  3. Vera Bridge
  4. Power outage and all the Vera devices were moved to room MiOS-xxxxx. How to fix?
Hello, I have a fresh openluup install on a raspberry. Just installed "Vera Bridge" plugin, but I can't make it to work. The plugin can not load the device infos from the vera. This is what I can see in the OpenLuup log : openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 I have tried it from a console on the same raspberry this way : wget http://192.168.1.2:3480/data_request?id=user_data2&output_format=json&ns=1 It worked, so I think it's not credential or network issue. What can be the solution for this ? more openluup log : 408 lines, 1 error, max gap 61s @ 2022-08-12 20:51:01.568 2022-08-12 19:21:24.150 :: openLuup LOG ROTATION :: (runtime 0.0 days) 2022-08-12 19:21:24.154 openLuup.init:: init phase completed 2022-08-12 19:21:24.155 openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x1c48ee8 2022-08-12 19:21:24.157 openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x1b461d8 2022-08-12 19:21:24.158 openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x1b48780 2022-08-12 19:21:24.158 openLuup.historian:: starting data historian 2022-08-12 19:21:24.159 openLuup.historian:: using memory cache size (per-variable): 1024 2022-08-12 19:21:24.168 openLuup.scheduler:: starting 2022-08-12 19:21:24.169 openLuup.scheduler:: [2] openLuup device startup 2022-08-12 19:21:24.170 luup_log:2: v22.7.31 2022-08-12 19:21:24.171 luup_log:2: sync in 35.8 s 2022-08-12 19:21:24.190 luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local 2022-08-12 19:21:24.193 luup.chdev.append:: [AltAppStore] Alternate App Store 2022-08-12 19:21:24.193 luup.chdev.sync:: [2] openLuup, syncing children 2022-08-12 19:21:24.194 luup_log:2: starting MQTT $SYS/broker statistics 2022-08-12 19:21:24.196 luup_log:2: 3Mb, 2.1%cpu, 0.0days 2022-08-12 19:21:24.211 openLuup.scheduler:: [2] openLuup device startup completed: status=true, msg=sync in 35.8 s, name=L_openLuup 2022-08-12 19:21:24.212 openLuup.scheduler:: [3] Alternate UI device startup 2022-08-12 19:21:24.212 luup_log:3: ALTUI: initstatus(3) starting version: v2.54 2022-08-12 19:21:24.214 openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name= 2022-08-12 19:21:24.214 openLuup.scheduler:: [7] VeraBridge device startup 2022-08-12 19:21:24.215 luup_log:7: VeraBridge 2022-08-12 19:21:24.215 luup_log:7: 2021.01.03 2022-08-12 19:21:24.216 luup_log:7: 192.168.1.2 2022-08-12 19:21:24.216 luup_log:7: device clone numbering starts at 10000 2022-08-12 19:21:24.217 luup_log:7: VeraBridge maps remote Zwave controller 2022-08-12 19:21:24.218 luup_log:7: v21.1.3 2022-08-12 19:21:24.242 openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 2022-08-12 19:21:24.242 luup.set_failure:: status = 2 2022-08-12 19:21:24.243 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 2 now: 2 #hooks:0 2022-08-12 19:21:24.244 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1660323316 now: 1660324884 #hooks:0 2022-08-12 19:21:24.246 luup_log:7: registering with AltUI [3] as Data Storage Provider 2022-08-12 19:21:24.247 luup.register_handler:: global_function_name=HTTP_VeraBridgeMirror_192.168.1.2, request=HTTP_VeraBridgeMirror_192.168.1.2 2022-08-12 19:21:24.249 luup.call_action:: 3.urn:upnp-org:serviceId:altui1.RegisterDataProvider 2022-08-12 19:21:24.260 openLuup.scheduler:: [7] VeraBridge device startup completed: status=, msg=No Vera, name=VeraBridge 2022-08-12 19:21:24.261 openLuup.scheduler:: [4] Alternate App Store device startup 2022-08-12 19:21:24.261 luup_log:4: AltAppStore : starting... 2022-08-12 19:21:24.262 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0 2022-08-12 19:21:24.263 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: #hooks:0 2022-08-12 19:21:24.264 luup_log:4: AltAppStore : v20.3.30 2022-08-12 19:21:24.264 luup.set_failure:: status = 0 2022-08-12 19:21:24.265 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.266 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.267 openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore 2022-08-12 19:21:24.268 openLuup.scheduler:: [5] Harmony Hub Control device startup 2022-08-12 19:21:24.280 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.LinkStatus was: Ok now: Starting... #hooks:0 2022-08-12 19:21:24.281 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.IconSet was: 0 now: 3 #hooks:0 2022-08-12 19:21:24.282 luup.attr_set:: 5.altid = HAM5_CNTRL 2022-08-12 19:21:24.326 luup.set_failure:: status = 0 2022-08-12 19:21:24.326 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.327 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.328 openLuup.scheduler:: [5] Harmony Hub Control device startup completed: status=true, msg=OK, name=Harmony Control 2022-08-12 19:21:24.332 luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.2,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2,[{ "default":"device.serviceId.name", "key":"mirror", "label":"Mirror", "type":"text" }]) 2022-08-12 19:21:24.337 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... #hooks:0 2022-08-12 19:21:24.360 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d21868 2022-08-12 19:21:24.363 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=323312852&Timeout=60&MinimumDelay=1500&=1660323303557 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:24.646 openLuup.server:: request completed (34267 bytes, 3 chunks, 280 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:24.648 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d6a9b0 2022-08-12 19:21:24.661 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=323312340&=1660323303558 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:25.252 openLuup.server:: request completed (70135 bytes, 5 chunks, 588 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:25.253 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2022-08-12 19:21:25.338 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.54 now: v2.54 #hooks:0 2022-08-12 19:21:25.934 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... now: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... #hooks:0 2022-08-12 19:21:25.964 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.996 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.999 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was: now: #hooks:0 2022-08-12 19:21:26.009 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.010 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.012 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0 2022-08-12 19:21:26.013 luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0) Thank You. d.
Vera Bridge
openLuup and Vera bridge
Vera Bridge
Vera Bridge
VeraBridge
Vera Bridge
Bridge openLuup to openLuup
P
Vera Bridge
Vera Bridge
Get Vera files throwing errors
Vera Bridge
Instant status
Vera Bridge
Scheduled Pinned Locked Moved Vera Bridge
11 Posts 3 Posters 3.2k Views 3 Watching
      This is caused by openLuup restarting and then unable to find Vera (which would be slower to start.)
      I thought this was fixed previously. You can obviously manually move them, but I assume you have too many. If you have no openLuup scenes on which they are dependent, you can simply delete them, reload, and all should be well.
        …or you could simply restore openLuup from your last, recent, backup?
          I can do both of the above - will probably use the backup, but just wanted to make sure I knew what was causing the issue. Clearly openLuup runs to fast. Another approach, besides a battery back up, could be to use systemd to control when openLuup starts. However I have little experience with systemd. Possibly someone has some idea on how systemd can make sure all remote Veras are up and running before openLuup starts? Or maybe that's something it would not typically be used for.
          B 1 Reply Last reply
            I’ll look more closely at the bridge code to check a few things. It’s not as though this always happens, though, so it may be a bizarre combination of things.
            • A a-lurker
              B Offline
              B Offline
              Buxton
              @a-lurker There's a systemd example in the openLuup user guide. Here's my startup based on those directions
              [Unit]
              Description=openLuup and AltUI Server for Vera
              After=network-online.target
              After=sockproxy.service
              Wants=network-online.target
              [Service]
              Type=forking
              ExecStartPre=/bin/sh -c 'until ping -c1 <VeraIP>; do sleep 1; done;'
              ExecStartPre=/bin/sleep 30
              WorkingDirectory=/etc/cmh-ludl
              ExecStart=/bin/bash /etc/cmh-ludl/openLuup_run.sh
              ExecStop=/bin/bash /etc/cmh-ludl/openLuup_stop.sh
              Restart=on-failure
              RestartSec=5
              [Install]
              WantedBy=multi-user.target
              "Wants=network-online.target" makes sure the network is up. Then the ping command loops until a response is sent back from the vera. Followed by a 30 second sleep to allow everything else to get up and running. However, no vera up-- no openLuup as the ping does not time out.
              Your router must allow ICMP between the vera and the OL host. Per the OL help file, you then need to create the .sh files and then activate the systemd service. I use Patrick's sock proxy for an app, so that command does not need to be in there if you don't use the proxy.
                akbooer thanks for the help. I seem to have it sorted out now. I do note that in the console/utilities/backups, that if you click on one of any the backups listed, a *.json file is presented for download rather than a *.lzap file. Not that it matters, as openLuup_reload seems to take either file type as a parameter and handle it accordingly. Like wise if you click on the "Backup Now" button, you a presented with a file that begins with "backup_backup.openLuup ...." Looks like the backup directory name has been prefixed to the filename. Not that matters either. A back up is a back up.
                  Buxton . Yes I think I should be using systemd. Currently I'm using rc.local for start up. Thought you were rather optimist using just a 30 second delay after being able to ping Vera!!!
                  Could you please post your openLuup_run.sh and openLuup_stop.sh scripts.
                  Thanks for the feedback.
                  • A a-lurker
                    @a-lurker said in Power outage and all the Vera devices were moved to room MiOS-xxxxx. How to fix?:
                    Thanks for that. Yes, same for me. I will fix it.
                    However, when I download, I get a .lzap file, not a .json one. What system are you using to download?
                    EDIT:
                    Actually, I only checked the .lzap file for an actual live backup, not from the list of previous backups. This may be the difference.
                    • A a-lurker
                      B Offline
                      B Offline
                      Buxton
                      @a-lurker Yeah, HA takes a couple of minutes to fully start, so 30 seconds is the bare minimum I could get away with on my system. Not to mention the host server's atom processor, while parsimonious on power use, is a dog when ten containers are starting up from boot. Luckily, power outages here are infrequent. When prices are right, I'll get a home battery/solar setup to eliminate that rare nuisance.
                      Place in "/etc/cmh-ludl"
                      openLuup_run.sh
                      #!/bin/bash
                      echo "Starting openLuup server"
                      echo "To see tail of logfile: tail -f ./out.log"
                      cd /etc/cmh-ludl
                      sudo rm /etc/cmh-ludl/logs/out.log
                      nohup ./openLuup_reload >> /etc/cmh-ludl/logs/out.log 2>&1 &
                      openLuup_stop.sh
                      #!/bin/bash
                      echo "Stopping openLuup server"
                      cd /etc/cmh-ludl
                      curl http://localhost:3480/data_request?id=exit
                      Then start the "openluup" service with:
                      $ sudo systemctl enable openluup
                      $ sudo systemctl start openluup
                      • B Buxton
                        openLuup_run.sh
                        #!/bin/bash
                        cd /etc/cmh-ludl
                        openLuup_stop.sh
                        #!/bin/bash
                        cd /etc/cmh-ludl
                        @Buxton OK got the systemd stuff working - thanks for that. A of couple notes for future readers:
                        • The script files need to be executable, so the permissions should be set to 0755.
                        • the scripts should use \n, not \r\n line endings ie Unix style
                        • you need to run this once to get the necessary symlinks built:
                          165.3k
