authtrack:
max_attempts: 4
EDIT: some logs
reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
House mode change not registered
@toggledbits MSR both stable and latest does not pick up a house mode change in openLuup. If I create an expression it states "home" even if openLuup is in night and my test rule to notify when house mode changes never picks up the change. Nothing is logged when I change house mode either.
On Vera Luup, when the house mode changes, a
statusrequest will return withUserData_DataVersionupdated. This is a signal to the API client that the user data has been changed and needs to be reloaded. It looks like openLuup does not do this, so MSR cannot see the mode change.Edit: looks like I can work around it. I will schedule that for a future build.
