya_doo
        r_sensor.yaml/zigbee2mqtt_tuya_door_sensor.yaml
          Uh yes... 😆
          Digging in now...
            I need the config for all of your zigbee2mqtt-related entities. Just looking at the one sovrumsdorr, I'm not able to reproduce the problem.
              Config as in reactor.yaml?
                Yes, but just the entities that use the zigbee2mqtt templates. I don't need all of it.
                  #28
                  entities:
                    "zigbee2mqtt_sensor":
                      topic: "zigbee2mqtt"
                      include: my_zigbee2mqtt_sensor
                    "datarummet":
                      topic: "Datarummet"
                      include: zigbee2mqtt_tradfri_light_bulb
                    "sovrummet":
                      topic: "Sovrummet"
                      include: zigbee2mqtt_tradfri_light_bulb_ws
                    "milia":
                      topic: "Milia"
                    "hallen1":
                      topic: "Hallen 1"
                    "hallen2":
                      topic: "Hallen 2"
                    "hallen3":
                      topic: "Hallen 3"
                    "fonster_koket":
                      topic: "Fönster köket"
                    "soffan":
                      topic: "Soffan"
                    "framsida":
                      topic: "Framsida"
                    "skank":
                      topic: "Skänk"
                    "baksida":
                      topic: "Baksida"
                    "lampa_spel":
                      topic: "Lampa spel"
                    "lampa_ella":
                      topic: "Ellas rum"
                    "lampa_gym":
                      topic: "Lampa gym"
                    "lampa_tv":
                      topic: "Lampa TV"
                      include: zigbee2mqtt_tradfri_control_outlet
                    "vitrinskap":
                      topic: "Vitrinskåp"
                    "klimat_sovrum":
                      topic: "Klimat sovrum"
                      include: zigbee2mqtt_aqara_sensor_temperature_humidity
                    "klimat_kaminen":
                      topic: "Klimat kaminen"
                    "klimat_dusch":
                      topic: "Klimat dusch"
                      include: zigbee2mqtt_aqara_sensor_humidity_temperature
                    "klimat_tvattstugan":
                      name: "Klimat tvättstugan"
                      topic: "Klimat tvättstugan"
                    "rorelse_hallen":
                      topic: "Rörelse hallen"
                      include: zigbee2mqtt_aqara_light_motion_sensor
                    "rorelse_kallaren":
                      name: "Rörelse källaren"
                      topic: "Rörelse källaren"
                    "rorelse_forradet":
                      name: "Rörelse förrådet"
                      topic: "Rörelse förrådet"
                      include: zigbee2mqtt_tuya_motion_light_sensor
                    "mini_switch_1":
                      name: "Mini Switch källaren"
                      topic: "Mini Switch källaren"
                      include: zigbee2mqtt_aqara_mini_switch
                    "jul_framsida":
                      name: "Jul Framsida"
                      topic: "Jul Framsida"
                      include: zigbee2mqtt_tuya_smart_plug_pm
                    "jul_koket":
                      topic: "Jul Köket"
                    "jul_sovrummet":
                      name: "Jul Sovrummet"
                      topic: "Jul Sovrummet"
                    "jul_datarummet":
                      name: "Jul Datarummet"
                      topic: "Jul Datarummet"
                    "element_gillestugan":
                      name: "Element gillestugan"
                      topic: "Element gillestugan"
                    "vaxtbelysning_kallare":
                      topic: "Växtbelysning källare"
                    "kompressor":
                      topic: "Kompressor"
                    "luftrenare":
                      topic: "Luftrenare"
                    "uttag_uterummet":
                      name: "Uttag uterummet"
                      topic: "Uttag uterummet"
                    "sovrumsdorr":
                      topic: "Sovrumsdörr"
                      include: zigbee2mqtt_tuya_door_sensor
                    "entrebelysning":
                      topic: "Entrebelysning"
                      include: zigbee2mqtt_tuya_light_bulb_rgbcw
                    "lampa_uterummet":
                      name: "Lampa uterummet"
                      topic: "Lampa uterummet"
                  EDIT: unrelated, found entity id "jul_köket" and renamed it to "jul_koket" in post and Reactor.
                    OK. I also need the definitions for zigbee2mqtt_tradfri_light_bulb and all of the other templates not in the common file you previously posted.
                      Wait... are those just available on Github? Are your current versions published in any branch there? If so, I'll just grab them from there.
                        No I haven't published them due to this issue but I can put them in the test branch, hold on.
                          Available in zigbee2mqtt_test.zip
                            Looks like MQTTController 24159 solved it. I don't see any errors or warnings in the log after a restart, except all of these but I quess that's normal?
                            <MQTTController:WARN> MQTTController#mqtt file /home/homebridge/reactor/config/ext/MQTTController/templates/tasmota.yaml overrides existing template definition tasmota_generic_relay from /home/homebridge/reactor/config/ext/MQTTController/templates/tasmota.yaml
                              No not normal, and I don't get those.
                                Strange! I wonder what’s causing that in my setup then as it’s the integrated templates as well.
                                  Are you running more than one instance of MQTTController?
                                    Ah yes, one for openLuup and one for Mosquitto
                                      OK. Try 24160
                                        Yep, all warnings gone! Thank you for all your work!
                                        • ? Offline
                                          ? Offline
                                          A Former User
                                            148.5k
