  4. Rule for devices battery level ?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
43 Posts 6 Posters 17.2k Views 7 Watching
  • CrilleC Crille
    @toggledbits I'm trying to understand the pros and cons of using this vs the new DynamicGroupController, could you give a short summation?
    Hi @crille !
    In this post we are having this discussion about Dynamic, I am having a hard time getting it to work, but it will be very good, the concept is great and this will make it much easier.
    https://smarthome.community/topic/793/multidimensional-array/17?_=1638031443562&loggedin=true
    CrilleC 1 Reply Last reply
    • wmarcolinW wmarcolin
      Hi @crille !
      @wmarcolin Yes, but the goal seems to be the same so what's the pros of doing it in the DynamicGroupController? More efficient, more dynamic, less complex etc, than a global expression like the one above?
      I'm all up for new improved ways of doing things just need an explanation of why 🙂
      wmarcolinW 1 Reply Last reply
      • CrilleC Crille
        @crille
        In my opinion, everything you put in: more efficient, more dynamic, less complex. Below is a screenshot of how I do it today, and it would be replaced only by the format expression already directly inside a message as per telegram.
        I will also use it to easily know all the devices that will be tripped in the house, see the other post for what I am adding after the battery. Besides this, unifying devices that for example are triggered by a contact or movement and have different expressions, will help unify and set up the alarm trigger management.
          162.3k
          1.3k
