  4. Plugin InfluxFeed - Selecting Capabilities for Export - how to
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
11 Posts 2 Posters 2.3k Views 2 Watching
  • N Offline
    N Offline
    hi, I'm trying to modify reator.yaml as illustrated in docs but no luck to change something, I continue to see only default capabilities/attributes.
    How can I understand better the problem?
    Example OWM:
    I want to add wx.feels_like and wx.pressure
    is it correct? if yes, there are no changes in db fields
      select_capabilities:
           x_ezlo_item: true
           wx:
             attributes:
                - feels_like
                - pressure
                - electric_meter_kwh
                - electric_meter_watt
    If I want to add these parameter?
    • x_ezlo_item.electric_meter_kwh
    • x_ezlo_item.electric_meter_watt
    After I did the changes, I let to start influxdb first and then MSR.
    Also creating new bucket, I don't see any changes.
    Synology - Docker
    Influxdb 2.1.1
    Reactor (Multi-hub) latest-21342-ead7ca9
    -Docker on Synology NAS
    -HASS Docker 2026.8.1
    -ZWaveJS-UI 11.22.3
    -Update 16/08/2026
      Can you show your entire config for InfluxDB plugin? The indenting of your example would be incorrect to start, so I'd like to see the whole thing and make sure you're starting from something that has a chance at being functional. This doesn't look right on its face, but being a subset of the entire, it's hard to be sure.
      • N Offline
        N Offline
        Hi, this is the config
        plugins:
          - id: influx
            # See the docs under Standard Plugins for configuration details.
            implementation: InfluxFeed
            enabled: true
            config:
              # influx_url - URL to access InfluxDB server (default: http://localhost:8086)
              influx_url: "http://10.0.4.71:8086"
              # ----- For InfluxDB 2.0+ ONLY -----
              # influx_token - Token from InfluxDB 2.0 UI (required)
              influx_token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
              # influx_org - Organization ID (required)
              influx_org: myhome
              # influx_bucket - Bucket name to which points are written (required)
              influx_bucket: reactor
              # ----- Optional (all versions) -----
              # influx_retention_policy - Retention policy (optional). If not specified,
              #                           the retention policy of the bucket/database
              #                           will be used.
              #influx_retention_policy: ""
              # ----- Filtering (all versions) -----
              # select_capabilities - Capabilities that should be exported in addition
              #                       to the defaults. These are key/value pairs. If the
              #                       value is false, the capability is not exported (so
              #                       you can override the default). If the value is an
              #                       object, it may contain an "attributes" key with an
              #                       array value containing the names of attributes to
              #                       be exported (other attributes in the capability
              #                       are ignored).
                light_sensor: true
                power_sensor: true
                dimming: false
                x_ezlo_item: true
                  attributes:
              #  zwave_network: false  # do not export this capability
               wx:                   # export wx capability, but only named attributes
                 attributes:
                    - temperature
                    - humidity
                    - feels_like
        -ZWaveJS-UI 11.22.3
        -Update 16/08/2026
          OK. Your indenting is wonky and there's another error that's probably causing problems parsing the entire config. You should use a tool like https://yamlchecker.com on any changes you make (paste the entire config file) until you get used to the idiosyncrasies of YAML, and then any time you run into problems. There are also probably messages in the log file about problems reading the file, too, so be sure and always check there when something is not working as expected.
          Specifically, on line 42, you can't have object keys in this position, because line 41 defines a value (true) for x_ezlo_item. Using true says you want everything from that capability; it's a short-cut. If you mean to limit the set of attributes for x_ezlo_item, then the value there must be an object for which attributes is a key. So that would correctly look like this (other lines redacted for clarity):
                  x_ezlo_item:
                    attributes:
          Your wx line (47) is not correctly indented, nor is the comment line before it, so that's going to be trouble as well. It should look like this in all:
          plugins:
            - id: influx
              enabled: true
              config:
                influx_org: myhome
                #                           will be used.
                #                       are ignored).
                  light_sensor: true
                  power_sensor: true
                  dimming: false
                  x_ezlo_item:
                    attributes:
                  #zwave_network: false  # do not export this capability
                    attributes:
                      - temperature
                      - humidity
                      - feels_like
          Unfortunately, I realize YAML is a nuisance, but JSON would be worse, I loathe XML and its progeny, and the Microsoft-ish INI format isn't really up to the task either. I begrudgingly chose YAML because there's little that's better, and a lot of tools and documentation for it. Eventually, there will be a GUI for this kind of configuration, but that's a good way off yet.
          • N Offline
            N Offline
            I corrected the file
            Valid YAML!
            Still no changes in influxdb
            I created a new bucket and new api tokens, when I go in "Explore" --> Filter Measurement -->Filter
            I see only default data:
            dimming is there
            no wx.feels_like
            and no x_ezlo_item
            also I stopped both container and I started first influxdb and then MSR, where I can check now?
            -ZWaveJS-UI 11.22.3
            -Update 16/08/2026
              It will only log things when things change. So make sure you are making things happen.
              Also, what version of InfluxDB are you using?
              And check the log file, particularly the messages output at startup.
              • N Offline
                N Offline
                Is is version InfluxDB 2.1.1
                a lot of Warm from Ezlo
                [latest-21342]2021-12-11T22:44:11.586Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.599Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.615Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.633Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.637Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.638Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.639Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.639Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.640Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.640Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.641Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.641Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.642Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.642Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.643Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.643Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.644Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.644Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.648Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.649Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.651Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.657Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.657Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.658Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.658Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.659Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.660Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.663Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.664Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.665Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.666Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.667Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.668Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.668Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.669Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.670Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.red for attribute rgb_color.red in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member red of null
                [latest-21342]2021-12-11T22:44:11.670Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.green for attribute rgb_color.green in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member green of null
                [latest-21342]2021-12-11T22:44:11.671Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.blue for attribute rgb_color.blue in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member blue of null
                [latest-21342]2021-12-11T22:44:11.671Z <EzloController:ERR> EzloController#ezlo failed to evaluate expression value.cwhite > 0 ? floor( 5500 + value.cwhite * 3500 / 255 ) : floor( 2000 + value.wwhite * 3500 / 255 ) for attribute color_temperature.value in category=dimmable_light;subcategory=dimmable_colored: ReferenceError: Invalid reference to member cwhite of null
                [latest-21342]2021-12-11T22:44:11.693Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=door_lock cap keypad
                [latest-21342]2021-12-11T22:44:11.727Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 971ms
                [latest-21342]2021-12-11T22:44:11.728Z <EzloController:NOTICE> Controller EzloController#ezlo is now online.
                [latest-21342]2021-12-11T22:44:11.730Z <DynamicGroupController:ERR> DynamicGroupController#groups selector criterion invalid type, expecting object, got string (battery_power)
                [latest-21342]2021-12-11T22:44:11.731Z <DynamicGroupController:ERR> DynamicGroupController#groups error in selection for Group#groups>low_battery: Error: Invalid selector
                [latest-21342]2021-12-11T22:44:11.731Z <DynamicGroupController:CRIT> Error: Invalid selector
                    at DynamicGroupController._select (/opt/reactor/server/lib/DynamicGroupController.js:314:23)
                    at DynamicGroupController._update_group (/opt/reactor/server/lib/DynamicGroupController.js:219:44)
                    at /opt/reactor/server/lib/DynamicGroupController.js:298:38
                    at DynamicGroupController._update (/opt/reactor/server/lib/DynamicGroupController.js:295:82)
                    at /opt/reactor/server/lib/DynamicGroupController.js:174:42
                [latest-21342]2021-12-11T22:44:11.732Z <app:NOTICE> Starting HTTP server and API...
                [latest-21342]2021-12-11T22:44:11.737Z <app:NOTICE> Starting Reaction Engine...
                [latest-21342]2021-12-11T22:44:11.737Z <Engine:INFO> Reaction Engine starting
                [latest-21342]2021-12-11T22:44:11.738Z <Engine:INFO> Checking rule sets...
                [latest-21342]2021-12-11T22:44:11.747Z <Engine:INFO> Checking rules...
                [latest-21342]2021-12-11T22:44:11.748Z <Engine:INFO> Data check complete; no corrections.
                -ZWaveJS-UI 11.22.3
                -Update 16/08/2026
                  Well, we're looking for InfluxDB messages at the moment. Anything?
                  • N Offline
                    N Offline
                    wrote on last edited by noelab
                    About InfluxDb I don't see any warn at startup
                    [latest-21342]2021-12-11T23:21:26.561Z <app:null> Reactor latest-21342-ead7ca9 starting on v16.11.1
                    [latest-21342]2021-12-11T23:21:26.562Z <app:INFO> Process ID 1; platform linux/x64 #42218 SMP Mon Oct 18 19:16:55 CST 2021; locale (undefined)
                    [latest-21342]2021-12-11T23:21:26.563Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
                    [latest-21342]2021-12-11T23:21:26.563Z <app:INFO> NODE_PATH=/opt/reactor
                    [latest-21342]2021-12-11T23:21:26.566Z <app:INFO> Configured locale (undefined); selected locale(s) en-US.UTF-8
                    [latest-21342]2021-12-11T23:21:26.588Z <app:INFO> Loaded locale en-US
                    [latest-21342]2021-12-11T23:21:26.597Z <Capabilities:null> Module Capabilities v21333
                    [latest-21342]2021-12-11T23:21:26.639Z <Plugin:null> Module Plugin v21186
                    [latest-21342]2021-12-11T23:21:26.644Z <TimerBroker:null> Module TimerBroker v21333
                    [latest-21342]2021-12-11T23:21:26.646Z <default:INFO> Module Entity v21334
                    [latest-21342]2021-12-11T23:21:26.650Z <Controller:null> Module Controller v21333
                    [latest-21342]2021-12-11T23:21:26.650Z <default:null> Module Structure v21338
                    [latest-21342]2021-12-11T23:21:26.658Z <default:null> Module Ruleset v21096
                    [latest-21342]2021-12-11T23:21:26.659Z <default:null> Module Rulesets v21096
                    [latest-21342]2021-12-11T23:21:26.667Z <GlobalExpression:null> Module GlobalExpression v21333
                    [latest-21342]2021-12-11T23:21:26.679Z <default:null> Module Rule v21337
                    [latest-21342]2021-12-11T23:21:26.683Z <GlobalReaction:null> Module GlobalReaction v21333
                    [latest-21342]2021-12-11T23:21:26.684Z <AlertManager:null> Module AlertManager v21333
                    [latest-21342]2021-12-11T23:21:26.685Z <default:null> Module Engine v21342
                    [latest-21342]2021-12-11T23:21:26.685Z <default:null> Module httpapi v21333
                    [latest-21342]2021-12-11T23:21:26.687Z <default:null> Module httpproxy v21333
                    [latest-21342]2021-12-11T23:21:26.702Z <default:null> Module wsapi v21334
                    [latest-21342]2021-12-11T23:21:26.703Z <app:NOTICE> Starting Structure...
                    [latest-21342]2021-12-11T23:21:26.740Z <InfluxFeed:null> Module InfluxFeed v21333
                    [latest-21342]2021-12-11T23:21:26.742Z <Structure:INFO> Structure#1 starting plugin influx (InfluxFeed)
                    [latest-21342]2021-12-11T23:21:26.743Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
                    [latest-21342]2021-12-11T23:21:26.752Z <VeraController:null> Module VeraController v21334
                    [latest-21342]2021-12-11T23:21:26.757Z <Structure:INFO> Structure#1 loading controller interface ezlo (EzloController)
                    [latest-21342]2021-12-11T23:21:26.769Z <EzloController:null> Module EzloController v21324
                    [latest-21342]2021-12-11T23:21:26.772Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://10.0.4.119:17000", "serial": "90000464" }
                    [latest-21342]2021-12-11T23:21:26.772Z <EzloController:null> EzloController#ezlo instance log level (null) (4)
                    [latest-21342]2021-12-11T23:21:26.773Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
                    [latest-21342]2021-12-11T23:21:26.777Z <DynamicGroupController:null> Module DynamicGroupController v21334
                    [latest-21342]2021-12-11T23:21:26.779Z <Structure:INFO> Structure#1 loading controller interface weather (OWMWeatherController)
                    [latest-21342]2021-12-11T23:21:26.783Z <OWMWeatherController:null> Module OWMWeatherController v21313
                    [latest-21342]2021-12-11T23:21:26.785Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
                    [latest-21342]2021-12-11T23:21:26.788Z <SystemController:null> Module SystemController v21342
                    [latest-21342]2021-12-11T23:21:26.790Z <Structure:INFO> Starting controller VeraController#vera
                    [latest-21342]2021-12-11T23:21:26.790Z <VeraController:NOTICE> VeraController#vera starting
                    [latest-21342]2021-12-11T23:21:26.835Z <VeraController:INFO> VeraController#vera loaded mapping ver 21301 rev 1 format 1 notice
                    [latest-21342]2021-12-11T23:21:26.837Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
                    [latest-21342]2021-12-11T23:21:26.837Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
                    [latest-21342]2021-12-11T23:21:26.838Z <VeraController:INFO> VeraController: deviceclass vera_system_object capability sys_system does not provide attribute state
                    [latest-21342]2021-12-11T23:21:26.850Z <Structure:INFO> Starting controller EzloController#ezlo
                    [latest-21342]2021-12-11T23:21:26.863Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking...
                    [latest-21342]2021-12-11T23:21:26.866Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
                    [latest-21342]2021-12-11T23:21:26.867Z <Structure:INFO> Starting controller DynamicGroupController#groups
                    [latest-21342]2021-12-11T23:21:26.869Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
                    [latest-21342]2021-12-11T23:21:26.870Z <Structure:INFO> Starting controller OWMWeatherController#weather
                    [latest-21342]2021-12-11T23:21:26.896Z <Structure:INFO> Starting controller SystemController#reactor_system
                    [latest-21342]2021-12-11T23:21:26.897Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
                    [latest-21342]2021-12-11T23:21:26.921Z <EzloController:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
                    [latest-21342]2021-12-11T23:21:26.922Z <EzloController:NOTICE> EzloController#ezlo connecting via WS to wss://10.0.4.119:17000
                    [latest-21342]2021-12-11T23:21:26.928Z <app:INFO> Structure running; pausing for controllers' initial ready
                    [latest-21342]2021-12-11T23:21:27.062Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://10.0.4.119:17000)
                    [latest-21342]2021-12-11T23:21:27.062Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
                    [latest-21342]2021-12-11T23:21:27.114Z <EzloController:INFO> EzloController#ezlo hub "90000464" is h2.1 (undefined) firmware "2.0.21.1785.1"
                    [latest-21342]2021-12-11T23:21:27.151Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
                    [latest-21342]2021-12-11T23:21:27.152Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
                    [latest-21342]2021-12-11T23:21:27.396Z <VeraController:NOTICE> Controller VeraController#vera is now online.
                    -ZWaveJS-UI 11.22.3
                    -Update 16/08/2026
                      OK. Thanks for uploading the logs and data. It looks like I made an error in the parsing of attribute lists. But, I think there's an easy workaround for you until I get a fix out... just change select_capabilities to default_capabilities. No other changes needed, I think.
                      • N Offline
                        N Offline
                        Thanks to you!
                        The fix is working.
                        Now I can truck energy consuption on Influxdb. The idea is to try to make in MSR what in HA is doing with utility_meter, Trend and Lovelace UI togheter. Maybe in future we will see a standard MSR energy plugin too.
                        Utility Meter
                        Utility Meter
                        Instructions on how to integrate the Utility Meter into Home Assistant.
                        Trend
                        Trend
                        Instructions on how to integrate Trend binary sensors into Home Assistant.
                        -ZWaveJS-UI 11.22.3
                        -Update 16/08/2026
                          164.2k
