  3. Vera TTS and negative temperatures
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
7 Posts 4 Posters 1.6k Views 4 Watching
    Hi all. Well winter is coming and temperatures are below freezing. I currently have this snippet of Lua:
    local GardenTemp = math.floor(0.5+luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 20415))
    luup.call_action("urn:dlna-org:serviceId:DLNAMediaController1", "Say", {Text="The temperature outside is" ..GardenTemp.. "degrees.",Volume=40,GroupZones="Everywhere"}, 22)
    When we turn the house on. Anyone help me to get it to say 'negative' or 'minus' when the temperature is actually sub-zero?
    TIA
      I have been getting negative numbers without any problem. It depends on the TTS engine you are using. MacOS reads "minus". What issues are you seeing?
        GardenTemp = tonumber(GardenTemp)
        if (GardenTemp < 0) then
            GardenTemp = "minus " .. (-GardenTemp)
          @rafale77 said in Vera TTS and negative temperatures:
          Ahh sorry this is the Alexa TTS. We just get the number.
            So
            TIA
              hey @CatmanV2 just use announcements (see readme). Plus, they've recently released a new conversational voice that's more natural. Just use this:
              luup.call_action("urn:dlna-org:serviceId:DLNAMediaController1", "Say", {Text='<lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is ' ..GardenTemp.. ' degrees.</amazon:domain></lang>',Volume=40,GroupZones="Everywhere"}, 22)
              This conversational voice is able to read numbers, puntuaction and others things waaayyy better. Try it and let me know 😉
                @therealdb said in Vera TTS and negative temperatures:
                Thanks, annoyingly AlexaTTS is currently non-functional for me. Not quite sure why. I assumed cookie expiration, but it's forced me to change my password and the new cookie does not appear to work.
                But nothing showing in the logs 😞
                  155.6k
