  4. Why can't I run this LUA code ?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
9 Posts 3 Posters 1.7k Views 3 Watching
    I have created a Global Reaction with this LUA code for my Vera to run.
    However when I run the Reaction nothing happens. I can't see anything in the log file either about this rules ID number.
    If I run the same LUA code on Vera in the test window it works OK.
    OR any other suggestions how I can set this up in a global Reaction (Scene) in MSR ?
    Instead I could use the VeraScenes.lua file in the Vera startup library, but I am wondering why I can't just paste the LUA code directly in to the MSR rule.
    local status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", 419) --Status of Safe to Arm virtual switch
    if status == "0" then --Safe to Arm
      luup.inet.wget("http://SOME-HTTP-REQUEST")
      luup.call_action("urn:micasaverde-com:serviceId:HomeAutomationGateway1","SetHouseMode", {Mode = 2}, 0) --Set House Mode to Away
      luup.inet.wget('SOME-HTTP-REQUEST' ,5);
    else --Not Safe to Arm
      luup.inet.wget("SOME-HTTP-REQUEST")
    LibraSunL 1 Reply Last reply
      Have you looked at the contents of your LuaUPnP log file?
      cw-kidC 2 Replies Last reply
        No I will try again and check it.
          @toggledbits said in Why can't I run this LUA code ?:
          I am not seeing anything at all in the Vera LuaUPnP log after running the Global Reaction with the above lua code.
          No job is started.
          However if I change the lua code to just a one liner to do a TTS announcement for example, then that does work OK and I see it happening in the Vera log also.
            Are you running firmware 7.32 in the 5350 range? If not, what firmware are you running?
              Production Vera Plus is firmware version 1.7.5186 (7.31)
                I tried running this code on my Vera Edge which is version 7.32 and same thing, nothing happens and nothing in the Vera log either.
                • cw-kidC cw-kid
                  @cw-kid I don't know much Lua, but what determines when you do or don't include a semicolon at the end of a statement? Seems irregular to my eye.
                  • LibraSunL LibraSun
                    @librasun
                    Both of these work OK on the Vera unit itself.
                    The one with the semi colon has a time out set.
                    I have tried making both HTTP requests one or the other / the same, but that's not the problem.
                    The problem is the LUA code is just not run on the Vera at all when initiated from the MSR rules Set Reaction.
                      163.7k
