  4. [SOLVED] Home Mode setting in Hubitat
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
9 Posts 4 Posters 1.9k Views 4 Watching
  • 3 Offline
    3 Offline
    @toggledbits - Have you enabled the option to switch Modes within Hubitat? I added the x_hubitat_sys_mode.set action on a couple of rules but it never seemed to change in the hub. I was manually testing this out via an action, and straight from the Entities page, and it doesn't look like it does anything. If I create a virtual button within Hubitat and then using the Home Mode Manager app, I can switch the modes based on the button I press, but it would be simpler if I could just assign the mode within an action.2021-08-31_101044.jpg
    I've tried the variable "away" as well as 3 in the Perform now action, but neither appears to do anything.
      Did this "Hubitat Modes" feature request ever get resolved to your mutual satisfaction?
        Mode setting and entity update work fine on Hubitat. If you're changing the mode in MSR and looking at the Hubitat UI's Location and Modes page (specifically the Modes tab), the display does not update automatically there and you need to refresh the page to see changes, but that's their UI problem. The mode changes happen.
        When issuing the x_hubitat_sys_mode action, you may use either the name or the numeric ID. If using name, the mode names are case-sensitive on Hubitat, so you must match case.
        Seems nutty, but it's what they do/allow, so it's what we're stuck with.
          Was just about to post (grabbing screenshot as @toggledbits made his post) and can confirm, mode changes work just fine.
          This is an example of one of many I use daily.
          TBH, I wasn't aware of the case-sensitivity... I must have just been lucky all this time and matched it correctly! Looking more closely at your screenshot @3rdStng it looks like Hubitat is expecting Away and you've provided away -- given the enlightenment about case-sensitivity that may be your smoking gun right there.
          *Hubitat C-7 2.4.3.177
          Core 2026.1.1
          MSR: latest-26011-c621bbc7
          3 1 Reply Last reply
            3 Offline
            3 Offline
            @gwp1 said in Home Mode setting in Hubitat:
            Likewise, this may have been my issue. I'll try again and if successful, which I think it will be, I'll be able to remove my virtual buttons.
            • 3 Offline
              3 Offline
              I confirm that I am able to set mode via MSR on my HE. Thanks for bumping this topic @LibraSun and thanks to @toggledbits for pointing out that the case is sensitive.
                For bonus points, if this indeed applies, let me mention that I was yesterday years old when I learned that Hubitat's house modes are case sensitive. Not knowing specifically what those modes look like, case-wise, but seeing "Day" as the current mode, I feel compelled to warn that the NOT IN [away,vacation,night] condition might not act as intended.
                NOTE: See thread https://smarthome.community/topic/765/how-do-i-delay-a-notification-to-fire-only-if-the-ruleset-actually-fires/3?_=1636129614862 for this reply's original context.
                That is, even in "Away" (title case) mode, this Rule would fire because it is NOT "away". Thoughts?
                  The in and not in condition operators allow case-sensitive or -insensitive operation.
                    @librasun Ah, but I've checked the ignore case button and it works wonderfully.
                    Core 2026.1.1
                    • Next Release?
