  4. Can someone explain for me how to use Reset reaction in MSR without disturbing other rules.
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
34 Posts 4 Posters 11.3k Views 4 Watching
    Matteburk
    With these 2 rules and mode is evening or day and rule 2 is triggered light is turned off after 120s by rule 1
    Rule 1 :Bathroomlight is turned on and dimmed to 20% if motion (follow,delay reset 120s) is true and Night mode is on
    Reset Reaction: turn off light.
    RUle 2: Bathroomlight is turned on and dimmed to 100% if motion(follow, delay reset 600s) is true and day or Evening mode I true
    Reset Reaction: Turn off light
    How do you turn off lights in similar cases without disturbing other rules with same sensors...
    /Mattias
    CrilleC 1 Reply Last reply
    • M Matteburk
      /Mattias
      CrilleC Online
      CrilleC Online
      @matteburk My guess is that Rule 1 is somehow also triggered, I would use Contraints to make sure they only fire when they are supposed to. I'm still learning Constraints but have similar Rules where schedules, motion sensors, lux and house mode is involved and got that set up but can't really explain very good as it's more of a trial and error for me at the moment 🙂
      The documentation is mixing Conditions and Constraints which for me is opposites and I'm mixing a lot of NOT's to make it TRUE and FALSE in the correct places.
      M 1 Reply Last reply
      • CrilleC Crille
        Matteburk
        @crille yes i understand but you cant have constraints for Reset Reactions. Only for Reactions.
        I’m not friend with MSR at them moment but I know it’s just something I understand wrong... Gaaah drives me nuts!
        • M Matteburk
          CrilleC Online
          CrilleC Online
          @matteburk Yes, the Constraints would block the Reaction in Rule 1 to run, thus will Reset Reaction in Rule 1 not run.
            @toggledbits I think it's becoming apparent that users might interpret Constraints in one of two diametrically opposite meanings. Some might think for example that a TRUE constraint condition will prevent the rule from continuing to run. Others, more correctly in my opinion, will understand that a constraint condition must be TRUE in order for the rule to run.
            I wonder if there could not be some clarifying language in the user interface?
              I'll refer to the documentation, and you can tell me if it's clear enough or still needs work: https://reactor.toggledbits.com/docs/Rulesets/
              Also, it would be good to have the full rules posted in this thread. The descriptions of what the rules look like just leave too much room for interpretation. Let's see what's actually being done.
                Matteburk
                wrote on last edited by Matteburk
                  Matteburk
                  • M Matteburk
                    CrilleC Online
                    CrilleC Online
                    @matteburk I think you need to put AND in top level for the triggers for Rule 1.
                    • CrilleC Crille
                      Matteburk
                      @crille saw that , have been experimenting so got a typo... but still same problem for me anyway
                        Matteburk
                        Rule 1
                        @toggledbits Here are screenshots
                        Rule 1
                        Skärmavbild 2021-03-28 kl. 18.23.09.png Skärmavbild 2021-03-28 kl. 18.23.22.png
                        Rule 2
                          OK, that's a start, I guess, although they are barely readable. Maybe we'll need to go back to some kind of Logic Summary-like thing.
                          Now, what are these supposed to do, and what is the problem you are having with them?
                          • M Matteburk
                            Rule 1
                            Rule 1
                            Rule 2
                            CrilleC Online
                            CrilleC Online
                            @matteburk I would still put condition "natt"/"dag" and "kväll" in Constraints as it's not a trigger, rather a condition and would prevent Reaction/Reset Reaction to run.
                            Edit: Clarification for future readers. Forcing the Constraints condition to go FALSE prevents the SET/Reset Reaction to run.
                            toggledbitsT M 2 Replies Last reply
                            • CrilleC Crille
                              @crille said in Can someone explain for me how to use Reset reaction in MSR without disturbing other rules.:
                              No, that's not how Constraints work. Constraints do not prevent Reset reactions.
                                CrilleC Online
                                CrilleC Online
                                @toggledbits No, but it will prevent the Reaction to run, thus the Reset Reaction?
                                  Matteburk
                                  Rule 1 is 1 motion sensor I Master bedroom and 2 motion sensors in bathroom that if any is true (delayed reset 120s)and Natt mode is true master bedroom light and bathroom light is turn on. Reset reaction turn off
                                  Rule 2 If any of the 2 motion sensors in bathroom is true(delayed reset 600s) and dag or kväll mode is true bathroom light is turned on . Reset reaction turn off
                                  • CrilleC Crille
                                    THAT is true, so we need to be careful how we phrase it, because your other statement is incorrect and misleading, and would give other readers the wrong idea. But you are correct in the last: if the SET reaction does not run, neither can the RESET, because RESET will only follow SET (once the basic state of the rules has been established).
                                    • M Matteburk
                                      @matteburk And the problem?
                                        Matteburk
                                        The problem is when rule 2 is set and reset is delayed 600s rule 1 is being resetted by reset reaction in it and lights go of in 120 s instead of 600s as it should
                                        • CrilleC Crille
                                          Matteburk
                                          @crille I know. that's how I normally think but I have tried this to get around my problem.... 🙂
                                            165.3k
