  4. [SOLVED] Home Mode setting in Hubitat
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
9 Posts 4 Posters 2.8k Views 4 Watching
  • 3 Offline
    3 Offline
    @toggledbits - Have you enabled the option to switch Modes within Hubitat? I added the x_hubitat_sys_mode.set action on a couple of rules but it never seemed to change in the hub. I was manually testing this out via an action, and straight from the Entities page, and it doesn't look like it does anything. If I create a virtual button within Hubitat and then using the Home Mode Manager app, I can switch the modes based on the button I press, but it would be simpler if I could just assign the mode within an action.2021-08-31_101044.jpg
    I've tried the variable "away" as well as 3 in the Perform now action, but neither appears to do anything.
      Did this "Hubitat Modes" feature request ever get resolved to your mutual satisfaction?
        Mode setting and entity update work fine on Hubitat. If you're changing the mode in MSR and looking at the Hubitat UI's Location and Modes page (specifically the Modes tab), the display does not update automatically there and you need to refresh the page to see changes, but that's their UI problem. The mode changes happen.
        When issuing the x_hubitat_sys_mode action, you may use either the name or the numeric ID. If using name, the mode names are case-sensitive on Hubitat, so you must match case.
        Seems nutty, but it's what they do/allow, so it's what we're stuck with.
          Was just about to post (grabbing screenshot as @toggledbits made his post) and can confirm, mode changes work just fine.
          This is an example of one of many I use daily.
          TBH, I wasn't aware of the case-sensitivity... I must have just been lucky all this time and matched it correctly! Looking more closely at your screenshot @3rdStng it looks like Hubitat is expecting Away and you've provided away -- given the enlightenment about case-sensitivity that may be your smoking gun right there.
          3 1 Reply Last reply
            3 Offline
            3 Offline
            @gwp1 said in Home Mode setting in Hubitat:
            Likewise, this may have been my issue. I'll try again and if successful, which I think it will be, I'll be able to remove my virtual buttons.
            • 3 Offline
              3 Offline
              I confirm that I am able to set mode via MSR on my HE. Thanks for bumping this topic @LibraSun and thanks to @toggledbits for pointing out that the case is sensitive.
                For bonus points, if this indeed applies, let me mention that I was yesterday years old when I learned that Hubitat's house modes are case sensitive. Not knowing specifically what those modes look like, case-wise, but seeing "Day" as the current mode, I feel compelled to warn that the NOT IN [away,vacation,night] condition might not act as intended.
                NOTE: See thread https://smarthome.community/topic/765/how-do-i-delay-a-notification-to-fire-only-if-the-ruleset-actually-fires/3?_=1636129614862 for this reply's original context.
                That is, even in "Away" (title case) mode, this Rule would fire because it is NOT "away". Thoughts?
                  The in and not in condition operators allow case-sensitive or -insensitive operation.
                  • LibraSunL LibraSun
                    @librasun Ah, but I've checked the ignore case button and it works wonderfully.
                      163.9k
