  3. Vera Bridge
  4. Openluup - verabridge can not load devices.
Hello, I have a fresh openluup install on a raspberry. Just installed "Vera Bridge" plugin, but I can't make it to work. The plugin can not load the device infos from the vera. This is what I can see in the OpenLuup log : openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 I have tried it from a console on the same raspberry this way : wget http://192.168.1.2:3480/data_request?id=user_data2&output_format=json&ns=1 It worked, so I think it's not credential or network issue. What can be the solution for this ? more openluup log : 408 lines, 1 error, max gap 61s @ 2022-08-12 20:51:01.568 2022-08-12 19:21:24.150 :: openLuup LOG ROTATION :: (runtime 0.0 days) 2022-08-12 19:21:24.154 openLuup.init:: init phase completed 2022-08-12 19:21:24.155 openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x1c48ee8 2022-08-12 19:21:24.157 openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x1b461d8 2022-08-12 19:21:24.158 openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x1b48780 2022-08-12 19:21:24.158 openLuup.historian:: starting data historian 2022-08-12 19:21:24.159 openLuup.historian:: using memory cache size (per-variable): 1024 2022-08-12 19:21:24.168 openLuup.scheduler:: starting 2022-08-12 19:21:24.169 openLuup.scheduler:: [2] openLuup device startup 2022-08-12 19:21:24.170 luup_log:2: v22.7.31 2022-08-12 19:21:24.171 luup_log:2: sync in 35.8 s 2022-08-12 19:21:24.190 luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local 2022-08-12 19:21:24.193 luup.chdev.append:: [AltAppStore] Alternate App Store 2022-08-12 19:21:24.193 luup.chdev.sync:: [2] openLuup, syncing children 2022-08-12 19:21:24.194 luup_log:2: starting MQTT $SYS/broker statistics 2022-08-12 19:21:24.196 luup_log:2: 3Mb, 2.1%cpu, 0.0days 2022-08-12 19:21:24.211 openLuup.scheduler:: [2] openLuup device startup completed: status=true, msg=sync in 35.8 s, name=L_openLuup 2022-08-12 19:21:24.212 openLuup.scheduler:: [3] Alternate UI device startup 2022-08-12 19:21:24.212 luup_log:3: ALTUI: initstatus(3) starting version: v2.54 2022-08-12 19:21:24.214 openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name= 2022-08-12 19:21:24.214 openLuup.scheduler:: [7] VeraBridge device startup 2022-08-12 19:21:24.215 luup_log:7: VeraBridge 2022-08-12 19:21:24.215 luup_log:7: 2021.01.03 2022-08-12 19:21:24.216 luup_log:7: 192.168.1.2 2022-08-12 19:21:24.216 luup_log:7: device clone numbering starts at 10000 2022-08-12 19:21:24.217 luup_log:7: VeraBridge maps remote Zwave controller 2022-08-12 19:21:24.218 luup_log:7: v21.1.3 2022-08-12 19:21:24.242 openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 2022-08-12 19:21:24.242 luup.set_failure:: status = 2 2022-08-12 19:21:24.243 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 2 now: 2 #hooks:0 2022-08-12 19:21:24.244 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1660323316 now: 1660324884 #hooks:0 2022-08-12 19:21:24.246 luup_log:7: registering with AltUI [3] as Data Storage Provider 2022-08-12 19:21:24.247 luup.register_handler:: global_function_name=HTTP_VeraBridgeMirror_192.168.1.2, request=HTTP_VeraBridgeMirror_192.168.1.2 2022-08-12 19:21:24.249 luup.call_action:: 3.urn:upnp-org:serviceId:altui1.RegisterDataProvider 2022-08-12 19:21:24.260 openLuup.scheduler:: [7] VeraBridge device startup completed: status=, msg=No Vera, name=VeraBridge 2022-08-12 19:21:24.261 openLuup.scheduler:: [4] Alternate App Store device startup 2022-08-12 19:21:24.261 luup_log:4: AltAppStore : starting... 2022-08-12 19:21:24.262 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0 2022-08-12 19:21:24.263 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: #hooks:0 2022-08-12 19:21:24.264 luup_log:4: AltAppStore : v20.3.30 2022-08-12 19:21:24.264 luup.set_failure:: status = 0 2022-08-12 19:21:24.265 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.266 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.267 openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore 2022-08-12 19:21:24.268 openLuup.scheduler:: [5] Harmony Hub Control device startup 2022-08-12 19:21:24.280 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.LinkStatus was: Ok now: Starting... #hooks:0 2022-08-12 19:21:24.281 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.IconSet was: 0 now: 3 #hooks:0 2022-08-12 19:21:24.282 luup.attr_set:: 5.altid = HAM5_CNTRL 2022-08-12 19:21:24.326 luup.set_failure:: status = 0 2022-08-12 19:21:24.326 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.327 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.328 openLuup.scheduler:: [5] Harmony Hub Control device startup completed: status=true, msg=OK, name=Harmony Control 2022-08-12 19:21:24.332 luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.2,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2,[{ "default":"device.serviceId.name", "key":"mirror", "label":"Mirror", "type":"text" }]) 2022-08-12 19:21:24.337 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... #hooks:0 2022-08-12 19:21:24.360 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d21868 2022-08-12 19:21:24.363 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=323312852&Timeout=60&MinimumDelay=1500&=1660323303557 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:24.646 openLuup.server:: request completed (34267 bytes, 3 chunks, 280 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:24.648 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d6a9b0 2022-08-12 19:21:24.661 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=323312340&=1660323303558 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:25.252 openLuup.server:: request completed (70135 bytes, 5 chunks, 588 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:25.253 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2022-08-12 19:21:25.338 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.54 now: v2.54 #hooks:0 2022-08-12 19:21:25.934 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... now: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... #hooks:0 2022-08-12 19:21:25.964 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.996 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.999 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was: now: #hooks:0 2022-08-12 19:21:26.009 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.010 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.012 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0 2022-08-12 19:21:26.013 luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0) Thank You. d.
Vera Bridge
openLuup and Vera bridge
Vera Bridge
Vera Bridge
VeraBridge
Vera Bridge
Bridge openLuup to openLuup
P
Vera Bridge
Vera Bridge
Get Vera files throwing errors
Vera Bridge
Instant status
Vera Bridge
Scheduled Pinned Locked Moved Solved Vera Bridge
11 Posts 3 Posters 3.3k Views 3 Watching
  • D Offline
    D Offline
    dmon
    Hello,
    more openluup log :
    "key":"mirror",
    "label":"Mirror",
    "type":"text"
    Thank You.
    d.
      OK, three things to check:
      1. Startup log
      2. Attribute page of the bridge (ie. did you install it right?)
      3. does this work from the Lua Test page?
      local a,b = luup.inet.wget "http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1"
      print(pretty(b))
      • D Offline
        D Offline
        dmon
        Console Output: :
        First output was :
        "MD5 module not available for digest authorization: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1"
        I'ves solved it with :
        sudo apt-get -y install lua-md5
        Now the console output is :
        "<?xml version="1.0" encoding="iso-8859-1"?>\010<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"\010 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">\010<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">\010 <head>\010 <title>401 - Unauthorized</title>\010 </head>\010 <body>\010 <h1>401 - Unauthorized</h1>\010 </body>\010</html>\010<?xml version="1.0" encoding="iso-8859-1"?>\010<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"\010 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">\010<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">\010 <head>\010 <title>400 - Bad Request</title>\010 </head>\010 <body>\010 <h1>400 - Bad Request</h1>\010 </body>\010</html>\010"
        So it seems an auth problem.
        Is there any possibilities to give the credentials to the VeraBridge plugin ?
        Strange that if I try this way (:3480 instead of /port_3480) it's working and get back everything:
        What I try to bridge is a Vera Lite with UI5.
        How can I reinstall the verabridge plugin from scratch ?
          I use it with Ui5 all the time. There should be no need for any credentials.
          Can you post or PM the device attributes page and startup log?
          • D Offline
            D Offline
            dmon
            device attributes page :
            I am very new here and can't find how can I send PM in this forum (I am not sure is it even possible in NodeBB engine), the forum can not allow me to attach files to my post yet.
            I am not sure whether the log contains any sensitive info so I attached a link for the logs and send you the password in chat for the file.
            log files : link
            After it did not worked as I wrote here yestersay I had a (maybe stupid) try to change the L_VerBridge.lua to use ":3840" string instead of "/port_3480" . I've changed RemotPort variable and the remote_request function. After the changes it downloaded the devices, but got another errors. You can see these at the end of the logs.
            Now I copied back the original L_VerBridge.lua and got the original error atthe beginning of teh log.
            This is why I asked how can I reinstall the VeraBridge plugin, to eliminate the mixing with my tries in the log files.
              Is the AsyncPoll variable set to true?
                The files for VeraBridge are installed with openLuup, so updating from the development branch will reload them. Note, though, that these are located in the openLuup folder. Delete any VeraBridge files that you may inadvertently have placed directly in the cmh_ludl home directory.
                • D Offline
                  D Offline
                  dmon
                  I've found this old forum post with similar problem (except I have no slave vera, only one) : verabridge-credentials
                  So I edited the two mentioned file in vera with ssh (/etc/lighttpd/lighttpd.conf, /etc/lighttpd.conf) and commented out the “mod_auth” section.
                  I've reinstalled freshly the VeraBrdige plugin.
                  Everything worked fine, the devices has been loadaded, and the GetVeraFiles donwloaded the needed files from the Vera.
                  After this I changed back the “mod_auth” section in the two files. Now the auth is enabled again.
                  I had to changed the RemotePort to :3840 at Variables.
                  Now it seems working.
                  I really don't know why my vera needs auth if you mentioned that your vera doesn't need it from OpenLuup.
                    Yes, this is why I asked for the attributes pages in the first place!
                    Glad it’s working now.
                    • D Offline
                      D Offline
                      dmon
                      wrote on last edited by dmon
                      The RemotePort change to :3480 was enogh for the device loading from vera, but was not enough for the GetVeraFiles.
                      For the GetVeraFiles working it needed the auth switch off in vera, because of this code in GetVeraFiles : http://192.168.1.2/directory.txt
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        Just wanted to add that my Vera Bridges stopped working, I can’t be sure exactly when, maybe after a reboot ? But wanted to share here as they were working fine..
                        The Variable for the RemotePort on both is /port_3480
                        Updating to :3480 fixes it..
                        @akbooer - not sure why this worked first and then stopped..
                        • akbooerA akbooer marked this topic as a question on
                        • akbooerA akbooer has marked this topic as solved on
                          165.3k
