  3. Vera Bridge
  4. Get Vera files throwing errors
Openluup - verabridge can not load devices.
Hello, I have a fresh openluup install on a raspberry. Just installed "Vera Bridge" plugin, but I can't make it to work. The plugin can not load the device infos from the vera. This is what I can see in the OpenLuup log : openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 I have tried it from a console on the same raspberry this way : wget http://192.168.1.2:3480/data_request?id=user_data2&output_format=json&ns=1 It worked, so I think it's not credential or network issue. What can be the solution for this ? more openluup log : 408 lines, 1 error, max gap 61s @ 2022-08-12 20:51:01.568 2022-08-12 19:21:24.150 :: openLuup LOG ROTATION :: (runtime 0.0 days) 2022-08-12 19:21:24.154 openLuup.init:: init phase completed 2022-08-12 19:21:24.155 openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x1c48ee8 2022-08-12 19:21:24.157 openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x1b461d8 2022-08-12 19:21:24.158 openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x1b48780 2022-08-12 19:21:24.158 openLuup.historian:: starting data historian 2022-08-12 19:21:24.159 openLuup.historian:: using memory cache size (per-variable): 1024 2022-08-12 19:21:24.168 openLuup.scheduler:: starting 2022-08-12 19:21:24.169 openLuup.scheduler:: [2] openLuup device startup 2022-08-12 19:21:24.170 luup_log:2: v22.7.31 2022-08-12 19:21:24.171 luup_log:2: sync in 35.8 s 2022-08-12 19:21:24.190 luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local 2022-08-12 19:21:24.191 luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local 2022-08-12 19:21:24.192 luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local 2022-08-12 19:21:24.193 luup.chdev.append:: [AltAppStore] Alternate App Store 2022-08-12 19:21:24.193 luup.chdev.sync:: [2] openLuup, syncing children 2022-08-12 19:21:24.194 luup_log:2: starting MQTT $SYS/broker statistics 2022-08-12 19:21:24.196 luup_log:2: 3Mb, 2.1%cpu, 0.0days 2022-08-12 19:21:24.211 openLuup.scheduler:: [2] openLuup device startup completed: status=true, msg=sync in 35.8 s, name=L_openLuup 2022-08-12 19:21:24.212 openLuup.scheduler:: [3] Alternate UI device startup 2022-08-12 19:21:24.212 luup_log:3: ALTUI: initstatus(3) starting version: v2.54 2022-08-12 19:21:24.214 openLuup.scheduler:: [3] Alternate UI device startup completed: status=, msg=, name= 2022-08-12 19:21:24.214 openLuup.scheduler:: [7] VeraBridge device startup 2022-08-12 19:21:24.215 luup_log:7: VeraBridge 2022-08-12 19:21:24.215 luup_log:7: 2021.01.03 2022-08-12 19:21:24.216 luup_log:7: 192.168.1.2 2022-08-12 19:21:24.216 luup_log:7: device clone numbering starts at 10000 2022-08-12 19:21:24.217 luup_log:7: VeraBridge maps remote Zwave controller 2022-08-12 19:21:24.218 luup_log:7: v21.1.3 2022-08-12 19:21:24.242 openLuup.client:: WGET error status: -1, request: http://192.168.1.2/port_3480/data_request?id=user_data2&output_format=json&ns=1 2022-08-12 19:21:24.242 luup.set_failure:: status = 2 2022-08-12 19:21:24.243 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 2 now: 2 #hooks:0 2022-08-12 19:21:24.244 luup.variable_set:: 7.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 1660323316 now: 1660324884 #hooks:0 2022-08-12 19:21:24.246 luup_log:7: registering with AltUI [3] as Data Storage Provider 2022-08-12 19:21:24.247 luup.register_handler:: global_function_name=HTTP_VeraBridgeMirror_192.168.1.2, request=HTTP_VeraBridgeMirror_192.168.1.2 2022-08-12 19:21:24.249 luup.call_action:: 3.urn:upnp-org:serviceId:altui1.RegisterDataProvider 2022-08-12 19:21:24.260 openLuup.scheduler:: [7] VeraBridge device startup completed: status=, msg=No Vera, name=VeraBridge 2022-08-12 19:21:24.261 openLuup.scheduler:: [4] Alternate App Store device startup 2022-08-12 19:21:24.261 luup_log:4: AltAppStore : starting... 2022-08-12 19:21:24.262 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: AltAppStore #hooks:0 2022-08-12 19:21:24.263 luup.variable_set:: 4.urn:upnp-org:serviceId:altui1.DisplayLine2 was: now: #hooks:0 2022-08-12 19:21:24.264 luup_log:4: AltAppStore : v20.3.30 2022-08-12 19:21:24.264 luup.set_failure:: status = 0 2022-08-12 19:21:24.265 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.266 luup.variable_set:: 4.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.267 openLuup.scheduler:: [4] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore 2022-08-12 19:21:24.268 openLuup.scheduler:: [5] Harmony Hub Control device startup 2022-08-12 19:21:24.280 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.LinkStatus was: Ok now: Starting... #hooks:0 2022-08-12 19:21:24.281 luup.variable_set:: 5.urn:rboer-com:serviceId:Harmony1.IconSet was: 0 now: 3 #hooks:0 2022-08-12 19:21:24.282 luup.attr_set:: 5.altid = HAM5_CNTRL 2022-08-12 19:21:24.326 luup.set_failure:: status = 0 2022-08-12 19:21:24.326 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.327 luup.variable_set:: 5.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: 0 now: 0 #hooks:0 2022-08-12 19:21:24.328 openLuup.scheduler:: [5] Harmony Hub Control device startup completed: status=true, msg=OK, name=Harmony Control 2022-08-12 19:21:24.332 luup_log:3: ALTUI: UPNPregisterDataProvider(3,Vera@192.168.1.2,http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2,[{ "default":"device.serviceId.name", "key":"mirror", "label":"Mirror", "type":"text" }]) 2022-08-12 19:21:24.337 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... #hooks:0 2022-08-12 19:21:24.360 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d21868 2022-08-12 19:21:24.363 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=323312852&Timeout=60&MinimumDelay=1500&=1660323303557 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:24.646 openLuup.server:: request completed (34267 bytes, 3 chunks, 280 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:24.648 openLuup.io.server:: HTTP:3480 connection from 192.168.1.24 tcp{client}: 0x1d6a9b0 2022-08-12 19:21:24.661 openLuup.server:: GET /data_request?id=user_data&output_format=json&DataVersion=323312340&=1660323303558 HTTP/1.1 tcp{client}: 0x1d21868 2022-08-12 19:21:25.252 openLuup.server:: request completed (70135 bytes, 5 chunks, 588 ms) tcp{client}: 0x1d21868 2022-08-12 19:21:25.253 luup_log:3: ALTUI: startupDeferred, called on behalf of device:3 2022-08-12 19:21:25.338 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Version was: v2.54 now: v2.54 #hooks:0 2022-08-12 19:21:25.934 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"Vera@192.168.1.2":{"url":"http://127.0.0.1:3480/data_request?id=lr_HTTP_VeraBridgeMirror_192.168.1.2","callback":... now: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... #hooks:0 2022-08-12 19:21:25.964 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"thingspeak":{"url":"","callback":"sendValueToStorage_thingspeak","parameters":[{"type":"number","key":"channelid"... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.996 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DataStorageProviders was: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... now: {"emoncms":{"url":"","callback":"sendValueToStorage_emoncms","parameters":[{"default":1,"type":"number","key":"node... #hooks:0 2022-08-12 19:21:25.999 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToSend was: now: #hooks:0 2022-08-12 19:21:26.009 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.RemoteVariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.010 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.VariablesToWatch was: now: #hooks:0 2022-08-12 19:21:26.012 luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.Timers was: [] now: [] #hooks:0 2022-08-12 19:21:26.013 luup_log:3: ALTUI: Wkflow - enableWorkflows(3,0,0) Thank You. d.
Vera Bridge
openLuup and Vera bridge
Question: if you have devices in a Vera that are bridged to openLuup and then you delete some of those device off the Vera, then how do you tell Vera Bridge to update those virtual Vera devices in openLuup? I've done this in the past and it just came good but I'm not sure how that occurred. I've tried a few Luup engine restarts to no avail. EDIT: looks like it has come good, all by itself, once again. What's the functionality behind this?
Vera Bridge
Power outage and all the Vera devices were moved to room MiOS-xxxxx. How to fix?
"Verabridge has a CloneRooms variable which should be set to true to force all bridged devices to be in the same rooms as on the remote Vera. Devices which are in "No Room" remotely, are placed in the appropriately named "MiOS..." room which corresponds to the remote machine name." Noting the above: OpenLuup has moved all the remote Vera devices from the correct rooms (where they have resided for years) to the MiOS-xxxxx room. I think it was caused by a power outage and it may have been some problem with the Vera and openLuup RasPi subsequently rebooting at different times (possibly). The CloneRooms variable is set to true. Did a couple of openLuup restarts but the remote Vera devices stayed in the MiOS-xxxxx room. Note that on the Vera all devices are still in their correct rooms that are mirrored in openLuup. They are not in "No room" on the Vera. Any idea on how to get the all remote Vera devices out of the MiOS-xxxxx room and back to their correct rooms in openLuup?
Vera Bridge
VeraBridge
This morning following a micro power cut, I have a problem with Vera Bridge. After a GetVeraFiles I have this message: 162: VeraBridge: [string "openLuup / L_VeraBridge.lua"]: 771: attempt to index upvalue 'BuildVersion' (a nil value)
Vera Bridge
Bridge openLuup to openLuup
P
Trying to bridge openLuup with another openLuup using Verabridge and getting no Vera. Is this the correct way of linking the two?
Vera Bridge
How can I remove old devices that are no longer in VERA
H
I have read this someone before but I cannot find the answer again. I have several devices and scenes in Vera which have been deleted so now the issue is to identify which ones they are in openluup ALTUI and remove them. I thought there was a process where you would delete the bridge and then add it again but I cant remember. Can anyone point me in the right direction? Thanks
Vera Bridge
Hello, Had a RPI laying around and saw the cheap razberry board so picked one up last week. Am trying to set up ALTUI and connect to my Vera Plus. Of the 80 or so devices it pulled in from my Vera, only about 14 look like they are functional. When I run the GetVeraFiles from the VeraBridge actions menu, I see a bunch of 503 errors in the log. If I open the URL that it is erroring on in the browser, it usually returns a valid image or page. Is there a way to attach logs to messages or is it acceptable to just paste in the entire thing as text? Let me know what info you need to see to point me in the right direction. Thanks, Roger
Vera Bridge
Instant status
Since Vera support sucks and I have this intermittent problem. Several devices which were included successfully and had always have instant status (updating vera directly when pressed locally) stop working every now and then. Vera support has 1 solution: exclude & include. And yes this works. But then after a while it starts all over and eventually I end up with a regular exclude include session which is unacceptable. Currently I am somewhere a around device number 1600 (no joke!). Vera tells me they can set and association to 1 (lifeline) to try. Is there any feasible solution which is stable to keep this working? Where to start? I only have Vera as zwave bridge...
Vera Bridge
Scheduled Pinned Locked Moved Solved Vera Bridge
37 Posts 4 Posters 20.7k Views 4 Watching
    #28
    The D_XYX.json controls the icons display. I suspect though that you are missing the icon file which is buried in the /www folder of the vera and has been moving around from version to version of firmware and might be what is failing?
      Yes, it’s possible that the icons are not found. The bridge does try downloading them from different places according to the firmware, but maybe that’s what’s gone wrong. A log file showing the GetVeraFiles activity would confirm that.
        RogerO
        #30
        Just picked dimmable lights as an example. Looking in d_DimmableLight1.json I see this in the first few lines:
        "default_icon": "dimmable_light_default.png",
        "state_icons": [
        "img": "dimmable_light_100.png",
        These files are on the RPI
        pi@raspberrypi:/etc/cmh-ludl/icons $ ls dimmable
        But I am only getting the generic z-wave icon in the UI
          Is there a file ownership issue? ie. can you actually see those files if you look for them through the openLuup server? I have seen this sometimes, depending on how openLuup is started at boot time. How DOES your openLuup startup work?
            RogerO
            Interesting, just noticed that the files on the RPI are 0 bytes. Let me see if I can figure out why.
              RogerO
              So I copied all the png files off my Vera and moved them into the /cmh-ludl/icons folder on my rpi. That fixed the bulb icons for dimmable lights and some of the others. I am still getting generic icons for binary lights. According to the json file it should be using the binary_light_default.png file. file is there in the icons folder and has the following permissions.
              -rw-r--r-- 1 pi pi 683 Dec 13 07:44 binary_light_default.png
              Looks the same as the dimable light png file that works
              -rw-r--r-- 1 pi pi 909 Dec 13 07:44 dimmable_light_20.png
              Are there other locations the app looks for to finds icons to use?
                Apps don’t look for icons, AltUI does. Also, openLuup itself.
                Does the openLuup console Devices page look any different (from an icon POV) from that of the AltUI one?
                htttp://openLuupIP:3480/openLuup?page=devices
                  RogerO
                  Well, left to run some errands and looking now, all the icons are correct except for a few like eventwatcher, sonos and vera Alerts. No idea why. OpenLuup and ALTUI are both showing correct icons now.
                    Maybe a browser cache refresh?
                      #37
                      @rogero said in Get Vera files throwing errors:
                      Interesting, just noticed that the [icon] files on the RPI are 0 bytes.
                      This issue is now solved:
                      https://smarthome.community/topic/20/openluup-version-log/12
                        159.9k
