  4. Preview of Multi-System Reactor
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
58 Posts 11 Posters 27.3k Views 11 Watching
  • LibraSunL LibraSun
    Dang, I just jetted back here to declare my idea #1 as "dumb" but thankfully you beat me to it. Individual Rules already have their own (manual) enable/disable anyway. Dunno what I was talking about. 🙂
    toggledbitsT Online
    toggledbitsT Online
    @librasun said in Preview of Multi-System Reactor:
    I don't think that's at all dumb, and it makes a lot of sense, depending upon, as you said in your follow-on post, what schema you choose for your rules. So far, I've gone with one rule set per room, just leaving the mapping established by the importer. Particularly when getting the rules moved from RFL to MSR, I often had to disable an entire room's (rule set's) rules until I got something fixed.
    It's not a bad idea at all.
      May I also just add that I appreciate how a Reaction can "Stop" itself? Could be a powerful debugging tool when needed.
        #23
        LEARNED SOMETHING TODAY
        1. You can click-and-drag Rules to reorganize them in Rulesets. Who knew?
        2. You cannot, however, click-to-highlight the Rule ID of an expanded rule, in order to copy that text.
        3. Setting an Expression := away is entirely different from := "away". The first evaluates to (null) if no such named Global exists; the second evaluates to the string "away".
        #2 would be hugely helpful for times when you need to troubleshoot the Reactor.log. (I understand CSS and HTML, but don't know the correct term for "object not swipable" -- is this a side-effect of, say, a very high z-index on that block element?).
        As for #3, I foolishly thought MSR's expression parser, lexpjs, was meant to typecast unknown objects (away ► "away") but that was a n00b miscalculation.
        • toggledbitsT Online
          toggledbitsT Online
          Looks like #2 is a limitation of "sortable" objects in jQuery UI. The sortable takes over all clicks and drags. I'll keep poking for workarounds, but don't get your hopes up.
            re: #2 it might then be helpful to replicate the Rule ID within the Edit view of each Rule?
              toggledbitsT Online
              toggledbitsT Online
              You can do the same with Rule Sets... organize them in any order you wish.
                toggledbitsT Online
                toggledbitsT Online
                Why do you need the rule ID?
                  Armed with the unique Rule ID, one can (somewhat more) quickly do a "FIND" in Notepad while looking at REACTOR.LOG
                    toggledbitsT Online
                    Got it. Name is also logged, although not as frequently in the debug levels.
                    It looks like the only way I can avoid the complete takeover of mousedown by the draggable/sortable is to use a drag handle, e.g. an icon on which you click and drag to move the row. That's done elsewhere, so it would be consistent. I can see other reasons in future to want to interact with the detail card, so I'm leaning towards it right now.
                      FEATURE REQUEST(?)
                      Place a warning in Global Expressions area that "These are not to be used as stand-alone Triggers. Will not be evaluated unless called from another resource (e.g. Rule-based expressions)."
                      And if this assumption is accurate (I could be misinterpreting? Rules just didn't seem to fire unless they have another in-house Trigger or local copy of said Variable), then also warn in Rules for which there is only a Global Expression and nothing else Trigger'ing it.
                        MSR USAGE QUESTION
                        Is there a (straightforward) way to do Dev# substitution into the new way (e.g. getEntity( "vera>device_216" ).attributes.battery_power.level) that attribute values get referenced in MSR?
                        Back on Reactor for Vera, I used to iterate over getstate( DeviceNum, "urn:micasaverde-com:serviceId:HaDevice1", "BatteryLevel" ) to derive the current battery levels on various devices. And I'd somewhat hate to have to hard-code or write out all of them by hand if I don't have to in MSR.
                          Matteburk
                          Could you share a rule for one Room so we can see how it could look like with multipel reactions that has different conditions.
                          I Don’t really understand how multipel reactions on diffrent conditions should look like. In Reactor it was easy to understand but in msr i Don’t get it..
                          I really Wanja make more complicated automations but Iam stuck with one reaction...
                          / Mattias
                          • M Matteburk
                            / Mattias
                            Tarkus
                            @matteburk Did you do an import of your Vera reactor sensors? It is different in MSR but I compared the MSR imported rules vs Vera reactors and it helped me figure out what was going on.
                            M 1 Reply Last reply
                              toggledbitsT Online
                              There are no reactions on groups in MSR. Reactor for Vera allowed you to create activities (its equivalent to reactions) on any group in your ReactorSensor.
                              So, if you are creating a rule with subgroups in MSR, and you decide that the subgroup needs to perform some actions, you have export that subgroup to a Rule of its own. There is a button for that. If you click that button on a group (to the right of the group name), it will export the group to a Rule, and replace the group with a "Rule" condition for the new rule so the logic remains intact in the current rule.
                                Matteburk
                                @toggledbits@toggledbits Ok Then I understand but I cant find the button... I have Button,rename and collapse and then som shaded row...
                                  toggledbitsT Online
                                  Are you on 21075? Version number in the upper-right corner.
                                  M 2 Replies Last reply
                                  • T Tarkus
                                    Matteburk
                                    @tarkus I dont use reactor anymore on my Vera Plus... I Jumped the ship a year ago to hubitat..
                                      Matteburk
                                      @toggledbits yes... Sorry... will update asap My bad!
                                        Matteburk
                                        @toggledbits On 21075 now and it works (button found) 🙂 Thanx! Lets rock on!
                                          #40
                                          FEATURE REQUEST
                                          Consider Including CallMeBot among the Notification classes, with the following parameters available for editing in notification.yaml:
                                          base_url=http://api2.callmebot.com/start.php
                                          source=vera
                                          user=@<user_name>
                                          text=<default_msg>
                                          lang=en-US-Standard-C
                                          rpt=2"
                                          Of course, the text parameter can be overridden in Reactions and probably should not have a default setting come to think of it. IIRC, usernames correspond to the user's Telegram account nickname.
                                            163.3k
