  3. Vera Bridge
  4. Get Vera files throwing errors
Hello, I have a fresh openluup install on a raspberry. Just installed "Vera Bridge" plugin, but I can't make it to work. The plugin can not load the device infos from the vera. This is what I can see in the OpenLuup log : openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 I have tried it from a console on the same raspberry this way : wget http://192.168.1.2:3480/data_request?id=user_data2&output_format=json&ns=1 It worked, so I think it's not credential or network issue. What can be the solution for this ? more openluup log : 408 lines, 1 error, max gap 61s @ 2022-08-12 20:51:01.568 2022-08-12 19:21:24.150 :: openLuup LOG ROTATION :: (runtime 0.0 days) 2022-08-12 19:21:24.154 openLuup.init:: init phase completed 2022-08-12 19:21:24.155 openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x1c48ee8 2022-08-12 19:21:24.157 openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x1b461d8 2022-08-12 19:21:24.158 openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x1b48780 2022-08-12 19:21:24.158 openLuup.historian:: starting data historian 2022-08-12 19:21:24.159 openLuup.historian:: using memory cache size (per-variable): 1024 2022-08-12 19:21:24.168 openLuup.scheduler:: starting 2022-08-12 19:21:24.169 openLuup.scheduler:: [2] openLuup device startup 2022-08-12 19:21:24.170 luup_log:2: v22.7.31 2022-08-12 19:21:24.171 luup_log:2: sync in 35.8 s 2022-08-12 19:21:24.190 luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local 2022-08-12 19:21:24.193 luup.chdev.append:: [AltAppStore] Alternate App Store 2022-08-12 19:21:24.193 luup.chdev.sync:: [2] openLuup, syncing children 2022-08-12 19:21:24.194 luup_log:2: starting MQTT $SYS/broker statistics 2022-08-12 19:21:24.196 luup_log:2: 3Mb, 2.1%cpu, 0.0days 2022-08-12 19:21:24.211 openLuup.scheduler:: [2] openLuup device startup completed: status=true, msg=sync in 35.8 s, name=L_openLuup 2022-08-12 19:21:24.212 openLuup.scheduler:: [3] Alternate UI device startup 2022-08-12 19:21:24.212 luup_log:3: ALTUI: initstatus(3) starting version: v2.54 2022-08-12 19:21:24.214 openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name= 2022-08-12 19:21:24.214 openLuup.scheduler:: [7] VeraBridge device startup 2022-08-12 19:21:24.215 luup_log:7: VeraBridge 2022-08-12 19:21:24.215 luup_log:7: 2021.01.03 2022-08-12 19:21:24.216 luup_log:7: 192.168.1.2 2022-08-12 19:21:24.216 luup_log:7: device clone numbering starts at 10000 2022-08-12 19:21:24.217 luup_log:7: VeraBridge maps remote Zwave controller 2022-08-12 19:21:24.218 luup_log:7: v21.1.3 2022-08-12 19:21:24.242 openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 2022-08-12 19:21:24.242 luup.set_failure:: status = 2 2022-08-12 19:21:24.243 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 2 now: 2 #hooks:0 2022-08-12 19:21:24.244 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1660323316 now: 1660324884 #hooks:0 2022-08-12 19:21:24.246 luup_log:7: registering with AltUI [3] as Data Storage Provider 2022-08-12 19:21:24.247 luup.register_handler:: global_function_name=HTTP_VeraBridgeMirror_192.168.1.2, request=HTTP_VeraBridgeMirror_192.168.1.2 2022-08-12 19:21:24.249 luup.call_action:: 3.urn:upnp-org:serviceId:altui1.RegisterDataProvider 2022-08-12 19:21:24.260 openLuup.scheduler:: [7] VeraBridge device startup completed: status=, msg=No Vera, name=VeraBridge 2022-08-12 19:21:24.261 openLuup.scheduler:: [4] Alternate App Store device startup 2022-08-12 19:21:24.261 luup_log:4: AltAppStore : starting... 2022-08-12 19:21:24.262 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0 2022-08-12 19:21:24.263 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: #hooks:0 2022-08-12 19:21:24.264 luup_log:4: AltAppStore : v20.3.30 2022-08-12 19:21:24.264 luup.set_failure:: status = 0 2022-08-12 19:21:24.265 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.266 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.267 openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore 2022-08-12 19:21:24.268 openLuup.scheduler:: [5] Harmony Hub Control device startup 2022-08-12 19:21:24.280 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.LinkStatus was: Ok now: Starting... #hooks:0 2022-08-12 19:21:24.281 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.IconSet was: 0 now: 3 #hooks:0 2022-08-12 19:21:24.282 luup.attr_set:: 5.altid = HAM5_CNTRL 2022-08-12 19:21:24.326 luup.set_failure:: status = 0 2022-08-12 19:21:24.326 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.327 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.328 openLuup.scheduler:: [5] Harmony Hub Control device startup completed: status=true, msg=OK, name=Harmony Control 2022-08-12 19:21:24.332 luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.2,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2,[{ "default":"device.serviceId.name", "key":"mirror", "label":"Mirror", "type":"text" }]) 2022-08-12 19:21:24.337 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... #hooks:0 2022-08-12 19:21:24.360 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d21868 2022-08-12 19:21:24.363 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=323312852&Timeout=60&MinimumDelay=1500&=1660323303557 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:24.646 openLuup.server:: request completed (34267 bytes, 3 chunks, 280 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:24.648 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d6a9b0 2022-08-12 19:21:24.661 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=323312340&=1660323303558 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:25.252 openLuup.server:: request completed (70135 bytes, 5 chunks, 588 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:25.253 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2022-08-12 19:21:25.338 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.54 now: v2.54 #hooks:0 2022-08-12 19:21:25.934 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... now: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... #hooks:0 2022-08-12 19:21:25.964 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.996 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.999 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was: now: #hooks:0 2022-08-12 19:21:26.009 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.010 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.012 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0 2022-08-12 19:21:26.013 luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0) Thank You. d.
Vera Bridge
openLuup and Vera bridge
Vera Bridge
Vera Bridge
VeraBridge
Vera Bridge
Bridge openLuup to openLuup
P
Vera Bridge
Vera Bridge
Vera Bridge
Instant status
Vera Bridge
Scheduled Pinned Locked Moved Solved Vera Bridge
37 Posts 4 Posters 21.3k Views 4 Watching
    RogerO
    Hello,
    Thanks,
    Roger
      OK, for a start...
      • which version of openLuup?
      • which version of Vera firmware?
      • what security settings do you have set on Vera? (ie. is running Lua code allowed?)
      I guess that a zipped attachment will work, although maybe just quoting the text...
      like
      this
        RogerO
        OpenLuup: v19.12.27
        Vera: 1.7.4970 (7.31)
        Secure the controller: OFF
        Enable Potentially unsafe lua code: ON
        Enable UPnP: OFF
        Since writing the earlier post. I blew away cmh-ludl on my RPI and reinstalled openLuup from scratch. Now I am not able to connect to the vera. It has a red title bar in devices. IP is correct under attributes.
        These lines in log file look weird to me: The URL doesn't contain the IP of the vera even though it sees it a few lines earlier.
        openLuup.io.server:: HTTP connection from 192.168.0.174 tcp{client}: 0x1ed7788
        openLuup.client:: WGET error status: -1, request: http:///port_3480/data_request?id=action&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&action=RunLua&Code=%0a%20%20local%20lfs%20%3d%20require%20%22lfs%22%0a%20%20local%20f%20%3d%20io%2eopen%20%28%22%2fwww%2fdirectory%2etxt%22%2c%20%27w%27%29%0a%20%20for%20fname%20in%20lfs%2edir%20%28%22%2fetc%2fcmh%2dludl%2f%22%29%20do%0a%20%20%20%20if%20fname%3amatch%20%22%2e%2a%22%20and%20%28fname%3amatch%20%22lzo%24%22%20or%20fname%3a%20match%20%22png%24%22%20or%20fname%3a%20match%20%22svg%24%22%29%20then%0a%20%20%20%20%20%20f%3awrite%20%28fname%29%0a%20%20%20%20%20%20f%3awrite%20%27%5cn%27%0a%20%20%20%20end%0a%20%20f%3awrite%20%27%5cn%27%0a%20%20end%0a%20%20f%3aclose%20%28%29%0a%0a%20%20
        2020-05-02 14:35:33.020
        Let me know what part of logs you want to see.
          RogerO
          Update:
          I uninstalled the VeraBridge and reinstalled it and it seems to be updating the devices now. Scenes have populated, though not all the light switches are functioning.
            You’re using a rather old version of openLuup. Suggest you update to the latest. Just click on the update button next to openLuup on the Plugins page.
            • propheadP Offline
              propheadP Offline
              prophead
              Actually, you want the development branch, not the master branch
              • propheadP Offline
                propheadP Offline
                prophead
                Type in development in the box next to update before you hit the update button in more > plugins
                • propheadP prophead
                    RogerO
                    Well, that completely horked it.
                    Now I am getting this in out.log
                    lua5.1: ./openLuup/loader.lua:476: Implementation XML root element name is not 'implementation'
                    stack traceback:
                    [C]: in function 'error'
                    ./openLuup/loader.lua:476: in function 'parse_impl_xml'
                    ./openLuup/loader.lua:553: in function 'read_impl'
                    ./openLuup/loader.lua:735: in function 'assemble_device'
                    ./openLuup/chdev.lua:141: in function 'create'
                    ./openLuup/userdata.lua:551: in function 'load'
                    openLuup/init.lua:244: in main chunk
                    [C]: ?
                    Assume I can go to the dev branch on gethub and pull down the latest files?
                      RogerO
                      That didn't work either. WIll wait for the experts to reply.
                        RogerO
                        Got it to work again. Now I am on 20.5.1 of openLuup.
                          Just wondering if there are lessons for me to learn from this?
                          ...is there something specifically you did wrong, and then right, to fix things?
                          propheadP 1 Reply Last reply
                            propheadP Offline
                            propheadP Offline
                            prophead
                            @akbooer The master branch apparently has those implementation files still enabled.
                              RogerO
                              I should clarify my last statement of "getting it to work". What I was referring to was getting past the error message and getting the ALTUI interface to load.
                              Here is the sequence of events from yesterday.
                              1. Deleted the cmh-ludl directory that I had originally installed in the /home/pi path.
                                Was having issues getting openLuup to run on startup based on the samples in the openLuup users guide. (more of a windows guy than linux).
                              2. Created a cmh-ludl in /etc, so that the install point matched the scripts in the doc.
                              3. Ran sudo lua5.1 openLuup_install.lua which installed the v19.12.27
                              4. Based on comments in thread added "development" to Update dialog box and ran update script. That completely broke everything. openLuup would not load.
                              5. Tried to copy openLuup files from github to my RPI. That didn't work either.
                              6. Reran sudo lua5.1 openLuup_install.lua and it installed the 20.5.1 version (at least that is what it says on the plugins page).
                              So the current state is that ALTUI runs. I can control a few switches through my Vera from ALTUI. The majority of my devices are displaying the generic z-wave icon and have no control buttons.
                              In devices, VeraBridge has a red title bar even though I can control it.
                              When I try to run the GetVeraScenes action I get this in the LuaUPnP log:
                              "2020-05-03 09:36:17.169 luup_log:5: GetVeraScenes action called
                              2020-05-03 09:36:17.374 openLuup.server:: request completed (2581 bytes, 1 chunks, 16755 ms) tcp{client}: 0x29334d8
                              2020-05-03 09:36:19.706 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=463507015&Timeout=60&MinimumDelay=1500&_=1588522721664 HTTP/1.1 tcp{client}: 0x29334d8
                              2020-05-03 09:36:30.267 openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x237b8d8
                              2020-05-03 09:36:30.469 openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x21da810
                              2020-05-03 09:36:30.470 openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x2a04e58
                              2020-05-03 09:36:30.470 openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x24e02a0
                              When I run GetVeraFiles I get a bunch of these:
                              "2020-05-03 09:39:19.118 openLuup.client:: WGET error status: 503, request: http://192.168.0.143/port_3480/D_ReactorSensor_UI7.json
                              2020-05-03 09:39:19.118 luup_log:5: ERROR: D_ReactorSensor_UI7.json
                              2020-05-03 09:39:19.121 openLuup.client:: WGET error status: 503, request: http://192.168.0.143/port_3480/D_DelayLightTimer.xml
                              2020-05-03 09:39:19.122 luup_log:5: ERROR: D_DelayLightTimer.xml
                              2020-05-03 09:39:19.129 openLuup.client:: WGET error status: 503, request: http://192.168.0.143/port_3480/D_VenstarColorTouchThermostat1_F.json
                              2020-05-03 09:39:19.129 luup_log:5: ERROR: D_VenstarColorTouchThermostat1_F.json
                              2020-05-03 09:39:19.133 openLuup.client:: WGET error status: 503, request: http://192.168.0.143/port_3480/I_DelayLight.xml
                              2020-05-03 09:39:19.133 luup_log:5: ERROR: I_DelayLight.xml"
                              I can, however, paste this, http://192.168.0.143/port_3480/I_DelayLight.xml, in the browser on my RPI and it returns the xml data.
                              Thanks for your assistance.
                                Ok, that's lots to go on.
                                I've just done a completely fresh install on a RPI of the development system (crrently v20.5.3, actually, but no material difference from what you're trying.) Donwloaded all files successfully from a Vera Edge, running 7.30.
                                I think that, at this stage, I'd like a copy of the startup log and the main log after a restart.
                                In addition, the listing provided by the openLuup console Startup page would be of use:
                                http://openLuupIP:3480/openLuup?page=startup
                                I'm worried by the red banner on the VeraBridge device.
                                  RogerO
                                  Here is the startup page:
                                  Plugin Startup Jobs CPU usage (in startup order)
                                  date / time device priority status hh🇲🇲ss.sss job # info notes
                                  1 2020-05-03 13:17:38.558 2 1 Done 0.004 1 plugin: openLuup sync in 21.9 s
                                  2 2020-05-03 13:17:38.559 3 3 Done 0.000 2 plugin: Alternate UI
                                  3 2020-05-03 13:17:41.731 5 5 Abort 2.793 4 plugin: VeraBridge ./openLuup/loader.lua:476: Implementation XML root element name is not 'implementation'
                                  4 2020-05-03 13:17:41.847 6 5 Done 0.008 5 plugin: Z-Way OK
                                  5 2020-05-03 13:17:41.848 4 Done 0.001 3 plugin: Alternate App Store OK
                                  Link for log files sent via chat.
                                    OK, straight-forward error. How did you create the VeraBridge plugin? It doesn't have a correct implementation file. What do its device attributes look like?
                                      RogerO
                                      I I created the VeraBridge by going into the app - Plugins and clicking the update button.
                                      altid
                                      category_num 1
                                      cpu(s) 2.793128
                                      device_file D_VeraBridge.xml
                                      device_json D_VeraBridge.json
                                      device_type VeraBridge
                                      disabled 0
                                      id 5
                                      id_parent 0
                                      impl_file I_VeraBridge.xml
                                      invisible 0
                                      ip 192.168.0.143
                                      local_udn uuid:d764c8cc-e932-55c4-478d-7aa05d83f3ea
                                      mac
                                      manufacturer akbooer
                                      model
                                      name VeraBridge
                                      plugin
                                      room 0
                                      status -1
                                      subcategory_num 0
                                      time_created 05/02/2020 04:29:14 PM
                                      altuiid 0-5
                                      favorite false
                                      dirty false
                                        There are several inconsistencies here.
                                        • The startup page shows a failure to read the implementation file, yet the details in the startup log show that the VeraBridge plugin has started correctly.
                                        • The VeraBridge version as reported at the end of the startup log (19.12.12) is not consistent with the version number of the openLuup system.
                                        If you look in the cmh-ludl folder, and in its files folder, do you find any VeraBridge files? There should be none. The only findable VeraBridge file should be the L_VeraBridge.lua one in the openLuup folder (20.4.30). If there are any others, delete them.
                                        I believe I know what went wrong, but the above should get you going OK.
                                          RogerO
                                          There is only one Verabridge file on the cmh-ludl folder or any of the sub's located in the openLuup folder. File header is:
                                          BOUT = {
                                          NAME = "VeraBridge",
                                          VERSION = "2019.12.12",
                                          DESCRIPTION = "VeraBridge plugin for openLuup",
                                          AUTHOR = "@akbooer",
                                          COPYRIGHT = "(c) 2013-2019 AKBooer",
                                          DOCUMENTATION = "https://github.com/akbooer/openLuup/tree/master/Documentation",
                                          DEBUG = false,
                                          LICENSE = [[
                                          Copyright 2013-2019 AK Booer
                                            165.3k
