  3. Vera Bridge
  4. Get Vera files throwing errors
Hello, I have a fresh openluup install on a raspberry. Just installed "Vera Bridge" plugin, but I can't make it to work. The plugin can not load the device infos from the vera. This is what I can see in the OpenLuup log : openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 I have tried it from a console on the same raspberry this way : wget http://192.168.1.2:3480/data_request?id=user_data2&output_format=json&ns=1 It worked, so I think it's not credential or network issue. What can be the solution for this ? more openluup log : 408 lines, 1 error, max gap 61s @ 2022-08-12 20:51:01.568 2022-08-12 19:21:24.150 :: openLuup LOG ROTATION :: (runtime 0.0 days) 2022-08-12 19:21:24.154 openLuup.init:: init phase completed 2022-08-12 19:21:24.155 openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x1c48ee8 2022-08-12 19:21:24.157 openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x1b461d8 2022-08-12 19:21:24.158 openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x1b48780 2022-08-12 19:21:24.158 openLuup.historian:: starting data historian 2022-08-12 19:21:24.159 openLuup.historian:: using memory cache size (per-variable): 1024 2022-08-12 19:21:24.168 openLuup.scheduler:: starting 2022-08-12 19:21:24.169 openLuup.scheduler:: [2] openLuup device startup 2022-08-12 19:21:24.170 luup_log:2: v22.7.31 2022-08-12 19:21:24.171 luup_log:2: sync in 35.8 s 2022-08-12 19:21:24.190 luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local 2022-08-12 19:21:24.193 luup.chdev.append:: [AltAppStore] Alternate App Store 2022-08-12 19:21:24.193 luup.chdev.sync:: [2] openLuup, syncing children 2022-08-12 19:21:24.194 luup_log:2: starting MQTT $SYS/broker statistics 2022-08-12 19:21:24.196 luup_log:2: 3Mb, 2.1%cpu, 0.0days 2022-08-12 19:21:24.211 openLuup.scheduler:: [2] openLuup device startup completed: status=true, msg=sync in 35.8 s, name=L_openLuup 2022-08-12 19:21:24.212 openLuup.scheduler:: [3] Alternate UI device startup 2022-08-12 19:21:24.212 luup_log:3: ALTUI: initstatus(3) starting version: v2.54 2022-08-12 19:21:24.214 openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name= 2022-08-12 19:21:24.214 openLuup.scheduler:: [7] VeraBridge device startup 2022-08-12 19:21:24.215 luup_log:7: VeraBridge 2022-08-12 19:21:24.215 luup_log:7: 2021.01.03 2022-08-12 19:21:24.216 luup_log:7: 192.168.1.2 2022-08-12 19:21:24.216 luup_log:7: device clone numbering starts at 10000 2022-08-12 19:21:24.217 luup_log:7: VeraBridge maps remote Zwave controller 2022-08-12 19:21:24.218 luup_log:7: v21.1.3 2022-08-12 19:21:24.242 openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 2022-08-12 19:21:24.242 luup.set_failure:: status = 2 2022-08-12 19:21:24.243 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 2 now: 2 #hooks:0 2022-08-12 19:21:24.244 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1660323316 now: 1660324884 #hooks:0 2022-08-12 19:21:24.246 luup_log:7: registering with AltUI [3] as Data Storage Provider 2022-08-12 19:21:24.247 luup.register_handler:: global_function_name=HTTP_VeraBridgeMirror_192.168.1.2, request=HTTP_VeraBridgeMirror_192.168.1.2 2022-08-12 19:21:24.249 luup.call_action:: 3.urn:upnp-org:serviceId:altui1.RegisterDataProvider 2022-08-12 19:21:24.260 openLuup.scheduler:: [7] VeraBridge device startup completed: status=, msg=No Vera, name=VeraBridge 2022-08-12 19:21:24.261 openLuup.scheduler:: [4] Alternate App Store device startup 2022-08-12 19:21:24.261 luup_log:4: AltAppStore : starting... 2022-08-12 19:21:24.262 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0 2022-08-12 19:21:24.263 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: #hooks:0 2022-08-12 19:21:24.264 luup_log:4: AltAppStore : v20.3.30 2022-08-12 19:21:24.264 luup.set_failure:: status = 0 2022-08-12 19:21:24.265 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.266 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.267 openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore 2022-08-12 19:21:24.268 openLuup.scheduler:: [5] Harmony Hub Control device startup 2022-08-12 19:21:24.280 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.LinkStatus was: Ok now: Starting... #hooks:0 2022-08-12 19:21:24.281 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.IconSet was: 0 now: 3 #hooks:0 2022-08-12 19:21:24.282 luup.attr_set:: 5.altid = HAM5_CNTRL 2022-08-12 19:21:24.326 luup.set_failure:: status = 0 2022-08-12 19:21:24.326 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.327 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.328 openLuup.scheduler:: [5] Harmony Hub Control device startup completed: status=true, msg=OK, name=Harmony Control 2022-08-12 19:21:24.332 luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.2,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2,[{ "default":"device.serviceId.name", "key":"mirror", "label":"Mirror", "type":"text" }]) 2022-08-12 19:21:24.337 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... #hooks:0 2022-08-12 19:21:24.360 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d21868 2022-08-12 19:21:24.363 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=323312852&Timeout=60&MinimumDelay=1500&=1660323303557 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:24.646 openLuup.server:: request completed (34267 bytes, 3 chunks, 280 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:24.648 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d6a9b0 2022-08-12 19:21:24.661 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=323312340&=1660323303558 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:25.252 openLuup.server:: request completed (70135 bytes, 5 chunks, 588 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:25.253 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2022-08-12 19:21:25.338 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.54 now: v2.54 #hooks:0 2022-08-12 19:21:25.934 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... now: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... #hooks:0 2022-08-12 19:21:25.964 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.996 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.999 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was: now: #hooks:0 2022-08-12 19:21:26.009 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.010 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.012 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0 2022-08-12 19:21:26.013 luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0) Thank You. d.
Vera Bridge
openLuup and Vera bridge
Vera Bridge
Vera Bridge
VeraBridge
Vera Bridge
Bridge openLuup to openLuup
P
Vera Bridge
Vera Bridge
Vera Bridge
Instant status
Vera Bridge
Scheduled Pinned Locked Moved Solved Vera Bridge
37 Posts 4 Posters 21.2k Views 4 Watching
    OK, this was overwritten because you updated it from the default (master) branch, rather than the development one. It’s entirely my fault that this is possible. Sorry.
    Solution is to update openLuup from the development branch again. This should replace that file with the correct one. getVeraFiles should then work.
      RogerO
      #22
      How do I specify that? Of should I just write development in the update box for the plugins?
      No worries about the issue. Glad to help finding it, and currently am just playing with it.
        RogerO
        Got it. Thanks for your help.
        Plugin Startup Jobs CPU usage (in startup order)
        date / time device priority status hh🇲🇲ss.sss job # info notes
        1 2020-05-03 15:22:33.769 2 1 Done 0.004 1 plugin: openLuup sync in 86.7 s
        2 2020-05-03 15:22:33.770 3 3 Done 0.000 2 plugin: Alternate UI
        3 2020-05-03 15:22:39.200 5 5 Done 4.403 4 plugin: VeraBridge OK
        4 2020-05-03 15:22:39.293 6 5 Done 0.008 5 plugin: Z-Way OK
        5 2020-05-03 15:22:39.294 4 Done 0.001 3 plugin: Alternate App Store OK
          RogerO
          I am still getting a lot of 503 errors and have quite a few devices from Vera that do not have all the controls present and functioning. Any ideas on why that might be happening?
            Perhaps Vera just can’t keep up, although I’ve never seen this before.
            Are these always the same files, or are you incrementally getting what you need? I really don’t know what to suggest for this one... anyone else seen anything like this?
            Which devices are not working? If it’s not too many, you can manually download.
            Alternatively, you can add a parameter to the GetVeraFiles request in the form of a Lua search pattern.
            For example
            Binary
            will download all files with "Binary" in the name.
              Granted I am not using vera anymore, for the couple of years I have used the vera bridge, no, I have not seen this.
              I was actually wondering the same thing: Did something in the recent vera firmwares attempt to block files upload.
              Or is the socket of openWRT just overwhelmed by the command frequency?
              Also @RogerO, what is between your vera and the openLuup machine? Wondering if you are having LAN packet losses.
                RogerO
                I have been running the getfiles job specifying file types and I am seeing more devices that have the correct controls now. I am still missing most of the icons on the devices
                Here is a breakdown by device type:.
                Dimmable Switch: controls working, all have generic icon regardless of level and state.
                Door Lock: Controls working. Generic icon
                HVAC: controls and icons correct
                Light Sensor: lux readings correct, generic icons
                On/Off switch: Controls working, generic icons except Harmony Control
                Motion Sensors: controls working, generic icons except for reactor
                Temp sensors: functioning, generic icons.
                So it looks like everything is functioning, just some icons are not displaying.
                Which file has the icon description?
                max packet size ping test between Vera and RPI
                ping 192.168.0.143 -s65507
                8 packets transmitted, 8 received, 0% packet loss, time 7009ms
                rtt min/avg/max/mdev = 12.750/12.915/13.079/0.157 ms
                  #28
                  The D_XYX.json controls the icons display. I suspect though that you are missing the icon file which is buried in the /www folder of the vera and has been moving around from version to version of firmware and might be what is failing?
                    Yes, it’s possible that the icons are not found. The bridge does try downloading them from different places according to the firmware, but maybe that’s what’s gone wrong. A log file showing the GetVeraFiles activity would confirm that.
                      RogerO
                      #30
                      Just picked dimmable lights as an example. Looking in d_DimmableLight1.json I see this in the first few lines:
                      "default_icon": "dimmable_light_default.png",
                      "state_icons": [
                      "img": "dimmable_light_100.png",
                      These files are on the RPI
                      pi@raspberrypi:/etc/cmh-ludl/icons $ ls dimmable
                      But I am only getting the generic z-wave icon in the UI
                        Is there a file ownership issue? ie. can you actually see those files if you look for them through the openLuup server? I have seen this sometimes, depending on how openLuup is started at boot time. How DOES your openLuup startup work?
                          RogerO
                          Interesting, just noticed that the files on the RPI are 0 bytes. Let me see if I can figure out why.
                            RogerO
                            So I copied all the png files off my Vera and moved them into the /cmh-ludl/icons folder on my rpi. That fixed the bulb icons for dimmable lights and some of the others. I am still getting generic icons for binary lights. According to the json file it should be using the binary_light_default.png file. file is there in the icons folder and has the following permissions.
                            -rw-r--r-- 1 pi pi 683 Dec 13 07:44 binary_light_default.png
                            Looks the same as the dimable light png file that works
                            -rw-r--r-- 1 pi pi 909 Dec 13 07:44 dimmable_light_20.png
                            Are there other locations the app looks for to finds icons to use?
                              Apps don’t look for icons, AltUI does. Also, openLuup itself.
                              Does the openLuup console Devices page look any different (from an icon POV) from that of the AltUI one?
                              htttp://openLuupIP:3480/openLuup?page=devices
                                RogerO
                                Well, left to run some errands and looking now, all the icons are correct except for a few like eventwatcher, sonos and vera Alerts. No idea why. OpenLuup and ALTUI are both showing correct icons now.
                                  Maybe a browser cache refresh?
                                    #37
                                    @rogero said in Get Vera files throwing errors:
                                    Interesting, just noticed that the [icon] files on the RPI are 0 bytes.
                                    This issue is now solved:
                                    https://smarthome.community/topic/20/openluup-version-log/12
                                      164.4k
