  4. Hubitat and virtual devices
5 Posts 3 Posters 2.1k Views 3 Watching
  • MikeReadingtonM Offline
    MikeReadington
    Hi Everyone,
    I setup a Hubitat device for the first time tonight. The MSR/Hubitat documentation was easy to follow, and it appears to have connected hassle free to MSR.
    Under the Hubitat entities list I see:
    A Hubitat Elevation system
    hubitat
    Mode
    Safety Monitor
    (I do get a last modified stamp and green activity flash when the hub reboots)
    I do not have any physical devices on the hub yet, so I added a few virtual devices to do some testing.
    Should virtual devices show up in entities?
    Thanks,
    Mike
      Matteburk
      Yes they should.
        One of the weaknesses of Hubitat is that you have to tell it, on the Maker API app page, what devices are visible through the API. That means every time you add or create a device, you have to go to the Maker API and publish it.
        Documentation: https://reactor.toggledbits.com/docs/ControllerConfig/#hubitatcontroller
        MikeReadingtonM M 2 Replies Last reply
          MikeReadington
          Thanks guys,
          Yep, @toggledbits, I went to the Maker API app after device creation and selected the devices, but they were not selected when I went back there today. I reselected the devices, restarted MSR, and everything is as expected. Looking at the interface, I think I missed hitting the update button before I left the page.
          Ok, back to messing around.
          Thanks again
            Matteburk
            wrote on last edited by Matteburk
            @toggledbits Yes it is but its just to toggle all off and then on so it goes quite fast.. But in Hubitat dashboard its the same thing. Because if you have all devices enabled for a dashboard it loads slower. Then they have made it so you can enable the ones you want in a dashboard. This really sucks when you make dashboard with a lot of specific devices.
              1.1k
              158.4k
