  3. Easy way to convert to SSD from SD card on Pi with MSR
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
9 Posts 4 Posters 2.7k Views 4 Watching
    Matteburk
    So have been migrating a bunch of automations to MSR from Hubitat and no I feel like I want to have an SSD instead of SD card on my Pi3.What is an Easy way to convert to SSD from SD card on Pi with MSR. What files do I need to copy to keep my rules?
    /Mattias
      The instructions below seem to be the most current. The procedure copies everything, so it will automatically pick up your Reactor configuration, logs, etc.
      But there are two three important caveats in using them:
      1. When you get to running "SD Card Copier" (step 15 at this writing), make sure the checkbox "New Partition UUIDs" is off. This is shown in the screen shot but not mentioned in the text, and if it's checked, your copy won't boot.
      2. Only certain SSD adapters work. The list of known working adapters is also linked below. Be very careful about model names and numbers (e.g. the Sabrent 3.0 to SSD model EC-SSHD does not work, while the similarly-named Sabrent 3.1 to SSD model EC-SS31 does work (I use this one, no problems).
      3. Some of the screens shown in the firmware configuration have changed slightly, so you may need to hunt for the setting the instructions are trying to get you to... stay calm and search on... just wander the menus. The right words are still there, just moved, so you'll know when you find them.
      Instructions:
      Jul 24, 2021  /  Raspberry Pi
      How to Boot Raspberry Pi 4 / 400 From a USB SSD or Flash Drive
      A firmware update lets you use any USB device to boot a Pi 4 / 400.
      Known Working Adapters:
      Jun 29, 2019
      Raspberry Pi 4 USB Boot Config Guide for SSD / Flash Drives
      The Raspberry Pi 4 is finally here and has a lot of exciting changes. One very major downside is that it doesn’t support true USB booting yet out of the box (like the 3 series did).
      MatohlM 1 Reply Last reply
        Instructions:
        Jun 29, 2019
        MatohlM Offline
        MatohlM Offline
        Matohl
        @toggledbits Are the instructions valid for RPi3 as well as @Matteburk is referring to being his unit? I have not checked since I only use RPi4's. I think the big gain is when you have the SSD connected to USB3.
        • M Matteburk
          /Mattias
          ArcherS
          @matteburk if you have a Pi 3B+ then you are in luck since it will boot from USB without doing anything.
          If it is a Pi 3B then you have to change a "USB boot bit", see e.g. this instruction.
          I took the easy route and bought a new Pi 3B+ when I moved my Z-way server to SSD from SD. They are quite cheap anyway and I guess I can get use of the Pi 3B for something else later on.
          As @toggledbits says the Pi's are a bit picky on SSD adapters. I had two old 2.5" cases laying around, one worked and the other did not. The SSD migration cable that came with a Samsung SSD that I used for another PC also works.
          Edit: And if you buy a new Pi 4 they should now also have USB boot out of the box. Assuming the box has not been sitting on the shelf in the store for too long of course. 🙂
            Ahh... right... I would guess not. I haven't tried on a 3.
              Matteburk
              Thanx for all answers.... I had an old PI3 and ofcouse ordered wrong data usb cable so I had to order a new one and then I took a Pi4 also...
              • M Matteburk
                MatohlM Offline
                MatohlM Offline
                Matohl
                @matteburk Since you live in Sweden, you could find it in your local Kjell&Co store. I use Samsung 870, 250G (62906) and SATA-USB3 adapter (61199). Works great.
                • MatohlM Matohl
                  Matteburk
                  @matohl Thanx.. But i ordered it from Amazon.se already 😃
                    Matteburk
                    FYI I got the RPi 4 with ssd up and running and cloned sd card . Thanx to all!
                      164.4k
