  3. Raspberry Pi - Cron Jobs for Lua scripts ?
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
6 Posts 2 Posters 1.7k Views 2 Watching
  • parkercP Offline
    parkercP Offline
    parkerc
    I’ve got a few Lua scripts that I’d like to run periodically on my Pi, and I’ve tried to get them to run via Cron, but I can’t seem to get them to work..
    Does anyone have anything similar set up that works ?
    Crontab -e
    I’ve tried it a couple of ways based on the forum posts I’ve read, but neither have worked..
    0 0 * * * home/pi/shared/TS_cabin_graph_email_24h.lua
    0 0 * * * /usr/bin/lua /home/pi/shared/TS_cabin_graph_email_24h.lua
      Look in /var/log/messages for errors logged by the cron daemon.
      You can also add output redirection to your commands to capture any output or errors and use that for debugging:
      0 0 * * * /usr/bin/lua /home/pi/shared/TS_cabin_graph_email_24h.lua >/home/pi/email.log 2>&1
      The >filename addition redirects stdout (normal output/messages) to the given filename instead of whatever default console. The 2>&1 redirects file descriptor #2, which is stderr (the error output stream), to file descriptor 1, which is stdout (that normal message stream, which is now your open file).
      • parkercP Offline
        parkercP Offline
        parkerc
        Thanks @toggledbits that helped, and the error in the log is below.
        usr/bin/lua: /home/pi/shared/TS_cabin_graph_email_24h.lua:10: home/pi/shared/feed24h.csv: No such file or directory
        stack traceback:
        ��������[C]: in function 'assert'
        ��������/home/pi/shared/TS_cabin_graph_email_24h.lua:10: in main chunk
        ��������[C]: ?
        All my scripts worked before when they were being run manually from the root folder, how do I need to update them when run by the Cron daemon ?
          It looks like you are missing the leading "/" from the pathname of your CSV file.
          • parkercP Offline
            parkercP Offline
            parkerc
            Thanks @toggledbits that was it..
            Why would it not report an error when I was running the same script manually ?
              If I had to guess, because you were testing it while in the root (/) directory. That would be pretty much the only way it could work.
                133.9k
              • Logon screen timeout
