  4. [SOLVED] reactor_inet_check script... and containers
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
9 Posts 3 Posters 2.5k Views 3 Watching
    When on my bare metal RPi with MSR I had a rule that ran every minute to check Internet status via a script in MSR called reactor_inet_check.sh
    I've moved to containerized MSR and see in the instructions that this cannot be run from the container.
    The script cannot run within the Reactor docker container. If you are using Reactor in a docker container, the script needs to be run by cron or an equivalent facility on the host system (e.g. some systems, like Synology NAS, have separate task managers that may be used to schedule the repeated execution of tasks such as this).
    I've put a script on my container host that calls the reator_inet_check.sh script and it isn't erroring... but I still see the internet status within MSR as null.
    Before I go diving down the rabbit hole... should this work?
    My cronjob on the proxmox host:
    The contents of msr_internet_check_caller.sh
      OK, first, please don't screen shot text, especially code, logs, and scripts. Learn to use fenced code blocks: put three back-ticks ``` on a line by itself, then follow with the text, the close with another three back-ticks ``` on a line by itself. When formatted, it will look like this:
      #!/bin/bash
      # Execute the script inside the container
      pct exec 101 -- bash -c "cd /home/reactor/reactor;./reactor_inet_check.sh"
      The path for the script is suspicious and likely wrong. The reactor_inet_check.sh script has to be run from the Reactor install directory, and doing so would give you a script run path of ./tools/reactor_inet_check.sh. The script is built to run only this way. That's in the script header's instructions.
      But also, you are trying to run the script from the Proxmox host, which I guess you can do, but it's unnecessarily hard and makes the configuration dependent on the VMID. I recommend that you run it from Ubuntu. All that's required is this in your Ubuntu root crontab:
          * * * * cd /home/reactor && ./tools/reactor_inet_check.sh
      The Ubuntu /var/log/syslog should have information about the success of those runs.
      If you're using Reactor access control (i.e. you are configured to required login to access Reactor), you probably will also need to add an ACL to permit the script to use the API.
        #!/bin/bash
        @toggledbits I know how to tick code - I just didn't think at that hour it would be necessary. Apologies.
        Because, YES, trying to configure this from the Proxmox host is devilish, I've added this now to Unbuntu root crontab with:
        sudo crontab -e
        # MSR script to perform internet check every minute
        * * * * * cd /home/reactor/reactor && tools/reactor_inet_check.sh
        Looking into the ACL now as I do have Access Control enabled.
        EDIT
        Taking things in smaller bites... I've renamed users.yaml so Access Control is disabled. Let's start easy 🙂
        Cron is running. To me, this reads like it's running just fine.
        2025-01-18T13:08:01.129250-05:00 msr CRON[21717]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:09:01.161220-05:00 msr CRON[21737]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:10:01.223057-05:00 msr CRON[21769]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:10:18.126046-05:00 msr systemd[1]: Starting sysstat-collect.service - system activity accounting tool...
        2025-01-18T13:10:18.131608-05:00 msr systemd[1]: sysstat-collect.service: Deactivated successfully.
        2025-01-18T13:10:18.131786-05:00 msr systemd[1]: Finished sysstat-collect.service - system activity accounting tool.
        2025-01-18T13:11:01.254645-05:00 msr CRON[21797]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:12:01.315036-05:00 msr CRON[21821]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        2025-01-18T13:13:01.347216-05:00 msr CRON[21844]: (root) CMD (cd /home/reactor/reactor && tools/reactor_inet_check.sh)
        Looking at the Reactor System Entity, however, I still see
        reactor_system.internet_ok=null
          sudo crontab -e
          EDIT
          @toggledbits Most days I'm not very smart... but I'm stubborn.
          This is working.
          It has kept working thru multiple MSR restarts. (I have not yet tested a container restart.)
          I'm not 100% sure why it's working, tbh. I think one more MSR restart cleared the cobwebs and it was suddenly fine. I then added an ACL before putting back Access Control which brings me to...
          I also have Access Control back in place and using a hashed pwd (which for some reason eluded me when I tried to enable it previously.)
          On this day we're calling it "Two steps back, three forward."
          Thanks for your help as always.
            This is working.
            @gwp1 said in [SOLVED] reactor_inet_check script... and containers:
            It's good to know I'm in good company.
              A worthy quality
                @gwp1 any chance you could share the script?
                TIA
                  TIA
                  @CatmanV2 reactor_inet_check.sh and it's in your Reactor /tools directory. You don't touch it, just call it.
                  Then pull the output into a rule
                  13d46371-bc40-4cf9-a481-83ca28d1025d-image.png and trigger whatever alerting you'd like.
                    Oooh thanks!
                      162.8k
