  4. Using `format()` to build notification and other strings
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
14 Posts 3 Posters 2.7k Views 3 Watching
    A few new functions have worked their way into Reactor's expression language over the last couple of months, and while they are documented in the change logs and documentation, it seems some of you are not aware of them, so I'm going to pick one out and highlight it, maybe do others later...
    A lot of you build strings in expressions by simple concatenation, and there's nothing wrong with that, but there's a new function in the expression language that can help you clean things up, in particular when handling numeric values.
    I've noticed many of you will round your results either on the calculation, or in some cases, in a separate variable. For example, say we have a pair of expressions that retrieves the indoor and outdoor temperature from a sensor and the weather service:
    indoor = getEntity( 'hubitat>144' ).attributes.temperature_sensor.value' )
    outdoor = getEntity( 'weather>home' ).attributes.wx.temperature
    The weather service, since it converts from degrees K in its reporting to degrees C, may have an irrational or repeating value (e.g. 8.233333333...). As a result, when you compute the difference, it, too, may have an irrational or repeating result, so you decide to round it to one decimal:
    tempDiff = round( outdoor - indoor, 1 )
    Then, perhaps you have a rule that if the differential is greater than 10 degrees, you send a notification, and the notification uses all three variables in the message string:
    ${{ 'The outdoor temperature is ' + outdoor + 'C and the indoor temperature is ' + indoor + 'C; the difference is ' + tempDiff + 'C' }}
    This is fine, except that the outdoor temperature isn't rounded, so you decide to fix that. There are at least three ways: add a round() to the outdoor variable expression, or create a third variable like outdoorRounded = round( outdoor, 1 ), or, use the round() function into the substitution expression
    ${{ 'The outdoor temperature is ' + round( outdoor, 1 ) + 'C and the indoor temperature is ' + indoor + 'C; the difference is ' + tempDiff + 'C' }}
    It's all getting very messy... Let's use format() instead of string concatenation, and not worry about rounding the difference, so we keep the maximum precision possible for any calcs or tests that use it. We go back to:
    tempDiff = outdoor - indoor
    Now our string substitution:
    ${{ format( "The outdoor temperature is {0:.1f}C and the indoor temperature is {1:.1f}C; the difference is {2:.1f}C", outdoor, indoor, tempDiff ) }}
    Here, format() is building the message string. Each {} (curly-brace) pair denotes the substitution of a parameter to follow. The number first inside the opening curly brace is the parameter number, starting from 0 as the first parameter. So parameter 0 in this example refers to the variable outdoor, and 1 is indoor, and 2 is tempDiff. Using the numbers, parameters can be inserted in any order.
    Each of these substitutions in the example includes an optional format specification. If no format specification is given (e.g. {0}), then the parameter is converted to a string with no special formatting, but since we can get numbers like 8.233333... it's desirable to use some formatting to make it pretty. The format is separated from the parameter number by the : (colon) in the substitution. The format we're using for all three parameters is .1f, which is <width>.<precision>f. Any number before the dot is a fixed field width, but since we want no extra spaces, we just don't specify a width (it's blank for our example), and the value will take as much space as it needs. The f at the end tells format() that the value is going to be formatted as a floating point number, and the .1 before the f tells the formatter to display a single decimal digit. So our 8.23333333 value would be displayed as 8.2, without using extra functions or variables, or dropping precision in a calculation. For clarity, 10.875 would be displayed/inserted as 10.9 in this example, because the formatter will round the displayed result to the specified number of decimal digits.
    Tip: for simple string insertions that require no special formatting, format() will let you skip the parameter numbers if the parameters are in the same order as the substitutions, and the default format is (generic) string (s), so format( "{} x {} = {}", "alpha", "beta", "gamma" ) produces the string alpha x beta = gamma.
    Docs for format are in the Reactor documentation under the heading Special Reactor Functions.
      Another lesson, and a show of function. Sure, will help a lot.
        Love it! Two things just so you know I was paying attention:
        1. Numbers like 8.2333... are not "irrational" (as 'pi' would be), just plain rational-but-repeating.
        2. Yay for new functions like this; only reason I never commented or utilized is that my focus has been forced elsewhere lately.
        Definitely planning to revisit things like my dozen or so "Messaging" rules that insert expressions into boilerplate text, à la mail merge.
        THANKS for your ongoing dedication to making MSR the snizznel!!
          I have the following array > BatteryLow = ["Door Auxiliar Room 66%","Door Lock Kitchen 55%","Motion Closed 33%","Motion Kitchen 65%"]
          Using the format() function > ${{ format( "List of low battery: {}.", BatteryLow ) }}
          Generates the result in a notification > List of low battery: Door Auxiliar Room 66%,Door Lock Kitchen 55%,Motion Closed 33%,Motion Kitchen 65%.
          All separated by a comma ",".
          Examples (spaces shown as "⋅" for clarity only):
          Questions:
          1. how is it possible to format the separator to be for example comma space ",⋅"
          List of low battery: Door Auxiliar Room 66%,⋅Door Lock Kitchen 55%,⋅Motion Closed 33%,⋅Motion Kitchen 65%.
          1. Or if I want to change for example, space bar space "⋅/⋅"
          List of low battery: Door Auxiliar Room 66%⋅/⋅Door Lock Kitchen 55%⋅/⋅Motion Closed 33%⋅/⋅Motion Kitchen 65%.
            This has been mentioned and used in other threads on the more specific topic of creating and handling lists of failed or otherwise "in need of notification" devices...
            You are passing an array into format() directly, and asking it to format it as a string using default formatting. The default formatting isn't very interesting/pretty for arrays. But the join() function specifically converts an array to a string using a provided separator (another string).
            wmarcolinW 1 Reply Last reply
              @toggledbits Ok got it, I was using joing() before, and it generated the third variable with the final text.
              As we discussed in the other threads when using sort() that already generates the final name, I'm adding the space (" " + e.name), so it solved the presentation.
              The format() function is very interesting, and worked great with array, eliminated one step and one variable.
              • wmarcolinW wmarcolin
                @wmarcolin said in Using &#x60;format()&#x60; to build notification and other strings:
                Don't understand. Can you elaborate?
                  @toggledbits as we said, we are good at creating problems, not explaining 😁 this is also valid when we are creative 😊
                  Ok, before I first created an array with the list of devices with problem (OldFaultOn) and then in a second step without sorting the names, I generated into a new variable the string with the names (OldFaultMSG), separated by comma and space.
                  With the brilliant sort() function I am already directly generating the list of device names, sorted.
                  This eliminated having to have other variable to store the information to be displayed. As commented before, when using format() ahead, the function displays the whole array separated only by a comma. To improve the display it would be good to have a comma and space before the next name. So I decided to put space in the sort (" " + e.name).
                  I previously set up the notification like this.
                  And now using sort() and format().
                  I believe we have many ways of doing things, I am looking to improve the use of functions.
                    Since the result of sort() is an array, you can wrap the sort() with join(), no need for an extra variable.
                    FaultOn = join( sort( each id of FaultSensor: do e=getEntity(id), e?.attributes?.x_vera_device?.failed == true ? e.name : null done ), ", " )
                    This would, of course, change the type of FaultOn to a string.
                    If you wanted to preserve the array for other uses, you could also apply the join() to the format() substitution on the array: ${{ format( "Failed devices: {}", join(FaultOn, ", ") ) }}
                      @toggledbits nothing like talking to a Jedi master.
                      I will go with the second option, to preserve the array, I think it may have a better future use.
                        With the new DynamicGroupController option, is it now possible to override all this instruction to use format() directly?
                        bd400cc0-f1ce-4700-b7d3-577a4a8495ac-image.png f79b4c0d-3262-43d7-abf4-3544df1f008e-image.png
                        Or is it necessary to first transform the IDs that appear in the object carrying the name and format, and only then be able to send a text message?
                        Can you help Patrick, I am not really sure now how to go about this.
                          I will leave this for you to think about, or perhaps some other users can chime in with some assistance. Try some things, observe, fail, and learn. 🙂
                            @toggledbits done 🙂
                            sort( each id in getEntity('groups>low_battery').attributes.sys_group.members: getEntity(id).name + " " + int(getEntity(id).attributes.battery_power.level *100) + "%")
                              Looks good, though I swear you might be missing a closing parenthesis at the end?
                                164.5k
