  3. Vera TTS and negative temperatures
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
iCOMEN boiler switch
Forum sysops
I run a B&B and am looking for a way to turn the lights off whenever a room is unoccupied for X amount of time. The guest should still be able to turn the lights on and off manually, but should not be able to disable the auto turn off feature if the room is unoccupied. I guess I am looking for a light switch with a built in presence sensor? I guess a presence sensor would be better as if it is a motion sensor, the lights may go off unwanted if the guest fails to make sufficient movement e.g. if the guest is lying down watching a film. Are there any products on the market that would work for my application?
Looking for Bluetooth device for smartphone audio transmission
Hello, I am in search of a device capable of using Bluetooth to connect with a smartphone and serve as its primary sound source on demand. This device should function similarly to conventional Bluetooth headphones, which automatically become the phone's sound output upon activation. However, this device should differ in that it transmits the audio signal to an amplifier via a jack, SPDIF, or similar connection. Alternatively, it could be an integrated amplifier that directly sends the signal to passive speakers. The control of this process should be manageable through an API such as MQTT, REST, MODBUS, or similar. Are you aware of any devices that operate in this manner? The concept is as follows: upon entering the bathroom, I would press a wall-mounted switch. This switch would send a signal to the Bluetooth device, prompting it to connect to my smartphone and seamlessly continue playing the audiobook I am currently listening to. Instead of using the phone's speakers, it would seamlessly start playing through ceiling-mounted speakers. Many thanks
Beginner assistance
Hi folks, I currently have some cheap Zigbee hub and some Amazon Alexas running my smart home which mostly consists of Zigbee power strips and Zigbee battery powered switches. It all worked OK originally, but now whenever I press a Zigbee switch the light in the corresponding plug switches on then immediately off again. If I ask Alexa to turn the light on it works fine. Likewise if I switch it on from my phone. Any ideas what the issue could be? I've tried unplugging the hub a number of times but that doesn't seem to fix it. I was thinking about getting a Homey Pro 2023 to speed things up (tmas the Zigbee hub seems to be really slow now as well, for some reason) but I'm not sure about that either. Any suggestions greatly appreciated!
7 Posts 4 Posters 319 Views 4 Watching
    Hi all. Well winter is coming and temperatures are below freezing. I currently have this snippet of Lua:
    local GardenTemp = math.floor(0.5+luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature", 20415))
    luup.call_action("urn:dlna-org:serviceId:DLNAMediaController1", "Say", {Text="The temperature outside is" ..GardenTemp.. "degrees.",Volume=40,GroupZones="Everywhere"}, 22)
    When we turn the house on. Anyone help me to get it to say 'negative' or 'minus' when the temperature is actually sub-zero?
    TIA
      I have been getting negative numbers without any problem. It depends on the TTS engine you are using. MacOS reads "minus". What issues are you seeing?
        GardenTemp = tonumber(GardenTemp)
        if (GardenTemp < 0) then
            GardenTemp = "minus " .. (-GardenTemp)
          @rafale77 said in Vera TTS and negative temperatures:
          Ahh sorry this is the Alexa TTS. We just get the number.
            So
            TIA
              hey @CatmanV2 just use announcements (see readme). Plus, they've recently released a new conversational voice that's more natural. Just use this:
              luup.call_action("urn:dlna-org:serviceId:DLNAMediaController1", "Say", {Text='<lang xml:lang="en-UK"><amazon:domain name="conversational">The temperature outside is ' ..GardenTemp.. ' degrees.</amazon:domain></lang>',Volume=40,GroupZones="Everywhere"}, 22)
              This conversational voice is able to read numbers, puntuaction and others things waaayyy better. Try it and let me know 😉
                @therealdb said in Vera TTS and negative temperatures:
                Thanks, annoyingly AlexaTTS is currently non-functional for me. Not quite sure why. I assumed cookie expiration, but it's forced me to change my password and the new cookie does not appear to work.
                But nothing showing in the logs 😞
                  37.0k
                • Z-Wave Future....
                • Can´t restart or upgrade/deploy MSR
                • [Solved] Limit HA Entity in MSR
                • Disaster recovery and virtualisation
                • Remote access of Zwave stick from Z-wave server
                • Organizing/ structuring rule sets and rules
                • Moving MSR from a QNAP container to RP 5 - some issues
                • Widget deletion does not work and landing page (status) is empy
                • Need help reducing false positive notifications
