reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
[SOLVED] All Modes not visible in MSR 21337 from Hubitat
OK. 21338
@toggledbits Yep - all good! Thanks Patrick, I'll mark this as solved. Appreciate it.
Thanks for doing the footwork, being the hands and eyes! Sorry for the trouble. Onward!
