  3. Vera Bridge
  4. Bridge openLuup to openLuup
Hello, I have a fresh openluup install on a raspberry. Just installed "Vera Bridge" plugin, but I can't make it to work. The plugin can not load the device infos from the vera. This is what I can see in the OpenLuup log : openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 I have tried it from a console on the same raspberry this way : wget http://192.168.1.2:3480/data_request?id=user_data2&output_format=json&ns=1 It worked, so I think it's not credential or network issue. What can be the solution for this ? more openluup log : 408 lines, 1 error, max gap 61s @ 2022-08-12 20:51:01.568 2022-08-12 19:21:24.150 :: openLuup LOG ROTATION :: (runtime 0.0 days) 2022-08-12 19:21:24.154 openLuup.init:: init phase completed 2022-08-12 19:21:24.155 openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x1c48ee8 2022-08-12 19:21:24.157 openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x1b461d8 2022-08-12 19:21:24.158 openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x1b48780 2022-08-12 19:21:24.158 openLuup.historian:: starting data historian 2022-08-12 19:21:24.159 openLuup.historian:: using memory cache size (per-variable): 1024 2022-08-12 19:21:24.168 openLuup.scheduler:: starting 2022-08-12 19:21:24.169 openLuup.scheduler:: [2] openLuup device startup 2022-08-12 19:21:24.170 luup_log:2: v22.7.31 2022-08-12 19:21:24.171 luup_log:2: sync in 35.8 s 2022-08-12 19:21:24.190 luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local 2022-08-12 19:21:24.193 luup.chdev.append:: [AltAppStore] Alternate App Store 2022-08-12 19:21:24.193 luup.chdev.sync:: [2] openLuup, syncing children 2022-08-12 19:21:24.194 luup_log:2: starting MQTT $SYS/broker statistics 2022-08-12 19:21:24.196 luup_log:2: 3Mb, 2.1%cpu, 0.0days 2022-08-12 19:21:24.211 openLuup.scheduler:: [2] openLuup device startup completed: status=true, msg=sync in 35.8 s, name=L_openLuup 2022-08-12 19:21:24.212 openLuup.scheduler:: [3] Alternate UI device startup 2022-08-12 19:21:24.212 luup_log:3: ALTUI: initstatus(3) starting version: v2.54 2022-08-12 19:21:24.214 openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name= 2022-08-12 19:21:24.214 openLuup.scheduler:: [7] VeraBridge device startup 2022-08-12 19:21:24.215 luup_log:7: VeraBridge 2022-08-12 19:21:24.215 luup_log:7: 2021.01.03 2022-08-12 19:21:24.216 luup_log:7: 192.168.1.2 2022-08-12 19:21:24.216 luup_log:7: device clone numbering starts at 10000 2022-08-12 19:21:24.217 luup_log:7: VeraBridge maps remote Zwave controller 2022-08-12 19:21:24.218 luup_log:7: v21.1.3 2022-08-12 19:21:24.242 openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 2022-08-12 19:21:24.242 luup.set_failure:: status = 2 2022-08-12 19:21:24.243 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 2 now: 2 #hooks:0 2022-08-12 19:21:24.244 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1660323316 now: 1660324884 #hooks:0 2022-08-12 19:21:24.246 luup_log:7: registering with AltUI [3] as Data Storage Provider 2022-08-12 19:21:24.247 luup.register_handler:: global_function_name=HTTP_VeraBridgeMirror_192.168.1.2, request=HTTP_VeraBridgeMirror_192.168.1.2 2022-08-12 19:21:24.249 luup.call_action:: 3.urn:upnp-org:serviceId:altui1.RegisterDataProvider 2022-08-12 19:21:24.260 openLuup.scheduler:: [7] VeraBridge device startup completed: status=, msg=No Vera, name=VeraBridge 2022-08-12 19:21:24.261 openLuup.scheduler:: [4] Alternate App Store device startup 2022-08-12 19:21:24.261 luup_log:4: AltAppStore : starting... 2022-08-12 19:21:24.262 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0 2022-08-12 19:21:24.263 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: #hooks:0 2022-08-12 19:21:24.264 luup_log:4: AltAppStore : v20.3.30 2022-08-12 19:21:24.264 luup.set_failure:: status = 0 2022-08-12 19:21:24.265 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.266 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.267 openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore 2022-08-12 19:21:24.268 openLuup.scheduler:: [5] Harmony Hub Control device startup 2022-08-12 19:21:24.280 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.LinkStatus was: Ok now: Starting... #hooks:0 2022-08-12 19:21:24.281 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.IconSet was: 0 now: 3 #hooks:0 2022-08-12 19:21:24.282 luup.attr_set:: 5.altid = HAM5_CNTRL 2022-08-12 19:21:24.326 luup.set_failure:: status = 0 2022-08-12 19:21:24.326 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.327 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.328 openLuup.scheduler:: [5] Harmony Hub Control device startup completed: status=true, msg=OK, name=Harmony Control 2022-08-12 19:21:24.332 luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.2,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2,[{ "default":"device.serviceId.name", "key":"mirror", "label":"Mirror", "type":"text" }]) 2022-08-12 19:21:24.337 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... #hooks:0 2022-08-12 19:21:24.360 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d21868 2022-08-12 19:21:24.363 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=323312852&Timeout=60&MinimumDelay=1500&=1660323303557 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:24.646 openLuup.server:: request completed (34267 bytes, 3 chunks, 280 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:24.648 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d6a9b0 2022-08-12 19:21:24.661 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=323312340&=1660323303558 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:25.252 openLuup.server:: request completed (70135 bytes, 5 chunks, 588 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:25.253 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2022-08-12 19:21:25.338 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.54 now: v2.54 #hooks:0 2022-08-12 19:21:25.934 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... now: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... #hooks:0 2022-08-12 19:21:25.964 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.996 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.999 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was: now: #hooks:0 2022-08-12 19:21:26.009 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.010 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.012 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0 2022-08-12 19:21:26.013 luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0) Thank You. d.
Vera Bridge
openLuup and Vera bridge
Vera Bridge
Vera Bridge
VeraBridge
Vera Bridge
P
Vera Bridge
Vera Bridge
Get Vera files throwing errors
Vera Bridge
Instant status
Vera Bridge
Scheduled Pinned Locked Moved Vera Bridge
15 Posts 3 Posters 4.5k Views 3 Watching
  • P Offline
    P Offline
    powisquare
    • P powisquare
      @powisquare
      Yes, but you need to change the bridge’s RemotePort Variable from /port_3480 to :3480.
      You also need a really good reason to bridge two openLuup instances, so I’m interest in what that might be!
        Yeah me too... what would be the application?
        • P Offline
          P Offline
          powisquare
          Ok - may have misunderstood ; )
          New pi/openluup/zway is set up and has replaced vera. My central openLuup which used to bridge to the old vera is now wanting to connect to the new setup ...
            Then I guess the question is, what not use the openLuup on the pi as your central openLuup?
            • P powisquare
              @powisquare said in Bridge openLuup to openLuup:
              Ah, no, that would be me, and it's an ongoing situation...
              1. You have installed the Zwave.me server software on a RPi with UZB, or on a Razberry?
              2. You have also installed (another) openLuup instance on that same machine?
              3. You have a 'central' openLuup instance somewhere(else) already?
              4. You want to link that central openLuup to Zwave.me server?
              5. You installed the ZWay plugin in one or other of your openLuups ...?
              YES or NO to the above list, plus any more explanatory notes, might help me to unpick this. Thanks!
              P 1 Reply Last reply
                P Offline
                P Offline
                powisquare
                @akbooer said in Bridge openLuup to openLuup:
                1. You have installed the Zwave.me server software on a RPi with UZB, or on a Razberry? YES
                2. You have also installed (another) openLuup instance on that same machine? YES
                3. You have a 'central' openLuup instance somewhere(else) already? YES
                4. You want to link that central openLuup to Zwave.me server? YES
                5. You installed the ZWay plugin in one or other of your openLuups ...? YES
                For peace of mind regarding backups (taking physical copies) we have a 'central' openLuup with three verabridges. One of these veras is now being replaced with pi + UZB + zwave.me server + openLuup + Zway plugin.
                  Ohh and why not remove the openLuup on the pi and instead put the z-way bridge on the central openLuup?
                  • P Offline
                    P Offline
                    powisquare
                    Would love to do that if allowed?
                      you can setup your z-way bridge on the central openLuup exactly like the one you have on the Pi. That should also remove some latency since your are taking out a communication layer. Nothing should prevent you from doing that. In fact that's how I transitioned from one controller to the other. Your pi should therefore just be running z-way.
                      Actually at the end I even move z-way to the same machine as the central openLuup making my equivalent of the rPi just a UZB and zigbee host sending its data to the controllers at the central machine using ser2net/socat.
                      Oct 7, 2017
                      Share Z-wave dongle over IP (USB over IP using ser2net / socat ) guide
                      Hi, Recently i’ve been working on virtualising all IT systems in my home. I’ve virtualised my NAS, Firewall, Router, Network Video Recorder and ofcourse my Openhab2 setup. During this virtualisation effort i ran into a few issues with regards to passing through my Z-wave.me USB1 z-wave dongle to...
                        What @rafale77 said.
                        I regularly run a Razberry accessed from a remote openLuup.
                        • P Offline
                          P Offline
                          powisquare
                          Had a slight hiccup yesterday - 'end kernel panic - not syncing: attempted to kill init'. Have reinstalled and back up to speed. Just would like to confirm - when I had zway bridge installed previously I seem to remember the bridge using device numbers in the 10000 range. One of the verabridges in 'openLuup central' also uses this range - should I change the parameter in verabridge to another range before I install zway bridge?
                            No, absolutely not. This variable looks after itself. The new ZWay bridge will spot the presence of the existing VeraBridge(s) and allocate a block of device numbers which does not conflict. With three VeraBridges, the next free block should be in the 40000 range.
                            • P Offline
                              P Offline
                              powisquare
                              Bingo! It is done. Huge thanks guys.
                                Excellent!
                                  165.3k
