  4. Having media player tell the states?
5 Posts 2 Posters 1.3k Views 2 Watching
  • F Offline
    Hi!
    In HA it's possible to have a media player tell the state of a entity, like this:
    service: tts.google_translate_say
    data:
      message: "Temperature is {{states('sensor.temperature')}}."
      cache: false
    I tried to do the same in MSR, but I didn't succeed. Is it possible - if so; how?
    /Fanan
      What did you try?
      F 1 Reply Last reply
        What did you try?
        I tried it with and without the " ". Like this (example without it):
        Don't know what else to try?
        • F Fanan
          @fanan You're on the right track. What you're doing wrong is that you're trying to use Home Assistant's substitution syntax in Reactor. You need to use Reactor's substitution syntax (and expression functions and syntax) in a substitution in Reactor. You will need to use the getEntity() function in your Reactor expression, and then navigate through the entity's data to the desired attribute. That will look more like this:
          Note that the argument to getEntity() is either an entity name (if it's unique), or a canonical ID (as shown here; canonical IDs are shown in the Entities list in left nav).
          • F Offline
            I see! Great help - as always! I'm greatful for all the support you giving!
              160.0k
