  4. MSR Import Bug
MSR Import Bug
    Tarkus
    wrote on last edited by Tarkus
    Not sure if this was addressed yet but going thru my imported Vera Reactor setup I noticed all the reaction entity power states that were off in Vera Reactor were set to on in MSR.
      When did you last run the import?
        Tarkus
        I think my import went back to build 21058 or there about.
          Tarkus
          I had some questions on importing in this forum on the day I ran the import so I went back to that thread and it was 17 days ago.
            Ah. OK. I think that was fixed at the time, and then since, there's the new service model which gets more actions and variables right than the old.
            You can re-run the import and it will fix/redo the rules from the backup, and leave any new rules you've created untouched, but if you've modified the imported rules in the last 17 days, and you want to preserve those changes, I don't recommend it. If you decide you want to try, I recommend you back up your existing rules just by stopping MSR and making a copy of the storage subdirectory somewhere. If it all goes pear-shaped, you can just restore that copy (copy it back) and you'll be right back where you were.
              Tarkus
              @toggledbits Yeah I made too many changes to re-import at this stage. It was easy enough to change the entity states that were incorrect. All is good. I did have some weirdness with adding a virtual dimmer expression. I will put in a PR for that.
                146.8k
